      07-26-2019, 11:37 AM   #67
eagle_bmw
Drives: 2019 BMW X5 40i
Thanks skalberti for sharing this. My dr900s-2ch is arriving today and will be installing tomorrow. I have both PMP and battery pack (more cost effective in my purchase) and will explore both.
2019 X5 40i M-Sport
07/2020.54 -> 11/2020.50 -> 03/2021.50 -> 07/2021.85 [All OTAs]
skalberti614.00
      08-01-2019, 01:36 AM   #68
eagle_bmw
I finally installed my 900s-2ch. I used the fuse box in the cargo area as it was a lot easier to access. I didn't use the external battery pack because of the 10 min delay for all the switched fuses. With at least 9A draw from the battery pack I'm worried that it may drain the battery during that 10 min delay. I wish it would only start charging when it drop to 80% or so.
Used PMP instead with tailgate fuse for constant power and cigarette lighter fuse for acc (again, 10 min delay to off).
I'm having trouble, though, putting the weather stripping back by the B pillar corner because the cam wires would not go in completely between the headliner and the center vertical panel. How did you guys route the wires here, did you go by the headliner as well (crossing b pillar)?
2019 X5 40i M-Sport
      08-12-2019, 05:05 PM   #69
skalberti
skalberti's Avatar
Drives: 2017 Mineral White M3
Leaving the B pillar in place, pull the weather stripping down before and after the B pillar, take a wire grabber and push the. Cam cable through the gap between the b Pillar and metal body. Then just push the weather stripping back into place.
It's good to be bad
eagle_bmw182.50
      08-12-2019, 05:45 PM   #70
eagle_bmw
Thanks again skalberti ! That's exactly what I figured should be done and had to reroute the cables. I followed most of your write ups in the OP and responses. Very helpful posts! All clean now.
I ended up installing the B-124 battery pack and didn't have any issue so far. The 10 minute delay is very short to significantly drain the battery. By my rough calculation the PMP/camera should consume more power in 12 hours than with the battery pack.
One mistake but got corrected in software is the rear camera's orientation.
Some photos to share:
2019 X5 40i M-Sport
      08-12-2019, 05:49 PM   #71
skalberti
skalberti's Avatar
You can flip the orientation of the cameras in the app settings. Mine runs off the car battery for 12 hours while I'm at work. Never have any issues with the battery being discharged. Your Install looks good!
It's good to be bad
      08-12-2019, 06:18 PM   #72
eagle_bmw
Yup, I was about to remove the rear panels again but thought there must be an orientation setting.
That wire grabber from Amazon!
2019 X5 40i M-Sport
      08-13-2019, 12:23 AM   #73
bichoo
bichoo's Avatar
281
Drives: BMW X5 40i M-Sport
Which blendmount product number did you order? They list 3 different types for the G05.
thanks
2019 BMW X5 40i Phytonic Blue/Tartufo
2016 BMW X3 35i M-Sport, Dinantronics (sold)
2012 BMW X3 28i (sold)
      08-13-2019, 07:27 AM   #74
eagle_bmw
thanks
Specialty Series, BBV-2918. I just matched the mirror mount in my car which has the same curvature as BMW-016. I've seen others used different series.
2019 X5 40i M-Sport
      08-13-2019, 07:50 AM   #75
skalberti
skalberti's Avatar
thanks
I used the BBV 2030
It's good to be bad
bichoo280.50
      08-13-2019, 08:46 AM   #76
ShiNobi_511
Drives: 2019 BMW X5
Hi, does the positioning of the camera where you have it effect the sensor for drive assist?
      08-13-2019, 06:48 PM   #77
eagle_bmw
No issue with mine and I used driving assist for most of my ~2700 mile trip last week. I followed the use of mounts in this thread instead of the double sided tape to attach the camera to the mirror. The dashcam is far from blocking any sensor/camera.
2019 X5 40i M-Sport
      08-14-2019, 01:14 PM   #78
ShiNobi_511
Drives: 2019 BMW X5
Awesome, thanks!
      08-18-2019, 06:56 PM   #79
ShiNobi_511
Drives: 2019 BMW X5
May I ask which fuse did you tap into in the rear fuse box for the blackvue battery?
      08-18-2019, 07:30 PM   #80
eagle_bmw
Sure, I used the switched fuse for the cigarette lighter. To be sure you tap to the right fuse# download the fuse map for your car/VIN from here:
https://www.bmw.ie/en/topics/owners/...xsYmFjay5odG1s
2019 X5 40i M-Sport
      08-18-2019, 08:09 PM   #81
ShiNobi_511
Drives: 2019 BMW X5
Thanks, weird there seem to doesn't be one online for my car
      08-18-2019, 08:39 PM   #82
eagle_bmw
Okay, the cigarette lighter fuse that I used is F218 which is consistent with this link that I bookmarked, from another helpful member of this forum.
https://www.newtis.info/tisv2/a/en/g...box/1VncvSrfBj
2019 X5 40i M-Sport
      08-18-2019, 08:50 PM   #83
ShiNobi_511
Drives: 2019 BMW X5
Thanks!
      08-18-2019, 09:26 PM   #84
eagle_bmw
Also in mine, looking directly at the fuse box, the line/12V is on the right side of the fuse and the load is left side (can check by removing the fuse and checking both sides with a voltmeter). If connecting directly without an adapter you would want to connect to the load side so the original fuse can protect the circuit. If using add-a-fuse adapter (recommended) the common line should be connected to the line side. The original circuit would be unchanged and protected by the original fuse and the dashcam will have protection via the new fuse.
2019 X5 40i M-Sport
      08-19-2019, 01:29 PM   #85
ShiNobi_511
Drives: 2019 BMW X5
Thanks! i actually tried F218 with a add-a-fuse adapter but that didn't do it. I'm going to try again later today with the info you'd just provided.
      09-06-2019, 01:56 PM   #86
radmjk
radmjk's Avatar
241
Drives: 2024 X5 M60i, 2020 RRS SE, 201
Did you end up having any luck?
By the way, do you or anyone else have any zoomed out photos of the passenger foot well fuse compartment? I'm looking to access it but not exactly sure what I need to start removing to gain access.
Thanks!
RADMJK
2024 BMW X5 M60i Brooklyn Gray Metallic
2020 Range Rover Sport SE White
2017 BMW 530i xDrive Black
2005 BMW Z4 2.5i Jet Black
      09-06-2019, 07:25 PM   #87
eagle_bmw
Thanks!
You may want to read the whole thread, but I followed skalberti post:
https://www.bimmerpost.com/forums/sh...php?p=24462525
I see you have m sport. The threshold plate has electrical connection to the /// light so be careful when you remove the plate.
I wasn't able to take photos but access to the front fuse box is really tight. I needed to install a battery pack so had to change my plan and used the cargo fuse box instead. It is a lot easier to access and fits the battery pack. Of course I had to route both camera wires (front and back) to the fuse box.
2019 X5 40i M-Sport
      09-12-2019, 07:05 PM   #88
StrykerRan
StrykerRan's Avatar
15
Drives: BMW X5 40i
Originally Posted by Xeno View Post
It is stormy today and difficult to get good pictures, but here is my current install. I will test this and see if using the BM would be an advantage for me.
Hi, do you know if the the R7 can be hooked up using "mirror tap" to the X5?
For example, something like this: https://www.amazon.com/gp/product/B0...JE1FY0AH&psc=1
Great hook up btw. Very sleek.
