03-27-2022, 10:19 PM | #45 | |
Rep 593
I wish there was a tutorial which parameters exactly need to be change to enable anti dazzle lights. |
GotBeemed415.50 |
03-28-2022, 08:34 AM | #46 | |
Rep 432
04-16-2022, 11:11 PM | #47 |
Rep 593
r33_RGSport had remotely enabled anti dazzle on my car, and it works really well on rural roads. Amazing tech.
r33_RGSport12971.00 GotBeemed415.50 |
04-29-2022, 09:19 AM | #48 | |
Rep 2
Laser Lights explained - X6M Competition (2021 G05 in UK)
The best way to describe the difference is comparing them to the hotspot of a high quality flashlight. You can see twice the distance (1km i believe) and there is s distinct hotspot that is cast into the furthest point (usually against a tree or a road sign or something). they are superb, but they are not outstandingly better than the LED standard Headlights. They do look really cool when you opent he car up and the lights all come in in sequence with the DRL's and they have this nice cool blue surround. |
05-01-2022, 10:29 AM | #49 | |
Rep 593
DJXS19800.00 |
05-06-2022, 03:29 AM | #50 |
Rep 2
05-06-2022, 11:19 PM | #51 |
Rep 593
09-23-2023, 02:30 AM | #52 |
146
Rep 337
When anti-dazzle kicks in, does your headlights working in high beam, i.e. the car moves high beam out of a car in front of you? Or it works in low beam mode?
09-23-2023, 06:37 AM | #53 |
Rep 593
You need to have the "auto high beam" activated, so essentially you're driving with low beams and the system activates high beams depending on traffic conditions.
09-23-2023, 12:46 PM | #54 | |
146
Rep 337
My expectation is that the car is always/in most cases use high beam and when there is a traffic - moves one beam away, second switch to low beam (or move it away as well) not to blind. I have LED headlights with anti-dazzle enabled via ProTools app. In your case, how does it work? |
