11-13-2018, 05:22 PM | #45 | |||
239
Rep 353
Call them and ask for Ethan x4689 |
11-13-2018, 05:40 PM | #46 |
Rep 255
Drives: 2021 M-B GLS 580
I am still waiting for someone (tire mfg. or forum member that finds something) to come up with a tire only solution for all season. My current and previous m-sports I put Conti DSW on the 20 inch staggered--works great. No solution yet for the new G05 22 inch that I can find. I am about a year out and looking forward to M50i; hope there is staggered 22 inch all season coming. JLR & Conti have 22 inch for RRS but those setups are not staggered or quite as wide. All your new G05's look spectacular BTW.
2020 X5 M50i
2017 X5 50i M-Sport (Retired) 2013 X5 50i M-Sport (Retired) |
Mitchfin97.50 |
11-14-2018, 03:30 AM | #48 |
Rep 131
You've made a mistake and you should change your order - you had to order both front/rear 9J and tires 275/45/20. That's a right size in Poland - call your Dealer.
11-14-2018, 04:51 AM | #49 | |
25
Rep 41
Front: 275/45/20 ET 35 - 9J Rear: 275/45/20 ET 25 - 9J Then it will be ok? |
11-15-2018, 08:12 PM | #51 |
Rep 11
Has anybody put these on a G05 Msport yet? I would be interested to see photos if possible. The mfg confirmed that 19" will not fit over the Msport callipers but 20" is good.
11-15-2018, 11:02 PM | #52 | |
Rep 442
I'll be mounting Nokian Hakka R3s on these. |
11-16-2018, 03:21 AM | #53 |
Rep 95
Just ordered VMR 710 20 X 9.5 ET 37 in matte black.
Square setup with Yokohama Iceguard IG5 in 275/45/20 I might get 25MM spacers to push the wheels out to be more flush with fenders Suck i have to take off the 22's so soon.. |
11-16-2018, 08:29 AM | #54 |
Rep 2,515
Confirming the 20" winter package from Tire Rack does in fact mount beautifully on the G05. Not my truck, but I asked one of my service guys to test fit it. Plenty of room around calipers.
?16 M2 Long Beach Blue/Black, 6MT
'22 X5 4.0 M Sport Black Sapphire/Tartufo ?22 Tesla Model Y Performance Midnight Silver/White |
e90_2_f80239.00 |
11-16-2018, 09:44 AM | #56 | |
Rep 95
Do you know if tire rack supplied new tpms sensors? Supposedly you have to supply your vin to get the tpms sensors to be programmed first. Last edited by M3 Chris; 11-16-2018 at 10:03 AM.. |
11-16-2018, 09:54 AM | #57 |
Rep 769
11-16-2018, 10:10 AM | #58 |
Rep 2,515
Wheels come mounted with TPMS
11-16-2018, 02:09 PM | #60 |
Rep 428
wheels from GL/GLS or ML/GLE or even S-Class can work.
mercedes is 5x112 with the same centerbore as BMW now. (66.6mm). The GL/GLS has offset around -60mm, so you will likely need a 15-20mm spacer for an X5. The S-Class is around -40mm which might fit directly without need for spacers, get the appropriate lug bolts. |
11-17-2018, 03:22 AM | #61 |
Rep 602
I called tire rack and even though i had the size and offset they wouldn't recommend any wheels because they don't know if the spokes will clear the brakes... I need to get a winter set ordered here SOON!
11-17-2018, 03:34 AM | #62 | |
Rep 116
Thx in advance for all the info on this winter setup! |
11-17-2018, 09:36 AM | #63 | ||
Rep 2,515
11-17-2018, 03:55 PM | #64 | |
Rep 116
EDIT: since posting this, I went to tire rack and it he MSW type 48 in 20” are sold out for the season. Damn. Last edited by JLR0523; 11-17-2018 at 04:10 PM.. Reason: Update |
11-17-2018, 04:26 PM | #65 | |
Rep 2,515
11-17-2018, 10:40 PM | #66 |
Rep 424
Apologies if this is a dumb question but I am a newcomer to needing winter tires. Last season was my first time living near snowy conditions so I had a set of Blizzaks mounted on my F15 stock rims. I see most folks in this thread seem to prefer a completely separate set of rims and tires rather than just swapping the tires twice per year.
Any reason why that would be preferable? I can think of salt perhaps causing corrosion on the rims, but I typically wash my car as soon as I get down from the mountain (just go up for ski days, and back to wet but not snowy conditions for the rest of the time). Thanks! |
