      01-03-2022, 02:44 AM   #133
Bambazonke
Bambazonke's Avatar
Australia
210
Drives: 2017 X5 & 2020 X5
  [0.00]
Originally Posted by The-Traveler View Post
Anyone still have that spreadsheet? I'm trying to get this working on a 2018 G30 running ID6, with 5AT and all other required features.
Need ID7 & 5AU
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive
      06-06-2022, 04:37 PM   #134
Vorda
Drives: G05 45e
Originally Posted by ifr View Post
ETJA doesn't work for eu vehicles. No fix possible
Happen to still have that spreadsheet (or other reference work)?
Have a G05 MY20 (fully updated by dealer last month) with 5AU and I'd like to enable SWA and TLA. With Belgian traffic jams I'd kill for ETJA..
      06-12-2022, 11:41 PM   #135
watrob
watrob's Avatar
Australia
140
Drives: MY2022 X5 M-Sport 45e White
I had the boys for "Code My Bimmer" do all the code changes I needed. Took them 25 mins remotely and it was done. Steve did a great job and for $99 felt it was great value.
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked.
      07-15-2022, 03:56 AM   #136
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
Until your next OTA update Do yourself a favour and get Bimmer Utility for US$99 and a Enet cable for $25 If you need some help I am just up the Bruce and on the same time zone LOL
      07-28-2022, 09:55 AM   #137
rulppa
Drives: G05 45e
Originally Posted by perikifi View Post
After a lot of reading and some trial and error, I got Esys+EsysX working and was able check the aSLA settings on my MY20 October 2019 build Euro 45e with 07/2019.59 factory software.
All the other listed keys had the correct values, only the six *_Land_Aktiv keys had non-0xFFFFFFFF values, keeping me from using aSLA, as one of the 0 bits is for Finland (or Nordic or something else). Note that I have been able to select aSLA in iDrive since start but it has produced a 'This feature is not supported in your country' message and later warnings every time you activate adaptive driving.
Having coded all six land keys to 0xFFFFFFFF I am able to set SLA as Adjust automatically, as well as check on Adapt to route, without any messages. So everything is great, but due to this weekend's schedule I will not be fully field testing this before Monday.
Another Finn here, sorry for quoting old post but just trying to figure this out and confirm. By six land-codes, does this look like a winning ticket here -> ?
SAS2/42C1
C_SLA_aSLA_Land_Aktiv - 0xFFFFFFFF
C_SLA_Vorausschau_Land_Aktiv - 0xFFFFFFFF
C_SLA_Streckenregelung_Land_Aktiv - 0xFFFFFFFF
DSC_VIP/3D14
      07-28-2022, 08:43 PM   #138
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
SAS2/42C1
DSC_VIP/3D14
The current land mask settings in your X5 exclude Finland. Not sure how BMW geo masks countries for features but I assume either by the onboard GPS or by the mobile network or even basic telephone country coding!. Would be helpful to find how they do it.
The land mask values listed above are in hex code and as such the following setting (FF,FF,FF,FF) is set to the maximum hex value (FF) so as to include ALL regions that do NOT have aSLA enabled. I use the same values here in Australia as does some owners in the US/Canada who have coded aSLA to work in their BMW's
marcosg24.50
      12-07-2022, 01:20 PM   #139
The-Traveler
Drives: E92 M3 & G30 530e
Originally Posted by VTENGR View Post
Would it be possible to repost this cheat sheet? Link is dead.
Can we please repost this sheet, pretty please!
      12-10-2022, 07:02 PM   #140
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
07/2022.58 updates are now happening worldwide. I have taken IFR's Excel sheet plus other coding tweaks and created an XML cheat sheet for the X5 that works with Bimmer Utility and Launcher Pro for those that have lost all their coding from doing OTA updates
You will probably have to join the group to access the file
File availiable at
https://www.facebook.com/groups/1573...74/files/files[IMG][/IMG]
      12-11-2022, 08:00 PM   #141
roxxor
roxxor's Avatar
1141
Drives: 2024 iX50
I appreciate the cheat sheet! I was able to piece together and enable pretty much all aSLA/TLA/UCC options, except even with coding all the values to FF, the Form Emergency Lane Option still says Not Available In This Country (US).
      12-13-2022, 05:18 AM   #142
PaoloV
Drives: BMW x5 Xdrive 40i
Originally Posted by Bambazonke View Post
07/2022.58 updates are now happening worldwide. I have taken IFR's Excel sheet plus other coding tweaks and created an XML cheat sheet for the X5 that works with Bimmer Utility for those that have lost all their coding from doing OTA updates
File availiable at
You can indicate the name of the group please. From the Link I can not enter . Thank you
      12-13-2022, 06:07 AM   #143
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
The feature doesn't work here in Australia as well. It is dependent on the map database containing the road type that supports the function the same applies to TLA where the map database needs to have the Traffic light location data in it for TLA to work
      12-18-2022, 03:27 PM   #144
AndreiBes
Drives: BMW F20 120i 2019
Hello, I have upgraded to the latest OTA and now I'm getting this error when I try to read any ECU:
```CAFD_0000211B_003_011_013 Fehler:
CPS read from ECU "ECUId:VDP_0x76" failed! [C070]
openECUConnection for link VDP_76_ETHERNET failed with error MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name VDP_76_ETHERNET doesn't map to an item [1694]
Is it cause the mapping is not ready for yet for the BU right?
      12-18-2022, 10:07 PM   #145
The-Traveler
Link doesn’t work still
      01-02-2023, 05:17 PM   #146
mjkasper
15
Drives: BMW X5 45e
Why does it seem nearly impossible to find/download the latest PsdZData files and cheat code XML files for BimmerUtility? I'm particularly interested in those for a G05 (2023 X5 45e).
Does anyone know where I can find these files?
      01-02-2023, 06:06 PM   #147
medphysdave
medphysdave's Avatar
Drives: M2 CS | 85 of 592
Head over to bimmerfest for the psdzdata files lite or full.
      03-17-2023, 11:02 AM   #148
KVD-NL-BMW
KVD-NL-BMW's Avatar
Netherlands
Drives: BMW 218 Gran Coupe F44 M-Sport
I have coded it in my Dutch BMW 2 Gran Coupe, that has no SAS as intended (5AS + 5DF + 5DM + 5AQ + 8TF), but the DSC_VIP accepts all the codes and it (auto speed limit) seemed to work for a minute. But after 100 meters it indicated "not active in your country"
- Are you trying to say that by coding "FF,FF,FF,FF" in all te masks we actually disable the automatic function? I'm in the Netherlands, Europe.
(Having no SAS is correct in this model with this FA as intended by factory build BMW)
      03-17-2023, 09:57 PM   #149
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
No by maxing out the hex code to FF FF FF FF you are enabling the mask range to the maximum value to include all areas so the function will work in any country/region providing BMW are using this method to select which countries they want or allowed to enable it.
Other features like TLA are controlled by some other method like geo fencing or cloud enabled? like the inbuilt dash available for those that have 360 surround camera option
      03-19-2023, 08:06 AM   #150
KVD-NL-BMW
KVD-NL-BMW's Avatar
Netherlands
Thank you that is also what I assumed:
- It could be geofencing that does not allow Auto-speed-limit my country althoug I have code "FF,FF,FF,FF"
I'm wondering if anyone already found a way to prevent the geofencing? I will have a look into my ECU's and coding with E-SYS and bimmer-utility and do some google/chat-gpt searches
      03-23-2023, 12:25 PM   #151
deliciouscars
Drives: f11
Try this link. I'll leave it up a couple of days:
https://drive.google.com/file/d/1ore...ew?usp=sharing
Hi, does anyone here have the current link for the list? I'm just trying to code Urban cruise control, only I'm missing the values
      04-30-2023, 04:11 PM   #152
mjkasper
15
Drives: BMW X5 45e
Can't get aSLA to work with 11/2022 update
I have a 2023 X5 45e in the US. It came with 07/2022 and I was able to enable aSLA. I just received the 11/2022 OTA update which wiped out my programming (as expected). I went through what I believe to be the same steps as before, following the same cheat sheet as before, but I can not get the feature to enable. The aSLA feature does appear in the Car/Settings but I can't put it in 'Automatic' speed set mode.
It feels like it is a 'land_activ' setting somewhere but I updated all of them as indicated by the cheet sheet I had used previously with no luck.
Does anyone know if the coding to enable aSLA has changed from 07/2022 to 11/2022? Does anyone have a cheat sheet they used to enable aSLA on 11/2022?
      06-29-2023, 02:42 AM   #153
NaFa
Drives: Bmw x5 45e g05
Good day everyone,
Not sure what I did wrong ? But I have 2022 g05 45e us spec with SLI working, but with US standard, I was trying to change region , but it not changing anything on dashboard, still white box with no info.
I also can’t code kafas4 , but I code everything else (mgu, vip,sas) using last bimmerutility . Hope someone can help
      07-03-2023, 02:10 AM   #154
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
Gents I have just sent an email to BU re issues enabling UCC It appears their latest software version is now independent of E Sys and third party PSdZData updates, is missing some UCC fdl labelling in their ncd database version.
UCC can still be enabled successfully providing you copy the xml file into the cheat sheet directory and use the enable/disable tabs as it ignores the "unbelegt" labelling as the cheat sheet uses the mask start and end ranges.
Both the SAS3 and the DSC_VIP ecu's are affected
