12-01-2020, 02:12 AM | #1 |
Rep 444
Battery charging advice
I know this part of the forum isn’t the right place for this thread but I need some quick help and most peeps seem to read this part of the forum.
I drive 6 miles a day Monday to Friday just lately so my battery has depleted to a state where everything has shut down other than starting, no warning, just shut down. Went to the car in the dark this morning and no light of any sorts, puddle, door handles, interior or headlights. I am reading there are two battery’s, boot and engine bay plus I have the active suspension which drains one of them further than norm. So does anyone know if there’s a battery charger hook up point that will charge both at the same time? Thanks guys |
12-01-2020, 06:36 AM | #2 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
Only use the battery hook up point in the engine bay and select Auto AGM setting on the battery tender. Both batteries will be charged. Many owners here like CTEK MXS 5.0
Here is a good thread on this topic: https://g05.bimmerpost.com/forums/sh...php?p=25574804
2021 X5, Excellence, M Sport, DHP, DAP, RSE, MW, Merino.
12-01-2020, 08:01 AM | #3 |
Rep 8,815
^^ what he said
If you charge at the terminals under the hood the car will figure out the rest in terms of which battery needs charging. Keep in mind with the ctek it will take a good 15-24 hours to get it fully charged up. Maybe longer if your battery is so drained.
Addbuyer833.50 |
12-01-2020, 09:27 AM | #4 |
Rep 444
I've put a standard battery charger on it to get some juice in. That said, the battery terminal reading under the bonnet was 13.5v which is fully charged?
My thoughts are that the X5 gremlins are at work again and the battery wasn't so discharged that it shut everything down. As stated, for a couple of months my usage has been 10 x 3 mile journeys per week and with it being winter I've had all the creature comforts burning juice, so it certainly points to a discharged battery. If you can imagine walking up to your car in total darkness and the comfort entry doesn't acknowledge your presence, no lights of any kind come on, not even when the door is opened and upon starting the car a warning comes up saying the battery is critical (i think thats what it said) |
12-01-2020, 03:58 PM | #5 |
Rep 8,815
Is there anything aftermarket installed on the car that could be draining the battery? I also disable the feature that automatically unlocks/locks the car when it senses the keys. This will most definitely cause more battery drain when its parked.
Maybe its time for a trip to the dealership just to be on the safe side. This reminds me i should probably top off my battery as the temps has been dropping and I don't do a lot of highway driving to fully charge up my batteries as well.
Addbuyer833.50 |
12-01-2020, 07:31 PM | #6 |
BMW Aficionado
1362
Rep 1,827
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I have a couple of these and they work great. (BMW rebrands these and applies their logo for a price premium) I use the CTEK's on the Z4 and the Mini which spend a lot of time sitting in the garage, so I can peoperly maintain the AGM battery. On my Tundra that sits outside in the sun most of the time, I use this placed in the dash to maintain my Lead Acid battery. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
Addbuyer833.50 |
12-02-2020, 05:53 AM | #7 | |
Rep 444
Ironically, I have just reverted back to auto locking when walking away. I got so fed up with the car failing to lock from the door handle touch, worked well in principle with having a dog but was so temperamental! Worst touch locking I've had a car EVER Anyone know if the handle sensitivity can be adjusted by BMW? |
12-02-2020, 05:57 AM | #8 | |
Rep 444
Maybe i need to put the X5 on the C-Tec over the weekends from now on |
12-02-2020, 12:11 PM | #9 |
Rep 53
Not that I want you to have an issue with your car, but I hope this isn't the norm. With all of the travel restrictions in place, my wife and I are pretty much staying at home are we're lucky if we make a trip to the grocery store every other week. I definitely don't want to be coming out to a dead battery on these rare trips.
12-02-2020, 12:43 PM | #11 | |
Rep 485
12-02-2020, 01:12 PM | #12 |
Rep 6,805
The vehicle turns the 12vdc sockets off after about 15-minutes after you shut it off.
Short trips in the winter where you may be using all of the heating can suck a battery down fairly fast, and you may have some idling in there that also inhibits the ability to recharge at a decent rate. It's possible that you have a module(s) that is not getting the shutdown message and staying in active mode. That can drain the battery, too. There's a specific test that can be done to check on that. The alarm and other similar stuff have known power drains, so anything higher than that needs investigation. On my previous vehicle a 535GT, it only got driven periodically, and if I didn't put a trickle charger on it, it would eat through a battery in a couple of weeks to a max of a month. Even with an AGM, they don't like frequent deep discharges. When it was driven, it got maybe 1K miles or so on it, but in between, I drove my EV for all local trips. The X5 45e just sits plugged in when it's home, so that isn't an issue. It's best if your charger is settable to AGM battery type. |
12-02-2020, 02:50 PM | #13 |
Rep 804
I haven't done any measurements on X5 (yet?), but one cold winter day (around -30 C or -22 F) I checked the charging voltage on my Saab 9-5 and it was 14.7 V at the battery terminals with the engine idling and all imaginable electric loads switched on (lights, seat heaters, heater fan, audio, windscreen wipers etc.). The problem with the battery is that when it's cold, it just doesn't accept much charging current - and the charging voltage should be pretty high (expecially for AGM batteries). And the batteries in many BMW models are in the coldest possible place, under the boot.
Addbuyer833.50 |
12-03-2020, 06:54 AM | #14 | |
BMW Aficionado
1362
Rep 1,827
How old is your battery? |
Addbuyer833.50 |
12-03-2020, 07:11 AM | #15 |
Rep 444
12-03-2020, 08:12 AM | #16 |
Rep 4,504
Drives: 2022 iX xDrive50, DGM
Trickle charger; charge fully every couple of weeks in these strange times, unless you still regularly commute. Battery should go for a month or two cold, and restart the car, but odd gremlins may start to pop up, and short jaunts never fully recharge the battery. BMW is not unique in having a host of electronic parasites on board - nature of the beast in a nearly fully automated, electronically controlled and driven automobile. A '57 Chevy battery, in a '57 Chevy, will last much longer without topping off.
12-03-2020, 08:24 AM | #17 | |
BMW Aficionado
1362
Rep 1,827
I think the best advice for any battery is to use a proper battery tender when it will not be cycled for regular duty. |
Paladin15556.00 |
12-03-2020, 08:30 AM | #18 |
Rep 4,504
Always good advice, although my '64 Karman Ghia convertible sometimes sat up on the rack for 6 months between starts, and cranked like a champ when I broke it out in the Spring.
11-30-2022, 07:51 AM | #19 |
Rep 21
Howdy everyone, I found this thread super helpful for my 2021 G05 X5 that had a dead battery. My wife drove our son to daycare in the morning and came to find it dead later in the afternoon. No power to unlock doors or anything. Used the key to open the driver door and had the alarm going off. Finally plugged in my CTek 7002 to find that the battery was completely dead. Left it on for about 3h and still nothing. Boosted the car and drove it around for 30m to get some charge. Plugged it back in and found it's at about 25%. Left it charging over night and come this morning to see the charge level hasn't changed. Is this normal?
For reference I've used this charger on my 2017 F30 and usually after 1 nigh the battery is fully topped up. |
11-30-2022, 09:26 AM | #21 |
Rep 21
Update:
I found this thread which seems to be very similar to what I am seeing. Will leave it to charge for the day and see if I see any changes. https://g05.bimmerpost.com/forums/sh...1&postcount=63 |
