04-02-2021, 03:25 PM | #45 | |
Rep 182
aug0211167.50 |
04-15-2021, 03:52 PM | #47 |
Rep 246
Thanks for this informative post! I apologize for the total newb question, but what is the difference between these lowering links and installing new springs?? I'm assuming there is no benefit in handling with these lowering links as there might be with certain springs. I'm trying to figure out what I want to lower my G05 while adding some 15/20 spacers. I don't mind the way it handles with stock suspension, so don't necessarily need an upgraded spring. I see a lot of people mentioning drop in ride height with different driving modes.. does this mean these lowering springs only apply to people with Air Suspension?
lexttu61.00 |
04-20-2021, 11:46 AM | #48 |
Rep 1,241
Standard suspension and/or DHP suspension = Uses traditional coil springs, which require replacement in order to lower the vehicle. Ride height is dependent upon chosen coil springs, and is non-adjustable.
Air suspension = Uses air bags (not coil springs). Ride height is electronically set. Drop links (from this post) "trick" the computer/suspension into "thinking" the car is at normal height. Ride height is adjustable depending upon chosen drive mode. |
05-07-2021, 10:51 AM | #49 |
Rep 96
Passenger side lower than driver side, same link length..
I also used the RGsport Links, i disconnected the sensors, double checked my measurements but for some reason the passenger side is lower than the driver side. I took them off and checked measurements again, they were the same, put them back, reconnected and still passenger is lower than driver. I don't get it. What are your measurements ?
r33_RGSport12969.00 |
05-07-2021, 11:00 AM | #50 | |
12969
Rep 18,715
This air suspension sensor is very sensitive, even 1mm unlevel ground will throw the height about 1/4".
05-07-2021, 11:16 AM | #51 |
Rep 96
Measure what exactly? I'm measuring the link length before installing to make sure the fronts are the same and rears are the same on both sides. It is visibly noticeable when looking at the car from the back that the passenger side is lower.
05-07-2021, 11:26 AM | #52 | |
12969
Rep 18,715
Measure on level ground after driving the car.
buggydrvr13.00 |
05-07-2021, 11:29 AM | #53 |
Rep 96
How far does it need to be driven and any particular speed i need to hit for things to engage/disengage or whatever? I'm confused as to how one side is lower when the link length is the same. It's like the driver side isn't adjusting or something...I'm measuring in my garage which is certainly level.
05-07-2021, 12:09 PM | #54 | |
12969
Rep 18,715
Trust me, unless you really specifically tell the builder to level the ground, your garage ground will never be level. Also, after sometime, ground movement will not make it level. You just need to drive it around the block so the air suspension recalibrate itself. Normal speed.
05-07-2021, 02:55 PM | #55 | |
Rep 96
05-07-2021, 04:22 PM | #56 | ||
12969
Rep 18,715
Or your stock plastic ball is damaged. Hence I recommend to remove from the car to work on it.
05-07-2021, 05:01 PM | #57 |
Rep 96
Thanks again, i figured it out, when i removed the original links, i removed a ball from one end, When i put it back i had the ball facing the wrong direction. Fixed it, all is well! Whew, that was driving me nuts! Thanks again. Note to everyone, make sure if you remove the ball from the stock link, when you put it back on the car, make sure is facing the right direction.
06-07-2021, 12:41 PM | #58 |
Rep 136
06-07-2021, 12:56 PM | #59 |
Rep 136
do you have the link to where you buy the bbm link?
06-07-2021, 01:08 PM | #60 | |
12969
Rep 18,715
You can't correct camber on the front double wishbone system anyway.
08-02-2021, 08:48 AM | #61 |
Rep 177
I bought the RGSport lowering links. The install was pretty easy. Before the install I went ahead and bought 4 new OEM BMW links incase I broke it. So the fronts are the same but they changed the back OEM control rods. The bottom part is not plastic anymore. It’s a metal square that slides into the original location and screws in. The other end has a screw type like the BBM links. It’s easier to remove now rathe than pushing the piece in with a socket to remove and you don’t have to worry about breaking the other end, you just use a 10mm socket to remove it. Also unlike the front piece’s that you pop off with the heat gun, it looks like it’s metal rather than plastic.
08-08-2021, 12:42 PM | #62 |
Rep 1
New here and to the X5 45e. Just did the install of the RG Sport lowering links. Very easy to do following RG instructions. I did had to remove the rear wheels in order to have good access to the area.
I adjusted the links at 24 mm (front) and 16 mm (rear) per RGs recommendations. I just want a 20 mm drop, basically having loading height in Sport height. When I finished the job the rear now is higher than the front. Not level. Not sure why. I started the job at +20 from normal height (to have a bit better clearance) and turn off the system. Also unplug each individual sensor as I worked on them. Everything is pluged in. Any idea what could be wrong or do I have to wait/drive it and the system will reset/level itself? |
08-09-2021, 09:48 PM | #63 | |
12969
Rep 18,715
To let airbag adjust. I bet you did the front first and the rear last. So when you lift the car up, the bag is filled with air (vacuuming air due to the weight of suspension assembly).
08-13-2021, 04:02 PM | #64 |
Rep 136
Did mine today. Without lifting at all. I recommend lifting. Will do that if any adjustment needed.
Hard part was popping the ball out but heat from a lighter worked ok. Also getting the length so precisely even was a challenge but seems to have worked. Will need to make sure they don't vibrate loose later. |
10-12-2021, 12:46 PM | #65 | |
Rep 96
12-13-2021, 11:37 AM | #66 |
Rep 136
hey RG, i just bought the link from you and about to install. I normally just drive comfort and not much in sport mode at all but i do want that sport mode riding height. can i just follow the direction was given in the lowering link package without coding my car to start in sport by default ? i dont drive in sport anyways so im not afraid of dropping it too low by activate sport mode.
