01-26-2023, 02:30 AM | #1 |
Rep 91
Using ISTA to lower stock air suspension height
Has anyone used ISTA to lower standard air suspension height, instead of using droplinks?
See this thread ps://www.7post.com/forums/showthread.php?t=1753268Asd |
08-13-2023, 10:36 AM | #4 |
299
Rep 352
I was able to lower the car using ISTA. After reading this forum and a few YouTube videos I was able to lower the car by 20mm.
I started by reading the height status values and added 20 to that number. For example my status values prior to lowering was 754 (it was different in some of the corners by 2-3 mm) I changed it the original number +20. The one that was 754 I changed to 774 and that lowered the car. Normal height now sits as Sport Sports sits as loading Loading look like the picture below. Now I need bigger spacers 😂😂 calling Ben next week. |
mikekay105.00 |
11-05-2023, 07:41 AM | #6 | |
105
Rep 318
11-07-2023, 12:01 PM | #8 |
Rep 8,737
Drives: eVeRyOnE mAD!
11-08-2023, 06:35 PM | #10 |
Rep 8,737
I know of two other guys that have coded their air suspension, and both reported having to re-code after updates.
FYI note that some updates may not touch all modules, meaning if you coded something but the update doesn’t affect the module where your modification resides, you likely won’t lose it and have to re-code |
mikekay105.00 |
12-02-2023, 08:48 AM | #11 |
299
Rep 352
12-02-2023, 09:21 AM | #12 | |
Rep 8,737
but good they didn’t have any reason to do a deep dive. Some dealerships are opportunistic like that to pin something on the customer |
04-16-2024, 12:01 PM | #13 | |
Rep 15
Sorry to revive this post. But what cable did you use? also have any links for following to do this? |
04-20-2024, 09:38 AM | #14 |
299
Rep 352
Amazon has this one. I have had mine for many years now so I don’t recall where I purchase it.
OHP ENET Bimmercode OBD2 Cable for BMW F- Series Coding | E SYS ISTA+ ICOM Bootmod3 Bimmerlink OBD | Heavy Duty Cable |
