02-23-2024, 01:36 PM | #1 |
Rep 161
Allow turning off headlights while driving???
Hello,
It seems like a new software update from BMW disallows turning OFF the headlights when you are driving. Does anyone know how to fix this?? I want to be able to turn off headlights when driving at night without slowing down/parking. I used to be able to do this, but BMW seems to have updated the software to disallow this. 2020 M340i. Thank you!! |
02-24-2024, 09:13 AM | #2 |
B58 Power
497
Rep 633
Drives: 05/2022 M340i xDrive Touring
It was not possible and still isn´t possible.
https://g20.bimmerpost.com/forums/sh....php?t=1709540
05/2022: BMW G21 ///M340i xDrive Touring - Individual Verde Ermes
03-29-2024, 08:31 PM | #3 | |
Rep 7
BimmerCode has options to code 1. “switch off exterior lights” ( we can press OFF on the switch cluster and it actually works without the warning “❗️ lights off while running “ 2. enable “check box for DRL “on the infotainment. With above 2 coded - fire the engine - Auto headlights on - press “OFF” on switch cluster - headlights go off . This option to press “off” works on standstill , idling and any speed less than 20kmph ( means while running if we slow down below 20kmph and press OFF , it works ) . - press side lights on switch cluster - they go on ( both front and back simultaneously) .. option to switch off as per above for headlights. - On infotainment now there are 2 seperate check boxes for front and back DRL .These can individually switch on and off the front/ rear DRL separately independant of speed . To select “off” we need to be below 20kmph , but once done , then it stays till next restart irrespective of speed / time / distance travelled . |
