      04-15-2022, 11:52 PM   #23
ae31744
Drives: 2019 X5 xLine
One question I have about running these tires with a larger sidewall is wouldn't you no longer be able to use the spare tire? Shouldn't the spare be less than 5% difference in diameter? All these sizes put it out of that range I believe.
      04-16-2022, 02:55 PM   #24
chayden2005
chayden2005's Avatar
Drives: X5 45e
2022 BMW X5 45e  [0.00]
Here's a basic reason to limit the time you run on a spare that isn't considered full size, in relation to your installed tires:
"The amount of power the internal computer sends to each wheel—based on what your AWD vehicle needs to go down the road—helps to manage how hard the transmission and transfer case are working. Inconsistent outside diameters caused by different tire sizes, tread patterns, or tread depths can force an AWD computer's readings to fluctuate, and various wheels will receive inefficient or incorrect power loads. As a result, the drivetrain (computer, transmission and transfer case) must constantly readjust, doing more work than necessary and eventually, may break down."
      04-16-2022, 06:48 PM   #25
ae31744
Okay - so even running 275/45R21 all around you would be okay using the Modern Spare which is 155/85R18 (7.5% smaller) to get to a shop if you got a flat?
      03-19-2024, 05:41 PM   #26
JoeAyalaM
JoeAyalaM's Avatar
Mexico
146
Drives: 2024 BMWX5 M60i / Audi S6 V8TT
Since the spare tire use is minimal, yes it should be fine because the four main tires diameter is the same.
