M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > M2 Alignment Issues
      03-22-2017, 08:04 PM   #23
Tumbleweeds78
Drives: M2
See if it pulls in a large parking lot. If it doesn't, it's probably the crown in the road causing it.
MSULLY25.00
      03-23-2017, 04:09 PM   #24
davidk
62
Drives: 2018 X3 M40i, 2018 M2
Although your issue may be related to the road crown, it may be entirely different. I read on a different BMW forum about someone having the same issue as you, with their M2 pulling to the right since new. His post included this sentence: A regional BMW manager says they have had this issue and that the car needed a new steering column (not just a steering rack, although that might help somewhat) due to a spring that caused the pull on the steering column. I am not sure where in the country he is located, but may be something worth looking into, since I didn't see it mentioned in this string. He indicated alignment and messing with other suspension settings did nothing to rectify the issue.
MSULLY25.00
      03-24-2017, 12:37 PM   #25
M2MG
Drives: 2017 M2
Mine has also pulled to the right since new, now 600 miles. On a flat surface, steering wheel tilts to the right.
Also disturbing is that the car is lower on the front passenger side than the driver side by 3/4 of an inch, measured from top of wheel well to middle of wheel. I brought it in to the dealer for that specific issue and it was "in spec" even though the slope is noticeable in both the driver and passenger seat.
MSULLY25.00
MDriven141.50
      04-13-2017, 05:15 AM   #26
bMira23
bMira23's Avatar
Spain
Drives: BMW:M2
Hi, mine as well 600 KM, and also goes to the right, i tried in very diferent roads and still goes to the right?
Did you guys find any solution? Would an external comapany alignment solve this issue?
      04-19-2017, 12:20 AM   #27
Dragster RR
Drives: 2020 M2CS
Mine too!
200 miles and mine has a slight pull to the right as well. I'm not too concerned about it though. I'll bring it in at around 500 mi and have them adjust it. My first 500 mi are 'gentle' so don't expect too much uneven wear on the tires.
      04-19-2017, 06:46 AM   #28
reppucci
340
Drives: 04A6 2.7T(DD), 16M2 BSM MT EP
2016 M2  [0.00]
1995 M3  [0.00]
2006 Mini Cooper S ...  [0.00]
2004 A6 2.7T  [0.00]
1994 325is  [0.00]
I assume they checked that the "shipping" blocks in the springs had all been removed prior to the car being put into service. I think someone on this forum members mentioned finding these in their M2 springs; and others even several years later on other cars!
      05-05-2017, 07:21 PM   #29
mailman411
Drives: MY17 M2
Took my car in last week for the same alignment issue pulling to the right. Tech took a look, and with the advise of BMW tech, they are replacing the steering knuckle (i have no idea what this is). They think it has to do with the positive camber but my car is already at the maximum and couldn't be adjusted any further. So, apparently, a replacement steering knuckle will fix that and allow the camber to be adjusted correctly. or something to that effect.
i'll see what happens next week when i pick up the car.
btw, do you guys hear ticking sounds from underneath the car after it fully warms up? I'm guessing its the exhaust and the metal expanding/contracting from the heat. dealer says this is normal and that since the m2 lacks insulation it is more apparent inside the car. just wanted to confirm with you guys if this is indeed normal.
      05-05-2017, 08:35 PM   #30
M2BSM17
Drives: 2017 BSM M2 6MT
2017 M2  [0.00]
I hear the ticking sounds. Sometimes I almost think it's the roof, but agree it's coming from under the car. I think it's normal. Not worried about it.
Also, I sometimes have thought my car is pulling right, but it seems to be the crown of the road causing it in most instances. I'm not worried about it. This car is so amazing I'm not going to let my typical OCD ruin any of the experience.
      05-11-2017, 05:00 PM   #31
bMira23
bMira23's Avatar
Spain
Drives: BMW:M2
Does the issue gets solved by replacing the steering knuckle?
Thanks in advance...
      05-11-2017, 06:12 PM   #32
David1
David1's Avatar
814
Drives: 09 E92 09 X5
Probably not.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
      05-12-2017, 12:22 AM   #33
chris719
Drives: '08 M Roadster
I did some searching and I found 2 people with this problem that had an F80 M3 and had it fixed with replacement of the swivel bearing(s). I doubt that's the only possible issue, but it worked for a couple people at least when nothing else fixed it.
      05-12-2017, 01:54 PM   #34
fourtitude
Drives: 2017 MT BSM
Same issue here. Took the car into the dealer from my 1200 mile checkup and they adjusted the alignment (wasn't too far out). Still pulling to the right and steering wheel is leaning to the right. Would be interested in hearing if anyone has had any luck getting this resolved.
      05-13-2017, 01:01 PM   #35
mailman411
Drives: MY17 M2
-_- still waiting on the car. Part arrived Thursday and still waiting for them to call me...
      05-16-2017, 01:21 PM   #36
fourtitude
Drives: 2017 MT BSM
Just got back from the dealer and the alignment was within specs. They said it could be related to tire pull and rotated the front tires. It appears to drive better, but I haven't heard of issues with tire pull, especially with only 1400 miles
      05-16-2017, 01:49 PM   #37
David1
David1's Avatar
814
Happens all the time.
      05-23-2017, 06:56 PM   #38
mailman411
Drives: MY17 M2
Bleh... got the car back and still same issue. According to them, it has improved (though I can't tell). Standard answer - it's a performance car and it is normal and within spec.
      05-25-2017, 05:41 PM   #39
matt123
Drives: BMW M3
Press the dealer to get it fixed. The issue also happens on the M3/M4. Tell them to contact BMW NA for assistance. They are finally admitting there is a problem. The more people that complain, the faster the issue will get fixed. I'm going on 2 months without my M3 getting fixed now and I work at a dealership.
      05-26-2017, 05:59 PM   #40
mailman411
Drives: MY17 M2
Supposedly, BMW NA already took a look and that was their answer.
      05-29-2017, 12:11 AM   #41
greasypeanut
Drives: F87
My car had the same pulling to the right issue. After a few visits at the dealership, they eventually replaced the steering knuckle and its all good now.
      05-30-2017, 10:08 AM   #42
twin fed
Doc Brown
twin fed's Avatar
1176
Drives: 2016 MG MT M2
does anyone know what the oem camber specs are?
      05-31-2017, 08:03 AM   #43
twin fed
Doc Brown
twin fed's Avatar
1176
never mind, I got them.
      05-31-2017, 11:27 AM   #44
cbmmm3
Drives: 2010 RX8, 2017 M2, 2020 M2CS
I thought that the pull to right was to offset the left slanting driver seat.
JLX70.50
m2
