05-08-2021, 03:49 AM | #89 |
Rep 109
Hi Guys,
Been searching the forum for an answer on these but can't seem to find it so..... If you fit these puddle lights (specifically the ///M logo) to the rear doors do they project on top of the welcome "stripes" when the door is fully open? Or do they look similar to the front door and project clear of the welcome lights? Cheers guys.
2020 M50d - Arctic Gray with Ivory White/Black Vernasca
05-08-2021, 05:23 AM | #90 | |
Generalissimo
641
Rep 1,392
05-08-2021, 12:49 PM | #91 | |
Rep 581
05-08-2021, 01:24 PM | #92 | |
Rep 1,203
Drives: 2023 BMW i4 M50
05-09-2021, 11:26 AM | #93 |
19
Rep 46
Having tried to force mine in, I broke the plug connector into which the puddle light attaches.
Any idea in the part numbers to replace that and how much labor? I did these on my F15 and it was a piece of cake. Don’t get why this is turning out to be a cluster |
05-09-2021, 12:29 PM | #94 |
Rep 8,698
Drives: eVeRyOnE mAD!
seems u didn't read earlier posts... it's been found these newer versions (63-31-2-468-386) are slightly bigger than the ones that come from factory, so a bit of trimming is involved to get them to fit. dumb move on BMW's part. they discontinued the older versions (62-31-2-414-105) that easily popped into the G05.
05-09-2021, 04:20 PM | #95 | |
Generalissimo
641
Rep 1,392
05-09-2021, 05:01 PM | #96 | |
Rep 8,698
I'm tempted to try to fit the new overlays into my original projectors. |
05-10-2021, 09:56 AM | #97 |
Rep 181
I just installed set of OEM's into my X5, however with the BMW roundel projection is slightly blocked off by portion of the door painted area. The M project doesn't do this because the M emblem is smaller in that vertical direction. I don't have my car here with me or I would take picture. Does anyone have the BMW Roundel installed that has same issue??
05-10-2021, 10:01 AM | #99 |
Rep 181
On my X5 a portion of the "B" is blocked by the painted area of door. Yes is did have to slightly trim the black trim hole to fit snap it in but on X5 there is some sort of anchor bolt which is slightly touching the projector housing. But I okay with things.
05-10-2021, 01:49 PM | #100 |
Rep 181
63-31-2-468-386 is definitely a wrong part of G07, I can not speak for G05. People who manage to push it in with the M logo will not see any issues since the door projection will not be cut off. The inner housing of this projector is a bit larger and it hits one of the body plastic part inside the door. See the image. When tightly pushing it in, it slightly tilts the projector inwards and BMW logo projection is obstructed by the door.
If this protruding plastic could be trimmed such that it no longer hits projector body do you believe it would go back to a normal position so that image is projected correctly??? |
05-11-2021, 12:07 AM | #101 | |
Rep 581
jcardea116.00 |
05-11-2021, 09:10 AM | #102 | |
Rep 5,324
I can confirm the original oem projectors DO fit without any modification required to the door or light housing. They snap in tight, but they do fit. The projection is not cut off by the edge of the doors. I have done all four G05 doors and all four G07 doors and two M2 Comp doors without any problem. I believe my X7 M50i took a total of 15 minutes to do all 4 doors. I think the latest OEM projectors that are dark grey in color are the ones that have issues. The all clear plastic OEM projectors are the only models I use because they fit every model. X7M50i. The G05 X5 looks exactly the same fitment. Last edited by MystroX5; 05-11-2021 at 09:22 AM.. |
05-11-2021, 05:04 PM | #103 | |
Rep 581
05-11-2021, 05:50 PM | #104 | |
Rep 5,324
05-15-2021, 04:09 PM | #105 |
Rep 581
Finally got the part 105 from eBay. So yeah it does go in my G07 with the trimming very easily. But for some reason it does not fit in completely. It is probably the same body plastic part blocking it. But this at least fits in.
Not sure if the one I got are faulty, but the projections are not 100% looking right. It seems stretched out and looking disgusting like a double chin :/ |
05-18-2021, 03:42 AM | #106 | |
Rep 3,479
Cross-continent road trip journal from BMW PCD to Alaska in new X7 M50i in this thread HERE!
New EVEN BIGGER road trip in X5 from BMW PCD to Alaska NOW ONGOING LIVE IN THIS THREAD! Wilderness road trip journal to Eastern Alaska in this thread And road trip journal to Denali and the Arctic Circle here in this thread! |
05-18-2021, 07:27 PM | #107 |
Rep 581
05-21-2021, 10:48 AM | #108 | |
BMW Junkie
176
Rep 306
Current Stable: 2021 BMW X7 xdrive40i, 2020 BMW X3 xdrive30i, 2017 Toyota Tacoma TRD-OR
Retired BMWs: 1999 BMW 328i, 2005 BMW M3 ZCP |
05-21-2021, 11:02 AM | #109 |
Rep 581
I am pretty sure, I tried both of the projectors on the driver’s door and they both did not go in fully
05-21-2021, 11:36 AM | #110 | |
BMW Junkie
176
Rep 306
