      01-10-2019, 08:31 PM   #45
MystroX5
MystroX5's Avatar
6290
Drives: 2020 X7 M50i/ 911
Originally Posted by cygnusecks View Post
No joy - even in a location where my phone says I have a strong cellular signal - as soon as I shut off cellular on the phone and use WiFi to connect to the car hotspot, I can't load the AT&T website at all..
Try updating the apps again and do a 40msec restart of iDrive. Ie above instructions.
      01-12-2019, 09:55 AM   #46
bimmerstyler
Drives: 2019 X5 G05
Nice dice for me. I have a genius appointment to run through the newest features of the car today anyways so I'll bring it up.
2019 X5 M Sport G05 Phytonic Blue
      01-12-2019, 01:09 PM   #47
cygnusecks
cygnusecks's Avatar
Drives: X5 (G05)
Good luck, let us know what they say. Yesterday, when I took my car in for another issue (seat leather on driver's seat detached), My "genius" said it's still not supposed to be working due to AT&T and filed a trouble ticket with BMW.
      01-12-2019, 01:11 PM   #48
bimmerstyler
Drives: 2019 X5 G05
Just left. We tried bunch of steps to get it to activate, but same outcome. I'm sure this will shake loose in the coming weeks if some are having luck now.
      01-12-2019, 04:17 PM   #49
mnewnam
270
Drives: '21 Mineral White X5MC
I was finally able to try once I got back from CES. The process worked. I did notice that the phone number of the vehicle is completely different than it was before the fix.
      01-12-2019, 07:16 PM   #50
bimmerstyler
Drives: 2019 X5 G05
Ok. I'll focus on activating through the phone connected to the car going forward.
      01-12-2019, 07:22 PM   #51
MystroX5
MystroX5's Avatar
6290
Make sure the phone or even iPad is connected to the car via the WiFi. Bluetooth won’t work. Once the phone is on the cars internal WiFi, you can go to the att site and register there.
      01-12-2019, 07:56 PM   #52
bimmerstyler
Drives: 2019 X5 G05
I'm thinking the cell in the car is still dead. On the WiFi it's not allowing myvehicle.att.com or rerouting any page request there.
      01-12-2019, 08:50 PM   #53
MystroX5
MystroX5's Avatar
6290
I could always connect to my X5’s WiFi before I could register.
      01-12-2019, 08:53 PM   #54
bimmerstyler
Drives: 2019 X5 G05
I can connect any device to it. Getting a page in the browser to go through the sign up process is what won't load. It was still a dead hot spot connection this morning.
      01-12-2019, 09:20 PM   #55
MystroX5
MystroX5's Avatar
6290
That was my issue last week. If you call att they probably can help now. Before they couldn’t do anything. BMW released our access numbers for 2019 vehicles only a few days ago to att. That was what changed for me. My vehicle’s number changed anyway after registration.
      01-12-2019, 09:21 PM   #56
bimmerstyler
Drives: 2019 X5 G05
Ok awesome. I'll give that a shot too. Thanks for the info.
      01-12-2019, 09:56 PM   #57
bimmerstyler
Drives: 2019 X5 G05
The plot thickens with my hotspot. AT&T doesn't have a record of my hot spot number or the vehicle VIN so this has to go back to BMW to fix according to them. I have to talk to BMW Genius when they get back in on Monday.
      01-12-2019, 10:48 PM   #58
skalberti
skalberti's Avatar
Drives: 2017 Mineral White M3
How do you find out what your cars hotspot number is?
It's good to be bad
      01-12-2019, 10:52 PM   #59
MystroX5
MystroX5's Avatar
6290
That has been the norm for most all of us.
BMW released info out to Att a few days ago. Follow the instructions from above by resetting apps and restart iDrive. You will appear and be able to register via in your vehicle to att.
This should be a sticky
Do this:
Start from the Home Menu and select "Apps".
- Select the vertical menu bar on the left edge of the screen.
- Select the "Options" button located near the iDrive controller.
- Select "Update Apps and Services" and wait for the data transfer to complete before pressing OK
Once this update is completed, please press and hold the volume knob on your dashboard for approximately 30-40 seconds to restart the iDrive system. You may now shut down the vehicle and attempt to sign up for Wi-Fi services at myvehicle.att.com.
      01-12-2019, 10:57 PM   #60
mnewnam
270
That was my issue last week. If you call att they probably can help now. Before they couldn't do anything. BMW released our access numbers for 2019 vehicles only a few days ago to att. That was what changed for me. My vehicle's number changed anyway after registration.
It's on the ConnectedDrive website under the vehicle. There's a link on the right that says something like my vehicle phone number. You can use this to sign up via your computer.
      01-12-2019, 11:00 PM   #61
MystroX5
MystroX5's Avatar
6290
That number is wrong and if you register via in your car, it doesn’t require the cars phone number. You must register in your car through it’s wifi hotspot to ATT. It transfers your correct data directly from the car to Att. It’s the only way I believe 2019 models have successfully registered.
      01-12-2019, 11:06 PM   #62
mnewnam
270
That number is wrong and if you register via in your car, it doesn't require the cars phone number. You must register in your car through it's wifi hotspot to ATT. It transfers your correct data directly from the car to Att. It's the only way I believe 2019 models have successfully registered.
I registered using that number on the website outside the car... they told me it will work either way. The number under the website was completely different than it was before they fixed it. It didn't work before, but did now with the new number.
MystroX56289.50
      01-12-2019, 11:13 PM   #63
MystroX5
MystroX5's Avatar
6290
That’s great. It looks like BMW data transfer is working.
mnewnam269.50
      01-12-2019, 11:51 PM   #64
skalberti
skalberti's Avatar
I was told my vehicle is incompatible after going through the OP's steps then putting the vehicle phone number in.
It's good to be bad
      01-13-2019, 02:24 AM   #65
mnewnam
270
I would reach out to BMW Genius team. They will be able to help.
      01-13-2019, 11:33 AM   #66
LAMF
LAMF's Avatar
Drives: X4MC
2020 X4MC  [0.00]
I have WiFi setup with a password, is that the same as the HotSpot. I never signed up with AT&T. Any input is much appreciated.
