09-18-2022, 06:57 AM | #45 |
13276
Rep 19,805
Just depends on the temp. Generally one uses max AC when it is far below the set, like when they just are starting. In that case the engine will not shut down. If for some reason one is using Max and it is below the set temp then it may shut down.
09-18-2022, 07:06 AM | #46 | |
1067
Rep 1,946
09-18-2022, 08:30 AM | #47 |
Rep 1,078
Do newer models use an electric motor driven a/c compressor instead of serpentine belt driven so that a/c can remain on (for short intervals) while the engine is stopped?
09-18-2022, 10:41 AM | #48 | |
308
Rep 340
Any ideas guys? |
09-18-2022, 10:46 AM | #49 |
Rep 4,337
it's been a while since I coded it off but I seem to recall Bimmercode telling me I had to put the car in diagnostic mode, or something along those lines, by quickly pressing the Start button three times in a row. Did you get that message? Before doing that, it would not code either anything or certain features, can't remember now.
09-18-2022, 10:51 AM | #50 | |
308
Rep 340
09-18-2022, 11:14 AM | #51 | |
Rep 4,337
Here is a video I just found on YT that basically shows what I recall even though this guy is not using Bimmercode. https://www.youtube.com/watch?v=mUYfhsde6GU . |
09-18-2022, 01:09 PM | #52 |
13276
Rep 19,805
You don't want to code it while it is running. Should be no need to put it into Diagnostics mode anymore, although out of habit I usually do, since it will do that when you connect.
09-18-2022, 01:11 PM | #53 |
13276
Rep 19,805
Putting the PHEVs and EVs aside, not that I know of.
09-18-2022, 01:14 PM | #54 |
Rep 4,337
Hey TB, when did the change happen to not engage diag mode? My last coding was in April/May timeframe and I needed to do it then. While its certainly easy to do, it would be good if that requirement went away. I'm on Bimmercode 4.1 (12440)-14.7.1
09-18-2022, 01:18 PM | #55 | |
13276
Rep 19,805
Edit: It could be that even though it happens automatically it should be done manually. The instructions say to do it.
09-18-2022, 01:23 PM | #56 |
Rep 4,337
09-18-2022, 01:24 PM | #57 |
13276
Rep 19,805
When I have some time later I will go out and try it just to make sure I'm not imagining things. Like I said, I usually hit it but have not always done so.
09-18-2022, 01:26 PM | #58 | |
Rep 4,337
What connection method do you use? |
09-18-2022, 01:28 PM | #59 | |
Rep 4,337
09-18-2022, 01:29 PM | #60 | |
13276
Rep 19,805
09-18-2022, 02:42 PM | #61 | |
Rep 4,337
Plugged my Ethernet OBD reader into the OBD port and the other end into my Ethernet to Lightning adapter and then plugged the adapter into my iPhone 1. Brought up the BimmerCode app on my phone and pressed Connect 2. Got a connection error and pressed the Open manual option 3. The manual for connecting via Ethernet tells me to press the cars Start button 3 times, which I then did and in a couple of seconds my dash display showed Diagnostic Mode active in white letters at the middle bottom of it. (This pic is out of order) 4. Started over by going back to BimmerCode and pressing Connect 5. After BimmerCode finished reading all the modules, it opened to the page you see in pic 5, showing the various modules it found in the car. Here you can see the Engine Centrol Unit which is the one you want for coding ASS 6. Selecting the Engine Control Unit brings you to the next page showing what features you have some control over. You can see on mine that I have both ASS features turned off (inactive). That how I disabled ASS full time no matter what mode I start my car in or put it in while driving. . |
09-18-2022, 03:01 PM | #62 |
13276
Rep 19,805
Just tested mine and it automatically goes into Diagnostic mode as soon as I hit the Connect button. I would guess the difference is due to the adapter.
Marty in NY2723.00 |
09-18-2022, 03:44 PM | #63 |
Rep 4,337
09-18-2022, 04:22 PM | #64 |
104
Rep 315
Sometimes I wish I had gone bimmercode vs bimmerutility. With the phone you can code anywhere for 75 bucks, I paid over 125 for a licence and need to drag around a laptop etc... Honestly BimmerCode is the way to go. And the cheat codes are super easy, click enable done ...
09-18-2022, 04:25 PM | #65 |
13276
Rep 19,805
No problem, us retired guys have the time.
09-18-2022, 06:21 PM | #66 | ||
308
Rep 340
