02-09-2019, 12:08 PM | #1 |
Rep 4
Dog barrier for trunk area?
Has anyone found a dog barrier for keeping their beast in the trunk area?
Looking for something like this, but doesn’t look like they have anything for the G05 yet. https://www.travall.com/travallguard-tdg1166-html.html In my MDX we just used a rear seat cover for both dogs, but it’s really not ideal. Our 2 year old Airedale constantly tries to get up front while I’m driving. I have tried belting him in and he manages to undo the buckle. |
02-09-2019, 05:23 PM | #2 | |
Rep 186
Qwertyjackie5.50 |
02-09-2019, 06:31 PM | #3 |
25
Rep 36
I bought this one in November for $50, and it has worked well. I'm waiting for a better one to be made but this works for me right now
https://www.amazon.com/dp/B0002MABGE Here's my previous post (if you scroll to my OP you can see a picture with the dog fence in the background) https://www.bimmerpost.com/forums/sh...php?p=24159554 |
Qwertyjackie5.50 |
04-24-2020, 02:50 PM | #4 |
Rep 106
travall.com now has their pet barrier available for the G05: https://www.travall.com/travallr-guard-bmw-x5-2018.html
I have already purchased and installed this. Quality is on par for travall pet barrier (only comparison I have is their pet barrier for 2017 X3), but the way it installs is not quite as good as the other one we have on the X3. The small issue I see with the G05 model is related to the 2 steels rods used to 'secure' the barrier so it won't move. On the G05 model those 2 rods connect all the way down at the cargo floor using 2 of the cargo tie-down points. Whereas the model we have from them for the X3 those rods connect to the latches that lock the rear seats in upright position (i.e. only about 1/3 of the way down instead of all the way to the cargo floor). If my description of this is unclear, the images on the travall.com website illustrate this pretty good. With the above said, it seems like a minor issue to me when I compare the 2 designs. With those rods going all the way to the cargo floor, they could get in the way if someone needed to load something very wide into the cargo area... |
04-24-2020, 04:33 PM | #5 |
Rep 14
There is also a German company that offers pet barrier and divider:
https://www.kleinmetall.de/en/master...-2018-20300175 This one differs slightly from the Travall as it is not fastened to the cargo floor, but to the latches that locks the rear seats. Similar to the X3 design rlou is referring to. If you plan to buy the divider as well, be aware that the one from Travall doesn’t fit the 45e/ hybrid due to the raised cargo floor, whereas the one from Kleinmetall does. (Contacted both of them since I was aware of the raised cargo floor) Last edited by BimmerNor; 04-24-2020 at 04:51 PM.. |
04-26-2020, 01:10 AM | #6 |
Rep 457
Following with interest. Has anyone found any that fold up/down as my two bulldogs won’t be in the car all that often so would be nice to not block visibility all the time.
Did I imagine that one of the storage options come with a pull down divider? Obviously not strong enough for big dogs but for my two would prob suffice. Can it be retro fitted as I didn’t spec it? Last edited by Unit; 04-26-2020 at 01:16 AM.. |
04-26-2020, 06:29 AM | #7 |
Rep 773
Looks like the company in the OP now makes a guard for the G05.
2020 M340i xDrive, Portimao Blue
2019 X5 xDrive 40i, Mineral White 2006 S2000, Berlina Black (Track car) |
04-26-2020, 03:03 PM | #8 |
Rep 80
I have the one form KleinMetall as well as the StarLiner boot liner. My only other experience with these has been the OEM BMW one for my i3 and I think the way this one fits is better. It is not attached to the floor, so really easy to lower the seats and use the full depth. I haven't put a divider in as it is either dog or luggage etc. at the moment.
I did also get a harness for the dog form KleinMetall too (https://www.kleinmetall.de/allsafe-comfort-15390100) so he could sit with the kids in the back. It is so well made I'm sure you could tow an X5 with it (assuming dog is capable). |
04-29-2020, 01:10 PM | #9 | |
192
Rep 357
04-30-2020, 02:45 PM | #10 |
Rep 182
Some pictures from the kleinmetall installed in my g05.
I had the travall in my f11 Both are good quality. Pro kleinmetall - rubber feet are better and bigger - I like the black color better than the gray travall - g05 travall has some bars that go to the floor and will be probably a problem in the 45e raised floor Pro travall - a little bit cheaper Also I can remove the kleinmetal g05 very fast with 2 hand screws, 2 minutes work.... In my f11 I needed to loose 4 screws for the feet or I couldn't get it out easy. Not that i did removed it a lot. |
04-30-2020, 02:57 PM | #11 |
Rep 1,453
Drives: 2023 iX xDrive50
Is that the Masterline from Kleinmetall? I see they make a couple of different versions.
04-30-2020, 03:17 PM | #12 | |
Rep 182
https://www.kleinmetall.de/en/master...-2018-20300175 Pictures on their site are not up to date... |
07-02-2020, 11:16 AM | #13 | |
Rep 268
07-19-2020, 03:44 PM | #14 |
Rep 4
Can you recommend a Cargo Liner?
I am looking for a cargo liner that attaches to the rear seat headrests, but also has the ability to protect the sides of the cargo area up to about 17 inches.
I found this one on Amazon, but it doesn't come in black: https://www.amazon.com/FrontPet-Quil...93&sr=8-5&th=1 On our last X5 we had the Hamilton Ultimate Pet Liner (https://www.cargoliner.com/collectio...mate-pet-liner) but it attached to the vehicle with a ton of velcro patches and was difficult to remove and clean. I'd prefer something that I can easily remove and is machine washable. Any recommendations would be greatly appreciated. |
07-19-2020, 03:59 PM | #15 |
Owner
132
Rep 566
Drives: G05 30d M-Sport
Why not use the standard BMW mesh separation? I bought it for mine, and it's fitted, doesn't really go in the way of visibility. Mind you, our lab is very tame and just use the back seats (in a "sling" protection cover thing) so we actually never /needed/ the mesh, but I think it'd work pretty well -- unless your dogs are so rabbid they'd chew they way out or something..
Received 190911: X5 30d M-Sport:Artic Grey:Comfort Pack:Tech Pack:Visibility Pack: Driver Assist Pro Pack:Heat Pack:Glass Roof:Leather Dash
07-19-2020, 04:04 PM | #16 | |
Rep 4
07-20-2020, 03:05 AM | #17 | |
Rep 457
This lines the entire cargo area (floor sides and seat backs) and fits very well indeed. Secured with velcro strips and can be removed to wash. https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1 But as I don't want to be removing it often I then have this Gledring rubber matt on top of it as it's quick and easy to lift out and hose down after the dogs have been in the boot after a muddy walk: https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1 Last edited by Unit; 07-20-2020 at 03:32 AM.. |
07-20-2020, 12:08 PM | #18 | |
Rep 4
Unit218.50 |
09-08-2020, 09:28 AM | #19 |
Rep 2
12-02-2020, 11:48 PM | #21 | |
192
Rep 357
I take it out when I don't need it. It weighs a bit but it's do-able also to put it in and take it out whenever you feel like it. |
12-03-2020, 12:45 AM | #22 |
Rep 106
