03-24-2024, 01:36 PM | #1 |
Rep 105
BMW Ace 3.0 Pro install on 2021 X5M Comp
Hi all,
I have not seen much around about to getting this installed the way that the dealership describes in the installation guide, which I tried but had difficulties and it is not fully reversible anyway, which I am not a fan of. Wanted to share my alternate install in case that someone is interested in routing to the back and installing to the rear fuse box, which is highly accessible and does not require major modifications. I used the following: 1) Thinkware mini battery pack (it fits like a glove in the back) 2) Ace 3.0 Pro camera 3) Additional 20 gauge wire because the hardwiring kit that comes with the battery is not long enough. Steps: 1) I installed the cameras in the same fashion as the dealer would 2) route all the wires to the back as dealer mentioned 3) remove battery cover, rear fuse cover and a few pins in the left liner to run wires under it 4) installed fuse tap into 205 with a 20 amp fuse. This fuse location is ACC with no delay. Used the ground located nearby below the fuse box 5) routed the camera power input cables behind the seat and under the rear lower liner 6) made 2 cuts on the liner (one for power input and one for power output). This is the only non-reversible part, but I rather replace this than the wiring harness if something goes wrong 7) out some adhesive Velcro (the rough part) under the battery and placed it on top of the liner. It will stick to the liner 8) installed the wires to the battery 9) reconnected battery Now you have the same setup but with an external battery and without worrying that you will be compromising other components. I am attaching pics below. Hope this helps. It took me 2 weekends to figure all out and route all the wires. With all this, it will likely take you less than 3 hours if you are skilled enough. I think some models require some programming. So, check with your dealer. But this saved me over $1,000 and the BMW guidelines say 2 hours shop time (some dealers are something else) |
03-24-2024, 07:03 PM | #2 |
Rep 63
Drives: 2024 X5MC Frozen Pure Grey
Thankfully, mine came factory installed. Mine doesn't have that box you placed in the tire well. I wonder if it's located somewhere else.
03-24-2024, 07:13 PM | #3 |
Rep 105
Definitely not. Fun install but mostly for the lack of detailed instructions out there. The dealership, because I think that is probably a dealer installed accessory and not installed from the factory, installs it in a very peculiar way. They just connect to the fuse box ACC and positive terminal. When the car’s battery voltage gets to a certain low threshold, it turns off. With my install, with the black battery, I get about 17 hours plus the additional the car’s battery uses. I like my install better simply because you only tap into one place and ground and get more recording time. But I would have chosen getting it with my build if it had been an option. It has been sitting in my garage for over a year waiting to get installed 😂
03-24-2024, 08:02 PM | #4 |
Rep 802
Pretty slick install! Did you manage to tuck the wires under the headliner? When I installed my dashcam the headliner seemed glued and would budge. I had to settle for running alongside it.
Current: MB 21 X5 M Comp | '20 Z4 M40i
Past: 09 M3 Coupe DCT (sold) | 11 1M Coupe MT (sold) | 15 i3 REX (returned) | 15 X3 35xi (sold) | 16 M235xi Vert (returned) | 18 M3 Comp Ultimate DCT (sold) | MW 20 X5 M Comp (totalled) |
03-25-2024, 03:14 AM | #5 | |
Rep 63
03-25-2024, 07:29 AM | #6 |
Rep 105
By the windshield? That one needs a prying tool to lightly pry it and another one to push the cable in. When I was getting the cable for the rear camera, I did feel like I had to be careful as I have to pull it down some to find the hole to fish the wire through to the tailgate.
-cj-201.00 |
03-25-2024, 07:35 AM | #7 | |
Rep 105
