10-28-2020, 06:48 PM | #45 |
Rep 6,805
While an extra step...shut the vehicle off, then check the condition the cabin checkbox that comes up on the display. It will stay on for about 20-30 minutes, then shut off. That was designed so you could do a quick run into the shop to run an errand and come back to a comfortable vehicle. The radio will stay on for about 10-minutes, but it can be turned back on just by pressing the volume knob.
If it's a minute or two to get out and open a gate...nobody's going to really get chilled or overheated. |
volodp196.50 |
10-29-2020, 01:51 AM | #46 | |
44
Rep 42
Indeed, the question stays open.
BMW X5 45e X-line
10-29-2020, 02:09 AM | #47 | |
Rep 804
EDIT: It still switches off after installing 07/2020.54. Last edited by biterror; 10-29-2020 at 07:43 AM.. |
ikheetleon218.50 |
10-29-2020, 04:43 PM | #48 |
Rep 6,805
Pathway lighting can be set to various times, but I'm not sure if all of them are available in iDrive...may take coding to give you more options. That would give you the lights, at least for that duration. To manually activate it (it can be automatically activated if you lock the vehicle), push the lighting lever forward momentarily.
biterror514.00 |
11-24-2020, 04:54 PM | #50 | |
Rep 56
I was under the impression that sound stays on but AC shuts down. I'll double check that later. |
11-24-2020, 10:06 PM | #52 | |
Rep 56
My only actual regret was the sapphire black color, which now I think was too conservative of a choice for this car. |
DuskPhilosophy77.50 |
11-25-2020, 12:24 AM | #53 |
Rep 6,805
Shutting down if the driver exits the vehicle isn't a bug...it's a purposeful choice by BMW. FWIW, the vehicle will stay running if your seatbelt is on and you open the door, as it realizes you aren't planning to exit the vehicle. You can tell it to continue the HVAC once you shut it off, if that's an issue and the entertainment system will continue to run, and restart if you press on the volume knob after it times out.
On an ICE, keeping the vehicle running might have some advantages, but not many if you're trying to optimize efficiency. |
11-25-2020, 09:14 AM | #54 |
Rep 804
Luckily, the headlights will stay on when you exit the vehicle - I was worried that they would be switched off. I think I can live with the pain of pressing the start button when returning into the vehicle..
11-25-2020, 10:24 PM | #55 |
805
Rep 1,790
What am I missing here? I have a 2020 X7 40i. I regularly have to stop the car, put it in park, unbuckle my seat belt and exit the vehicle to pick up wind strewn branches in the vehicles path. All of this while the engine is still running. When I exit the car it continues to stay running just like an old car does without all the technology.
For reference, I have iDrive set to shutdown when the driver's door is opened. However, that shutdown only shuts down the electronics "AFTER" the engine is turned off. If I don't open the driver's door, for up to 10 minutes after the car's engine is shut down, the radio/Bluetooth electronics continue to play until I open the driver's door. If I open the driver's door while the engine is running, everything continues to run including the radio/AC/Heat, Lights, etc. Reading the previous posts it appears that your vehicles turn the engine off as soon as you open the driver's door. Is this happening on the Hybrid engines only? |
11-26-2020, 01:48 AM | #56 | |
Rep 804
When I unbuckle and open the driver's door, the car shuts down (music keeps playing and the headlights stay on) and I have to Start it again before I can put it in D and continue driving. (It doesn't actually switch off the ICE because at low speeds it's running on battery already.) |
11-26-2020, 03:05 AM | #57 | |
805
Rep 1,790
I think this issue must be related to Hybrids only. |
11-26-2020, 07:45 AM | #59 |
Rep 127
Good to know! I’m hoping to be very happy as well!
11-26-2020, 12:53 PM | #60 |
Rep 480
I got an update from the dealer where the checkbox is for. When you go are driving, and stop, press the stop/start button after that moment the checkbox determines what happens when you open the door. So I think it's a matter of misinterpretation. I've suggested to update the drivers guide with an example. The dealer agreed it's a bit vague now what it does.
12-03-2020, 06:31 PM | #61 |
Rep 198
this is SUPER annoying in my car... and make it so much worst if you have the digital key because you have to re-authorize yoru phone each time....
It really doens't make sense. I always step out and go get stuff in my trunk of move the car just a bit to get space to open my door and I have everythign shut off.. that is rEALLY annoying.
2021 45e journal
12-15-2020, 08:23 PM | #62 |
Rep 9
Anyone find a fix? My 21 40i does this and I can’t stand it. As well as there is no button to turn off the start/stop feature when coming to a stop. Maybe need a bmw cider to fix these small bugs.
01-11-2021, 05:46 PM | #63 |
Rep 8
same problem
Hi ! Bonjour ! Hallo !
This issue is "driving" me crazy... So I search on the web and I saw your posts. I have the car from 3 days ago... It is weird how we all have tried the same things to make it stop. Anyway, by reading you all, i can say two things : 1. if I put the car in sport mode, the gearbox to the left on "manual", then I activate the electrical parking brake to prevent the car from moving, I can get out and the car will stay on. I'm sure that's not the purpose of buying such that car but that works. But, what a long manipulation... and if a child gets away from his seat and for example puts his foot on the accelerator, this can be a big drama. 2. I'm thinking of something, why not try the following steps : -stop where you want -> take away seat belt -> put the seat belt again but by attaching them from behind you (so you are free, just faking the car) -> open the door. If that works, it can be a big deal, isn't it ? Have a nice day ! |
01-11-2021, 06:02 PM | #64 |
Rep 198
same here... I have a 45e so I don't have to deal with any ICE engine start/stop but still the AC stops for my passengers and in Miami is in not ideal especialy with a small child...
I undestand if BMW wants to put the carin PARK but shuttng off climate control and all, I DO NOT understand.. I hope they make an over the air update on this... as well as the really crappy 3d parking camera accuracy.
2021 45e journal
01-11-2021, 07:33 PM | #65 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
On my MY21 40i with July iSTEP I don't seem to have this issue while using the digital key card.
My use case: I use a phone wallet and keep the key card inside. Started the X5 many times with the key card and stepped out multiple times (with and without the phone wallet). I recall getting a message on the iDrive, but the car didn't shut down. Am I missing something?
2021 X5, Excellence, M Sport, DHP, DAP, RSE, MW, Merino.
01-11-2021, 08:05 PM | #66 | |
Rep 2,420
