      08-22-2022, 05:29 PM   #23
PacShakur
Drives: BMW F80 M3
any movement on this?
r33_RGSport12972.00
      08-22-2022, 07:30 PM   #24
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
I don't think I will proceed. Not much demands unfortunately.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      08-22-2022, 08:02 PM   #25
I’mAllIn
38
Drives: 2022 X5M, 2013 BMW 335is
There wasn’t any demand for the internal combustion engine, Starbucks or Redbull until they came along ! Build it and they will come. Seriously, I hope it comes to fruition. Our X5M is my wife’s daily and I’d gladly spend some bucks to get the front tires back to OEM camber specs. Not looking to set a lap record and I suspect the vast majority of X5M owners are in the same boat. Either way, thanks for everything you provide for our machines.
r33_RGSport12972.00
      08-22-2022, 08:37 PM   #26
RR_Bimmers
RR_Bimmers's Avatar
229
Drives: 21' BMW X5MC, '23 BMW M4C Vert
  [0.00]
I'm in if you change your mind
r33_RGSport12972.00
      08-23-2022, 05:23 AM   #27
PacShakur
Drives: BMW F80 M3
Please man....we will buy it. Trust.
r33_RGSport12972.00
      08-23-2022, 07:15 AM   #28
onfireX5
Drives: F90M5,F85X5M
Run a preorder with a 50 % deposit. If it’s enough to pay the R&D after 1 month, build it. If not, refund the preorder due to the lack of ROI.
r33_RGSport12972.00
155ND914.50
      08-23-2022, 07:58 AM   #29
GotBeemed
Drives: 997 911, F95 X5M Competition
+1 for this guys idea
      08-23-2022, 12:45 PM   #30
MC2002X5MC
MC2002X5MC's Avatar
68
Drives: 2020 X5MC
+2 for that guy's idea. I'm getting about 6k miles on the fronts due to excessive inside tire wear. The rest of the tire has a ton of tread, but the inside strip is down to the cords.
I think the camber arm should be offered with the MSS springs to correct this issue.
      08-23-2022, 01:15 PM   #31
155ND
155ND's Avatar
915
Drives: X5MC Marina Bay Blue
+1
X5MC 2020 MBB
      08-23-2022, 07:19 PM   #32
x622
Forced Induction Connoisseur
x622's Avatar
962
Drives: 23 X5MC / 23 720s
2024 G87 M2  [0.00]
2023 Mclaren 720s  [0.00]
2005 Honda S2000  [0.00]
2008 BMW M3  [0.00]
2023 BMW X5MC  [0.00]
1964 Ford Mustang  [0.00]
1968 Pontiac GTO  [0.00]
Anyone want to send me a factory f95 upper control arm?
Oy vey, look at all these shekels
      08-31-2022, 11:44 PM   #33
Blizzle
Drives: 21 BMW X6MC
Ben I'm late to this party, but if it ever comes back up, I'd be in!
r33_RGSport12972.00
      09-30-2022, 08:34 PM   #34
r33_RGSport
Update.
After some research and digging around, I may have something over the shelf that may work.
I will test it as soon as my test car is dropped off. Should be next week.
I will follow up with the result.
Appreciate 10
onfireX53618.50
QF8221.00
Tenac4539.50
PBT143.00
GotBeemed415.50
Nykrayz127.50
m5 guy1691.50
      10-03-2022, 05:05 AM   #35
GotBeemed
AWESOME!
r33_RGSport12972.00
      10-03-2022, 05:34 PM   #36
Blizzle
Drives: 21 BMW X6MC
Sweet! Looking forward to it.
r33_RGSport12972.00
      10-05-2022, 02:32 PM   #37
r33_RGSport
Good news!!!
Swap the A-Arm and this is based on my measurement using analog tool.
Before: -2.75Ί
After: -1.5Ί
Factory recommendation: -1.2xΊ
I wish I have better way to measure the alignment. But, it should gives you rough idea how much it reduce the negative camber.
This would be the cheapest and fastest solution.
      10-05-2022, 02:42 PM   #38
Brandt51
Flavor of the month
Brandt51's Avatar
891
Drives: BMW F87 M2C
2020 BMW F87  [9.50]
Interesting. Where is the A arm from? I need to look at the alignment specs, but the visual difference is noticeable when lowered. Subsequently, I may be interested in the upgrade if the tires won't last less than 12k with MSS springs. But if they can make it that long, I don't think I would mess with the a arms at this time.
Appreciate the info
Samuel of the Internet
2023 F98 X4M Comp
2023 F95 X5M Comp
2020 F87 M2 Comp
r33_RGSport12972.00
      10-05-2022, 02:57 PM   #39
r33_RGSport
Appreciate the info
Came off G05 X5.
Again, camber doesn't reduce tire wear. Toe does.
Camber will allow you to have more surface patch to the tire.
Imagine putting a square foam like dish washing foam on a flat surface, that is 0Ί when all edges sit flat.
When you tilt 1Ί, it has more foam surface touching than when you are 2Ί tilt.
I am checking on my cost on this.
Side note though: I wouldn't recommend this A-Arm for track use since it is not spec-ed for actual M car.
Brandt51890.50
      10-05-2022, 03:31 PM   #40
weinerbarn
Unapologetic Tool Hoarder
weinerbarn's Avatar
734
Drives: 2020 X5 M Competition
Originally Posted by r33_RGSport View Post
Came off G05 X5.
I would say that's true within reason. Severe negative camber will absolutely cause tire wear as the contact patch of the tire is greatly reduced and you're riding on the inside edge and concentrating the load on a smaller area. When you can see daylight under the tire, you're going to wear through tires.
      10-05-2022, 03:41 PM   #41
r33_RGSport
And your point is?
      10-05-2022, 03:44 PM   #42
weinerbarn
weinerbarn's Avatar
734
And your point is?
Maybe I interpreted your comment incorrectly but it seemed like you were saying that fixing the out of spec camber would not affect tire wear.
      10-06-2022, 02:46 PM   #43
Brandt51
Flavor of the month
Brandt51's Avatar
891
Drives: BMW F87 M2C
2020 BMW F87  [9.50]
Came off G05 X5.
And your point is?
Respectfully, I think you're both wrong. From recent experiments I conducted, it would seem that footwear has caused premature tire degradation. Specifically the right shoe being of excessive weight has caused a noticeable drop in tire life. Very strange indeed.
2023 F98 X4M Comp
2023 F95 X5M Comp
2020 F87 M2 Comp
r33_RGSport12972.00
      10-06-2022, 02:50 PM   #44
r33_RGSport
Came off G05 X5.
Imagine putting a square foam like dish washing foam on a flat surface, that is 0º when all edges sit flat.
When you tilt 1º, it has more foam surface touching than when you are 2º tilt.
And your point is?
100% correct.
