10-29-2022, 08:32 PM | #89 |
1393
Rep 1,986
I got the front and rear set a couple of weeks ago and am planning on installing it myself in a couple of weeks. Car has about 2.5k miles on it including a 1500 mile road trip so brakes pretty new.
For the front, it seems like its a straight forward swap - i.e. pop out the caliper pin, slide the pads out, slide the new ones in and put the pin back. Anything else? Do I need to put the brakes in service mode somehow? For the rears, is there a full writeup somewhere for the m sport caliper? I've read that some people had some errors with the electronic brake that required a visit to the dealer. Edit: I have bimmercode and bimmerlink if that helps. Thanks
2022 X5 45e : AW/Tartufo
2018 M3 Competition : AW/SO 2016 340i xDrive : AW/CR (sold) |
r33_RGSport12971.00 |
10-29-2022, 09:29 PM | #90 | |
12971
Rep 18,716
Rear wise, since your car only 2500 miles, you don't need to touch the piston at all since it has plenty of room for the new pad to go in. Just make sure that you pump the brake before drive.
11-11-2022, 07:30 AM | #91 | |
Rep 5
I am on the fence between the IS1500's and IS2000's. I am looking to get rid of the school-bus-squeal and dust with minimal to no sacrifice in performance. I know the IS1500's are recommended for the cold temps in the DC area, but I might be wiling to take the chance on limited initial bite for the first few stops when temps are low! |
r33_RGSport12971.00 Xccelerate285.50 |
11-11-2022, 07:43 AM | #92 |
Rep 1,292
I have the IS2000 installed. These are the ones recommended for colder temps (I'm in Canada). I went with the IS2000 for better bite, cold temps and less dust. They are great, no squeal. The dust has been cut down compared to stock about 40%-50% I estimate. If you want even less dust go with the IS1500. however, I can't speak to performance in cold weather on either.
11-11-2022, 01:32 PM | #93 | |
Rep 5
11-24-2022, 09:16 PM | #94 |
Rep 29
@RG Sport noticed the IS1500 (for X5M F95) are not available for order on your site? ETA? How do they compare to IS2000? (I have OCD and obviously hate dust)
11-24-2022, 09:20 PM | #95 | |
12971
Rep 18,716
IS2000 is better for cold climate and still low dust and no squeal. About 10% more dust than IS1500.
11-27-2022, 04:00 AM | #97 |
Rep 192
11-27-2022, 04:32 PM | #98 |
Rep 1,292
No squeaking with the IS2000 pads either
11-28-2022, 01:50 PM | #99 |
3100
Rep 1,822
No squeak squeak on is2000 and have them on 3 M cars.
12-18-2022, 04:15 PM | #100 |
1393
Rep 1,986
Hi, I finally got around to installing the IS1500 on my 45e. Only have about 150 miles since the install but I noticed bite got better during this period. The dust has noticeably reduced as well. Now that it’s colder the initial braking when reversing out of the driveway is accompanied by a loud squeal. Anyone else have this? Does it go away as they get more time to break in?
12-18-2022, 06:23 PM | #101 | |
12971
Rep 18,716
That’s why I recommend IS2000 for guys in extreme cold area. Reversing wise, it is normal. Some stock cars with stock pads also squeal on reverse. It is because all of the brake dust and residue piled up on the rear part of the pad and scrubbed during reverse which cause squeal. Especially on IS1500 under extreme cold.
White3401393.00 |
12-31-2022, 12:43 AM | #102 | |
1393
Rep 1,986
Could it also be that they need anti squeal grease on the back of the pad or need an adhesive like the OEM m sport pads have? I thought the IS500s were just supposed to have lower bite to them when cold - not a horrendous squeal. Hoping something can be done. I will take a video of it tomorrow but def doesn’t seem normal.
12-31-2022, 06:58 AM | #103 | |
12971
Rep 18,716
Brake pad grease always recommended as BMW always recommend to apply brake pad grease. You didn't put some? You install them dry? I believe I mentioned it somewhere that IS1500 may squeal too under extreme cold weather. Maybe you haven't brake them in yet. Squeal only from the rear I assume? Do you have pictures how the pad installed?
12-31-2022, 07:34 AM | #104 | |
1393
Rep 1,986
I ended up taking them somewhere to have them installed because I didn’t have time to diy. I can’t be certain they used brake pad grease. Any way to check without taking the pads off? I also need to figure out if it’s coming from the front or the rear. I will try having my wife listen to it while I reverse. Will get back to you but thx for the fast reply. Regarding temps I wouldn’t consider 50 extreme cold so maybe they didn’t use grease.
01-01-2023, 04:04 PM | #105 | |
Rep 1,041
2024 M2, 2024 CGT4RS, 2020 M2 CS, 2021 Macan GTS, 2017 Cayenne S, 2002 M Coupe |
01-01-2023, 04:06 PM | #106 |
1393
Rep 1,986
The car has a total of 3k miles on it of which we did a 1500 mile road trip (750 miles each way so minimal brake usage). Another thing to note is you don’t really use the brake much on the 45e because it goes into regen mode when you let off the gas.
01-01-2023, 09:34 PM | #107 | |
12971
Rep 18,716
01-01-2023, 09:38 PM | #108 |
1393
Rep 1,986
Here’s a video of the sound. Sounds like it’s coming from the front. I will take the wheel off and snap some pics hopefully tomorrow.
https://youtu.be/efhX2N1CBdY
01-01-2023, 09:58 PM | #109 | |
12971
Rep 18,716
Doesn’t sound normal. Never had that same noise ever. Email me pictures so I can look at it closer. Attaching in the forum won’t help since resolution is resized and I won’t be able to zoom it.
White3401393.00 |
01-01-2023, 10:00 PM | #110 | |
1393
Rep 1,986
