      10-21-2023, 12:02 AM   #1
avito6237
Drives: 2019 BMW X5
Coolant Flush Maintenance schedule
Hello
Can you please share the maintenance schedule for flushing Coolant for 2019 X5 x40i?
Thanks in advance
regards
cdhowell127.50
      10-21-2023, 11:15 AM   #2
slilley
46
Drives: 2023 X5, plus others
Starting in 2005, the BMW coolant became a "Lifetime Fill". BMW doesn't list a coolant flush interval on any of their new cars. I guess the fluid will eventually get changed when the electric water pump and/or the thermostat fails...probably somewhere between 60K and 100K miles. I miss the days when I could simply drain and refill the cooling system on BMWs every 3-4 years.
      10-21-2023, 05:15 PM   #3
eelnoraa
Drives: G05 X5
Don’t worry a light flushing the system. Around 60k-70k miles, the expansion tank or lower radiator hose will crack and leak. All mine did that, and repeatedly did that. You will lost most if not all coolant at that repair. So indirectly, system will be flushed. Life time fluid is life time is the weakest part of the system.
2022 G05 B58/PHEV
+ a few very old BMWs
      10-21-2023, 06:59 PM   #4
gfeiner97
Drives: X540i
4yrs
      10-21-2023, 07:21 PM   #5
eelnoraa
Drives: G05 X5
Even before 2005. I have 2003 E39 and 2004 E46, both have “life time coolant”. Cannot tell when they started.
2022 G05 B58/PHEV
      10-21-2023, 07:23 PM   #6
eelnoraa
Drives: G05 X5
Originally Posted by gfeiner97 View Post
4yrs
I wonder which region is this. Coolant is definitely not in my G05 maintenance schedule
2022 G05 B58/PHEV
      10-22-2023, 08:05 AM   #7
avito6237
Drives: 2019 BMW X5
Thank you everyone for your responses.
