      08-08-2020, 08:33 PM   #23
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
Originally Posted by AlexGT View Post
Originally Posted by r33_RGSport View Post
bump, 100% Made in Germany.
Hi, could you advise what spacers should I use for this setup I’m planning to do in my 2019 G05 MSport?
Front wheels: OEM fitment is 22x9.5 ET37 and thinking on using TSW Aileron which 22x9 (narrower) ET37 (same ET).
Rear wheels: OEM fitment is 22x10.5 ET43, the Aileron is 22x10.5 (same as OEM) and ET38 (big difference from OEM) and this is is something that concerns me a little (I'm no expert on wheel fitment), wheel-size.com says "Positive scrub radius (about 6 mm). Scrub radius will be changed by 6 mm, this may affect the car's handling. Please check manufacturer recommendations. Please be aware that calculated value is approximate." I think I don’t need spacers here, right?
Wheel sizes are fine as long as you are using the stock tire sizes.
The front will be 6mm inward compare to stock and the rear will be 7mm poking compare to stock.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      08-11-2020, 01:59 PM   #24
AlexGT
AlexGT's Avatar
Guatemala
420
Drives: G05 X5 MSport
Thanks for the reply, however could you let me know your answer to the question I made about which spacers should I use in the front?
      08-11-2020, 02:39 PM   #25
r33_RGSport
In order to parallel the front to the rear, you'll need to do 13mm spacer on the front.
      08-11-2020, 03:17 PM   #26
AlexGT
AlexGT's Avatar
Guatemala
420
Thank you!
r33_RGSport12971.00
