12-13-2021, 06:44 PM | #67 | |
Rep 136
hey RG, i just bought the link from you and about to install. I normally just drive comfort and not much in sport mode at all but i do want that sport mode riding height. can i just follow the direction was given in the lowering link package without coding my car to start in sport by default ? i dont drive in sport anyways so im not afraid of dropping it too low by activate sport mode |
r33_RGSport12971.00 |
12-13-2021, 07:20 PM | #68 | |
12971
Rep 18,715
So, with that, it will start at sport individual with setting Engine - Comfort, Suspension - Sport, and Steering (whichever you pick).
12-13-2021, 09:11 PM | #69 |
Rep 136
I know that. But my question is that can i have my car on comfort mode and then install the link.?? Because in the intruction you sent eith the link i purchased. It stated that to have it in sport mode setting prior to install
12-13-2021, 09:47 PM | #70 | |
12971
Rep 18,715
Forgiven121.50 |
02-12-2022, 02:42 AM | #71 |
Rep 91
Just finished install of RGSPORT drop links on my newly delivered (today) MY22.
Straight home from dealer into my garage for mods With the correct tools and Ben's instructions install was a breeze. Just raised car to highest setting and no need for wheel removal What is the final height everyone is getting on loading after drop link install, from floor to wheel arch |
r33_RGSport12971.00 bmwsone0242.50 |
02-15-2022, 05:18 PM | #72 |
Rep 6
Car looks great!! Been trying to figure something for mine. I have a 22" m50i and every shop i've asked said there are no lowering options for my model. Anyone else having this issue??
02-16-2022, 08:43 AM | #73 | |
Rep 30
Can you provide your measurements in comfort, sport and loading? Also, how much did you shorten/lengthen the end links? |
02-16-2022, 02:21 PM | #74 | |
Sheriff
109
Rep 1,481
thanks
2023 Porsche Spyder, 2024 Porsche Macan GTS, 4Xe Rubicon & 2021 BMW X5 M Package
02-17-2022, 03:23 AM | #75 | ||
Rep 91
Measured on flat ground, bottom of guard to floor Standard mode is approx 800mm Loading mode is approx 760mm |
04-15-2022, 11:03 AM | #77 | |
Rep 10
Question to Ninefourteener
I´ve just intstalled BBM Links, but can´t see any difference in height. did extend with 3mm in front and shortened 2 mm in rear. But the car still has the height as OEM....What did I do wrong...any suggestions. |
05-15-2022, 04:39 PM | #78 | ||
Rep 1,340
05-15-2022, 09:20 PM | #79 |
Rep 1,340
I installed the front BBM links, you dont need to use a car jack (15 minutes per side).
1) Raise the car to the highest setting and lock the car. 2) Disconnect the air suspension's sensor, it is located behind the OEM link. 3) Use a hair dryer/heat gun to make removal of the top part of the OEM link easier. Use a small socket wrench to remove the bottom part of the OEM link. 4) The OEM link is 71mm, measured from center to center of the ball socket. 5) Use the longer BBM link and extend it by 10mm, measured from center to center of the ball socket. This will lower the front 1 inch in all settings (max, elevated, comfort, sport, loading). 6) Make sure the ball sockets of the BBM links have been locked 7) Connect the sensor. 8) Drive the car for a mile. You can adjust the front BBM links without having to remove them in case additional adjustments are required. Always disconnect the sensor before making any adjustments. |
Joph Weud3.00 |
05-16-2022, 08:21 AM | #80 |
Rep 30
2) Disconnect the air suspension's sensor. How do you 'lock the car' and disconnect the air suspension sensor? Thanks! |
05-16-2022, 08:48 AM | #81 | |
Rep 10
Can't understand why 2-3 worked for others, but now solved so why bother 🤗 Don't know how to add pictures, but it looks super! |
05-16-2022, 11:12 AM | #82 |
Rep 1,340
The air suspension's sensor is behind the OEM link, updated the previous post as well.
05-26-2022, 09:26 PM | #83 |
Rep 1,340
My rear BBM link got disconnected, car threw a chassis code, the packaged M6x35mm threaded rods are not long enough. I went ahead and bought a set of M6x50mm threaded rods from Amazon and then used a Dremel to cut them to 42mm.
How do you clear the chassis code? |
Dr. Jekyll209.50 |
07-24-2022, 03:19 PM | #85 |
Rep 3
Hi
Bought my links from baanVelgen and they suggested 6mm longer in front and 6mm shorter in rear, I did 7mm front and rear, the car ended ca 25mm lower. Received chassi error, had to adjust the rear links 1 turn longer on the treads. So I think the rear is about 5mm, the car ended up perfect low and nice. |
Afjeld1008.00 |
07-27-2022, 02:19 PM | #86 |
Rep 19
Hi guys. New to BMW here and was wondering if these lowering links are specifically for the X5 45e with the air suspension?
I read through this thread and it appears there are several different factory suspension settings (5?). I briefly looked at an X5 and the salesman reached in and hit a button on the dash while standing outside of the X5 and it dropped about two inches. Is that the lowest factory setting or can it go lower for getting in and out of the vehicle easily. Thanks. |
07-27-2022, 02:26 PM | #87 | |
Rep 8,694
Drives: eVeRyOnE mAD!
the 45e does have a LOAD level, but know that going too low with links will trigger a chassis error |
