06-23-2023, 07:18 AM | #1 |
Rep 195
USB audio “no files found”
New 2024 X5M here. I loaded my music files to a new Samsung Fit Plus 256Gb mini-stick (same model I’ve seen others here use), plugged in to the port by the cup holders / wireless charging. The first time I used it in the car, it worked fine. Since then I get “no music files found”. No change after removing and reinserting.
I strongly suspect user error, but what did I do? Last edited by Jeff J; 06-23-2023 at 10:00 AM.. |
06-23-2023, 08:24 AM | #2 |
Rep 8,698
Drives: eVeRyOnE mAD!
double check your settings in iDrive. I believe there’s a setting to enable/disable reading USB files
06-23-2023, 06:28 PM | #4 |
Rep 195
My USB stick opens right up on my desktop computer at home with all of the files visible and playable. They're mostly FLAC, but there are a few MP3s; I believe both formats are supported in iDrive 8...
I haven't found any settings to enable/disable the USB feature so far, but I'll keep diggin. |
06-25-2023, 01:56 PM | #5 | |
Rep 16
06-27-2023, 02:19 PM | #6 |
Rep 474
Drives: 2022 BMW X5 xDrive 40i
It's said the USB stick has to be formatted in FAT32 instead of NTFS, tho I'm pretty sure I used NTFS on mine and it worked. You could check that.
2022 X5 xDrive40i
Black/Black/Black |
06-27-2023, 10:15 PM | #7 |
Rep 195
I "long" reformatted (as exFAT, since that's been the defacto standard for flash drives for nearly 20 years). I loaded all MP3 files, and not very many of them (maybe a couple dozen albums). It worked exactly as expected.
Emboldened, I decided to add the rest of my files. Failure, but slightly different... It decided that there was only one file on the stick, and that one file worked normally. Bringing the stick back to my desktop computer showed that all the files were there, and there's nothing particularly unique about the one file that worked (Benjamin Britten's War Requiem, in case anyone's curious) I noticed that I had over 8000 files on the stick, and read somewhere that this was a limit at one time, so I deleted a bunch that I almost never listen to and got it down below that number. Same behavior as before, and oddly, it's that same single file that still appears. So perhaps I'll give it a go in FAT32 or even NTFS just to see what happens. |
07-01-2023, 05:13 PM | #8 | |
237
Rep 372
2021 G05 X5 s40i Phytonic Blue | Ivory White Vernasca | Anthracite-Brown Poplar Matte Trim
2015 F10 535i M-Sport Space Gray | Black Nappa (Gone) |
07-01-2023, 05:46 PM | #9 |
13274
Rep 19,798
This is correct, I use 6 different ones although 5 may work. The system caches the indexes so you need to use multiple USB drives in order for it to recognize changes. For drives 1 thru 5 I put two songs on each one, put the drive in and start playing a song. Drive 6 would be my original drive.
07-04-2023, 09:24 AM | #10 |
Rep 195
After reformatting in NTFS, the system recognized all of my files and their folder structure and behaved exactly like it should…for 2 days. Now we’re back to just that one track. We were driving on my wife’s fob for a road trip this weekend, and I was manually switching to my profile when driving; maybe that had an impact, but no idea why it would…
I did find in the Entertainment / Nav manual that EXFAT is the preferred format, for what it’s worth. I may have to go dig up TurtleBoy’s thread about multiple drives to see if I can figure this out. This, plus Android Auto always auto playing media when connected, is my biggest gripe with the car (which admittedly are both minor things). |
07-04-2023, 09:47 AM | #11 | |
13274
Rep 19,798
https://g05.bimmerpost.com/forums/sh...8&postcount=28 https://g05.bimmerpost.com/forums/sh...2&postcount=36
07-11-2023, 06:55 AM | #12 | |
Rep 25
07-11-2023, 11:15 AM | #13 | |
Rep 195
Since my last post on the subject I re-formatted again and reloaded a slightly more curated subset of my files. It now recognizes and plays some of them, but the portion of the folder structure (i.e. Artist name) starting with letters H-S is missing. Everything A-G and T-Z appears to be present and working. I have no idea how or why. |
07-18-2023, 10:19 PM | #14 |
Rep 195
I wanted to circle back to this thread and (hopefully) close it out with a solution.
It looks like the issue is total count of files. I had over 9000 initially. After purging down to around 6000, things appear to work as expected. I have no idea what the magic number is, and whether it's files or folders or what, but my USB stick is working now. |
07-19-2023, 12:41 AM | #15 |
Rep 16
I too have resolved my issue with “files not found” but I went a different route. I tested a couple of files moved to the root directory on the usb drive and they appeared, I then copied all 9,500 files to the root plus deleted all the folders and they all appear correctly. I can still find specific tracks, albums and artists though I can no longer use the folder search.
I’ve now got my music on shuffle from a low-profile usb drive and it starts every time I enter the car, very happy |
12-16-2023, 09:37 PM | #17 | |
13274
Rep 19,798
No it doesn't. BMW removed user accessible storage a few years ago.
machop36.00 |
