      05-06-2019, 04:47 PM   #89
bo0tn1c
Drives: BMW F30 M Sport
Originally Posted by Almaretto View Post
Launcher Pro does not have MGU mapping. E-sysX I hear does, but never used myself.
Ah okay makes sense. Only wanted to access the MGU for vim using the known method for evos rather than using a patch solution.
Can you please share what features can be coded and their parameters?
      05-06-2019, 08:07 PM   #90
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
It depends on which solution you are using.
No, I do not have list of parameters. I use my own Launcher Cheat Codes.
      05-16-2019, 03:19 PM   #91
qocerhuang
Drives: BMW X5 2019 50i
Any update from you guys, pick up mine next week.
      05-17-2019, 04:31 PM   #92
jav418
Drives: BMW X5
2019 BMW X5  [0.00]
Hey guys not trying to hijack thread. I can't connect to the vehicle using the INPA tools I have it downloaded and installed on my laptop with a ethernet OBD 2 cable, would anyone be open to helping me out? thanks and sorry if this isn't allowed.
      05-17-2019, 04:54 PM   #93
Almaretto
Almaretto's Avatar
2374
I do not think INPA supports G05, but never tried.
      05-23-2019, 09:57 AM   #94
Badix89
Drives: BMW X5 G05
Anything new coding with the G05? There are already some options for coding?
      05-23-2019, 09:10 PM   #95
Almaretto
Almaretto's Avatar
2374
I have not seen anything new. Most of the same that for for F15 also do on G05.
      05-24-2019, 10:07 AM   #96
hk5er
97
Drives: I20 iX xDrive40i
Just got my car back from dealer. I found out that my car was updated with integration level S18A-19-03-548.
Not sure what that means but can someone help me to activate CarPlay? My iDrive doesn't tell me what version of software I have.
My dealer tried to update my navigation map but somehow ended up breaking the headunit. So will have to wait for a replacement unit (part # 65128778989) from BMW AG. In the meantime, my navigation system is broken.
Any help will be appreciated. Thanks!
      05-24-2019, 11:44 AM   #97
Fsune1
Drives: 2019 X5 50i
Has anyone been able to code video in motion? I'm using Bimmercode but they still don't have this option available!!
      05-24-2019, 11:53 AM   #98
Badix89
Drives: BMW X5 G05
Almaretto, is it possible to code that the adaptive drive mode is always active instead of comfort?
      05-24-2019, 02:24 PM   #99
Almaretto
Almaretto's Avatar
2374
Those are just software version designations.
Yes, VIM works with E-sys.
Yes. You can change default to whatever mode you desire.
      05-24-2019, 10:48 PM   #100
Badix89
Drives: BMW X5 G05
Ok thank you
      06-07-2019, 01:00 PM   #101
smg058
Drives: 2019 BMW X5 50i - Carbon Blk
Any new information on coding VLD on the G05 with the laser-light option?
2019 BMW X5 xDrive50i M Sport - Carbon Black/Black
      06-11-2019, 09:13 PM   #102
aman27
Drives: 2016 F15 x35i MSport
Whats VLD on laser light option ?
      06-11-2019, 10:07 PM   #103
russelldav
456bhp for breakfast
russelldav's Avatar
425
Drives: 2019 X5 50i
VLD is Variable Light Distribution - It only works on your low beams to move your headlights and position the beams on the road depending on steering angle and vehicle speed.
HBA is High Beam Assistant - USA/Canada spec high beams that turn off in the presence of headlights or taillights of other cars and automatically turns the high beams on if no other cars are present.
Anti-Glare, Anti-Dazzle - European spec high beams that enable your car to keep the high beams on without blinding other cars.
      06-29-2019, 01:39 PM   #104
russelldav
russelldav's Avatar
425
Drives: 2019 X5 50i
I've been unable to code the Tailgate module using Bimmercode. Tried a few times now and this is the error message I get. I can code the other modules without any error. Any idea what I might be doing wrong?
      06-29-2019, 05:53 PM   #105
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
Is that the Android version? Over BT? Which interface?
My experience is with iOS latest on iPhone 8 over BT and ODBLink MX+ interface. Worked fine for tailgate coding. Do have to follow Bimmercode instructions carefully — disconnect from all other BT devices on your phone before coding.
      06-29-2019, 06:15 PM   #106
russelldav
russelldav's Avatar
425
Drives: 2019 X5 50i
I have a UniCarSys adapter using the iOS version of the app. I'll try again with airplane mode on.
      07-01-2019, 04:56 AM   #107
russelldav
russelldav's Avatar
425
Drives: 2019 X5 50i
FYI
      07-01-2019, 01:50 PM   #108
phzi
Drives: BMW X3 F25
Is it possible to add Turn Signals to the HUD with ESYS?
Thinking about getting a G05 and turn signals in the HUD are a must IMO.
      07-01-2019, 08:05 PM   #109
Almaretto
Almaretto's Avatar
2374
HUD turnsignals does not work on any car with digital instrument cluster. So, will not work on G05.
      07-01-2019, 11:53 PM   #110
X5G05SYD
Australia
Drives: X5 2019 M SPORTS, M PER
Anyone been able to code the rear tail lights to be on as rear DRLS lights on with Front DRLs ?
Cheers
J.
Tags
2019, bluetooth, carplay, coding, display, g05, laser, obd, obdii, remote
