01-13-2024, 03:00 PM | #1 |
Rep 10
Who makes the widest 315s for or rides?
We currently have 22 inch Continentals. I like the wide look and don’t necessarily want to go wider but for sure not less wide. Do the common dealer tires for these X’s look the same? My 2019 had 21 inch 315 Perellis but they didn't look as wide as what we have now.
01-13-2024, 03:11 PM | #2 |
Rep 2,824
Tires of the same specified width (315) but of a different model or manufacturer will be slightly different in actual width. You can look up the available 315/30/22s on Tire Rack and compare the measured/section width between the options (which can vary further based on rim width, but for this comparison I suspect they're all specified on the same wheel size). Some run narrow, some run wide.
01-13-2024, 03:32 PM | #3 |
Rep 3,681
I would think the variation in actual width will be small. After all, the contact patch is the same. Cannot make the actual side wall much wider, right?
2022 G05 B58/PHEV
+ a few very old BMWs |
01-13-2024, 03:37 PM | #4 |
13275
Rep 19,805
I think you are referring to tread width. The tire width is from outside of sidewall to outside of the other sidewall so the contact patch can vary. As you said though, the variation will be very small, I have seen no more than 3% mentioned for the width.
01-13-2024, 06:07 PM | #5 | |
Rep 965
And don't even get me started on the meat Ingles number that is the tread wear rating, lol. |
01-13-2024, 06:09 PM | #6 | |
13275
Rep 19,805
aussieintexas220.50 |
01-13-2024, 06:15 PM | #7 |
Rep 965
Because when you're making cheater tires the section width is a "guideline" more than a requirement, lol. I don't know how they convince themselves they made a tire of that size, but look up with width of a BFG or Goodyear tire and compare it to the width of a Nitto of the same size... Major differences, especially in wide tires like on the back of a Corvette.
01-13-2024, 06:18 PM | #8 | |
13275
Rep 19,805
01-13-2024, 08:13 PM | #9 | |
Rep 965
These two tires are both the same spec "size", but clearly not the same actual size. |
01-13-2024, 08:15 PM | #10 | |
13275
Rep 19,805
"Section width is the measurement from inner sidewall to outer sidewall when properly mounted, inflated, and without vehicle load. The measurement is in millimeters and doesn’t include ornamentation molded into the sidewall such as the lettering, protective ribs, and similar extensions that aren’t part of the structural sidewall." "Measuring the section width of your tire requires beginning with it mounted onto an appropriately sized wheel with the correct wheel diameter and rim width for the tire being measured. The tire must be inflated to the proper air pressure but not mounted onto a car or truck for measurement. Measurement is performed using a tool that can properly span the entire width of the tire and accurately contact the widest point on each sidewall. Official measurements are performed with the tire mounted to an industry assigned measuring rim." https://tiregrades.com/tire-anatomy/...dth-on-a-tire/
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50 Last edited by TurtleBoy; 01-13-2024 at 08:21 PM.. |
01-13-2024, 08:43 PM | #11 |
Rep 965
I get it (but apparently not how to add images). One is a Goodyear (on the right), the other a Toyo(on the left). Both 315s.
Like I said, I dunno how they convince themselves they're both 315s, but they are. |
01-13-2024, 08:59 PM | #12 |
13275
Rep 19,805
It is not worth our time discussing it but there is something else going on. There is no way a manufacture is going to take the chance of running afoul of federal /NHTSA regulations and not put the correct information on the tires. 571.139 defines Section Width as the linear distance between the exteriors of the sidewalls of an inflated tire, excluding elevations due to labeling, decoration, or protective bands and that is a required time to be on the tires.
01-13-2024, 09:10 PM | #13 |
Rep 56
It's the same as shoes: why do different manufacturers size 11's fit different?
There is for sure a difference in width between 'same' sized tires, it's not debatable. Tire rack and other respected sellers talk about it, and state the differences. Also a summer tire may be wider than the a/s tire of the same size from the same manufacturer. |
01-13-2024, 09:14 PM | #14 | |
Rep 3,681
One observation. Tires pictures in this link https://tiregrades.com/tire-anatomy/...dth-on-a-tire/ Are they even DOT tires?? My guess is the right one isn’t DOt approved. It is for recreational use only, in this case, track or drag strip tires. When it isn’t dot approved, yeah spec has very little meaning.
2022 G05 B58/PHEV
01-13-2024, 09:36 PM | #15 | |
Rep 965
These are street legal for reference. |
01-13-2024, 09:37 PM | #16 | |
13275
Rep 19,805
