03-20-2024, 08:34 PM | #1 |
Rep 86
Drives: 2024 X5 40i, E63s AMG
Black M Mirror Caps Installed
I purchased a set of M mirror caps off Amazon and installed them tonight. First set (different seller) had to be returned as the finish was awful and they were pretty banged up. These look great and were easy to install.
https://www.amazon.com/dp/B0CKSGZ7FM...t_details&th=1 |
03-20-2024, 10:37 PM | #3 |
Rep 86
Install was fairly easy/straight-forward. Used the included plastic pry tool to release the stock mirror cap, starting from the outer/top side, releasing the top first, then the bottom. Only issue was that I didn't get clips aligned the first time I put on the drivers side and had to remove it and reinstall it (my fault/rushing). Otherwise, took about 10-15 minutes to do both sides. |
03-21-2024, 07:00 AM | #4 |
Rep 1,080
So you did not remove the mirrors?
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (car-show car) |
03-21-2024, 05:38 PM | #5 |
Rep 86
MADBMWX5MC742.50 Mikemann14.50 |
03-21-2024, 05:40 PM | #6 |
Rep 1,080
Thanks...I have heard about both versions, success and failures with both...from craking a mirror to messing up a clip when prying the cap.
04-21-2024, 01:30 PM | #12 |
Rep 86
04-21-2024, 03:44 PM | #14 |
Rep 156
Try this link https://www.amazon.com/dp/B0C7KMZ4J8...ZB&starsLeft=1
Current - 2025 X5 sDrive40i M Sport
Sold - 2023 Rivian R1S Launch Edition Sold - 2018 Range Rover Sport HSE |
04-21-2024, 05:15 PM | #15 | |
Rep 86
Sevn86188.50 |
04-22-2024, 06:53 AM | #16 |
Rep 8,698
Drives: eVeRyOnE mAD!
I also bought and installed these to replace the expensive OEM M Performance carbon fiber caps that delaminated after only 2 years. these are helluva lot cheaper to replace even if I have to do so every 2 years which would take almost 30 years to add up to what I paid for the OEM ones
I preferred to remove the mirrors because it provides direct access to release the caps’ retention tabs. popping/prying them off risks breaking the tabs. ask me how I know… |
04-22-2024, 09:56 AM | #17 | |
Rep 86
nZtiZia4653.50 |
04-22-2024, 06:54 PM | #18 |
Rep 22
Got mine installed a couple of weeks ago and finally had a chance to giver her a bath before picture time.
04-23-2024, 09:03 AM | #19 |
Rep 879
Can you replace the tabs if broken easily? Where do you get replacements?
Make today your best day!
04-23-2024, 02:52 PM | #22 |
Rep 8,698
