11-06-2020, 05:55 AM | #67 |
Rep 802
I've been thinking of roof rack, too. Or below the cornering lights, but maybe that's too low. Will see. I wonder how difficult it would be to get the LED bar to activate when the lasers are switched on.
11-06-2020, 05:39 PM | #68 |
Rep 63
Yeah. I the high beam has two options
1. Normal high beam when the lever is pushed to the high beam position 2. By activating the automatic high beam via the button( this activates the auto dimming and light direction movement) So my thoughts are that if connected to the high beam wire it would activate the light bar on both options above. That way can turn off light bar if wanting to use the auto function. And turn on light bar and just use constant manual high bean when you push lever to high beam. Does that make sense. |
11-07-2020, 01:20 AM | #69 | |
Rep 802
11-07-2020, 05:47 AM | #70 |
Rep 63
Yeah i think the only option is to manually switch the light bar off when using the auto high beam option.
I think there may be a live wire for manual high beam on/off I think when on auto high beam the high beam wire (if there is one)does not actually switch off. And not sure thats legal. Need a wiring diagram. |
11-09-2020, 02:53 PM | #71 |
Rep 1
I idenfied a huge difference with laser lights. Not just the power but the intelligent bean who moves to the different directions help me to drive and when you use another vehicle withou it, you miss it.
12-04-2020, 02:33 PM | #72 |
Self-Deprecating Narcissist
7258
Rep 6,561
12-05-2020, 03:23 AM | #74 |
Rep 802
Not directly related to X5, but the Finnish magazine Tekniikan Maailma just compared AUDI A6 Avant TFSI e 55 Quattro, BMW 530e xDrive Sedan, MERCEDES-BENZ E 300 de T 4Matic and VOLVO V90 T6 TwE AWD (all PHEVs). BMW had the worst headlights of the four. Even with lasers it's not as good as Mercedes, for example. The lasers could not be measured because they work only when you're driving 60 km/h or faster.
The dotted line for BMW is for the adaptive LED lights with lasers. The areas drawn show where there's at least 5 lux of light on the road. High beam range for MB is about 260 meters (850 ft) and it's also wider than on BMW (170 meters, 550 ft). BTW, the BMW was ranked last in the test. ;-( |
iconoclast7257.50 |
12-05-2020, 08:41 AM | #75 |
7258
Rep 6,561
In regards to laser only they would have less reach by half. 300m versus 600m. In general USDOT/NAR headlights are 20% dimmer than E-Code variant and do not have as sharp of a cut-off like ROW headlights. Let's not forget that we are very lucky to get the ulgy yellow warning sticker... So that is a plus.
