01-27-2020, 11:22 AM | #1 |
Rep 85
Battery Management
Not to rehash this again, but has anyone else seen this error? The only info I could find on the forums was here:
https://g05.bimmerpost.com/forums/sh....php?t=1612639 I have an appointment with my SA this week for the second time in the past month for this issue. The first time this message popped up, my SA indicated that the cause of it was due to the fact that the latest iDrive 11/2019.41 didn't "fully take" with some of the ECUs. The car has been driving fine otherwise. Only thing I've noticed has coincided with this error is that the weather has been cold. I don't have any peripherals (e.g. dash cam,etc) connected except a flash drive in the cup holder area. |
01-27-2020, 02:28 PM | #3 |
Rep 810
Yes I've had that before, it means your Battery is getting low.
The dealer dealt with it by putting it on a high current charger for 1 hour, and it went away. Watch out for using the cars accessories without the engine switched on, especially if you have a dash cam or something similar. |
01-27-2020, 02:41 PM | #4 |
Rep 1,448
delete
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 |
01-30-2020, 12:23 PM | #5 |
Rep 85
Ok, I can't believe this. My X5 has been in the shop for a day for them to perform a battery draw to see why this message keeps popping up. My SA claims his tech discovered the IBS cable/block has gone bad. Brand new car of 6 months and something like this goes bad already??
01-30-2020, 12:41 PM | #6 |
Rep 22
Friend of mine is having this message popup time to time. Recently after he came from 2 weeks vacation, he could not get in into car - battery was dead. BMW advised him to drive a car more before vacation..... - strange advise. He is bringing a car now to dealership for research!
01-30-2020, 12:49 PM | #7 |
Rep 85
That was exactly how mine started. Randomly, 1-2x a week, the message would pop up when started up the car. It seemed to start doing this with advent of the cold weather this season.
01-30-2020, 02:29 PM | #8 |
Rep 810
The same message has just come back, around 2 weeks after they fixed it (see above).
Looks like some battery draw is happening from somewhere.... |
01-30-2020, 02:42 PM | #9 |
Rep 2,609
Jokers. About as useful as this:
01-30-2020, 05:08 PM | #10 |
Rep 4,503
Drives: 2022 iX xDrive50, DGM
The G05, more than any car I've owned, benefits from a trickle charger, even garaged. You might even say it requires one, from all the reports.
01-30-2020, 05:32 PM | #11 | |
Rep 4,331
I did convince her one time but never will try again. Why? Cause she backed the X out of the garage without disconnecting the tender! I guess she sure told me!!! |
Paladin15556.00 |
01-30-2020, 05:33 PM | #12 | |
Rep 4,503
01-30-2020, 06:22 PM | #13 | ||
210
Rep 336
volodp196.50 |
01-30-2020, 08:59 PM | #14 | ||
Rep 589
In all seriousness, I am getting a m50i. But my situation is that for daily drive, I only have like 5km from my home to work and it's city driving. m50i won't be able to stretch much of her leg. Is it gonna be a problem for the battery? Is the battery easily accessible, so I can put a trickle charger on every week or so? Anybody can take a picture to show me? Thanks |
01-30-2020, 10:06 PM | #15 | |
Rep 4,331
Then, she bought a Golf diesel and stopped driving the X, she then sold the diesel back to VW when Dieselgate hit and bought a GTi and still doesn't drive the X. She's just out of practice and forgot about it being on the battery tender. Well, anyway, we only use it for trips anymore. I freaked when she came back in the house and told me, but in the end, there wasn't a mark on the car to be seen and the tender wires just pulled apart without any damage. Whew! BMW's have always given us a battery + terminal in the engine compartment (red plastic cap covering it) and there are plenty of places to find a negative terminal or frame member. Just get a battery tender with the alligator clips or as a friend of mine does on his Jag, he uses ring terminals and mounts the connections in a more "secure" way and then just pulls apart the disconnect inline connections on the tenders cable when he wants to drive it. I has a set of batteries last 14 years on an 840 I had - impressive! |
01-30-2020, 10:52 PM | #16 | |
Rep 4,503
01-31-2020, 08:12 AM | #17 |
Rep 421
Any issue leaving the hood unlatched for the lead to the charger? Will it prevent the vehicle from completely shutting down or create an error code?
Also, a number have described using a battery tender. I have one, over 20 years old that works perfectly, but is there anything unusual to consider with the X5's battery; e.g. AGM vs lead acid? |
01-31-2020, 08:19 AM | #18 | |
Rep 4,503
01-31-2020, 04:20 PM | #19 | |
Rep 421
01-31-2020, 04:58 PM | #20 | |
Rep 7,477
And ALWAYS use the engine bay jump start terminals when trickle charging modern BMWs which have an IBS (intelligent battery sensor). When you bypass that module, you can set yourself up for check control and possibly battery charging issues.
02-01-2020, 09:33 AM | #21 |
Rep 421
Thanks for the info. So, I take it, the main battery is an AGM?
Can't help but smile at the requirement in the BMW document to only use battery chargers approved by BMW, as if somehow, their batteries are different than others. |
02-01-2020, 12:18 PM | #22 | |
Rep 2,609
Yes, the main battery is AGM.
