      01-19-2021, 05:57 AM   #111
R3D3V1L
Drives: BMW X5 G05 2020
Originally Posted by cruzer666 View Post
Pressing and holding the lock button should accomplish this as long as you're close to the car. If the car support convenient closing. I checked BimmerCode and there's no option to do it without holding the button.
Thanks. The other night we walked away from the car in a car park only to come back 2 hours later realising that we forgot to close the passenger window ... I was hoping there's a fail safe solution ...
      01-19-2021, 09:44 AM   #112
VTENGR
1053
Drives: 2020 X5 M50i
It would be nice if the connected drive app had an option for notifications. For example, it will send you a notification if your windows are down after 15 minutes or something like that. Obviously this could be turned off/on depending on preference. For me, I never leave my windows down while parked for an extended period of time, so a push notification that says "FYI your windows are down" would be helpful. My wife loves to roll her window down by just an inch or two - so it's very hard to tell that it's open when we walk away.
The auto close feature would be nice, but I feel that could introduce a safety issue, if the windows were to close when no one is watching.
      01-28-2021, 07:58 AM   #113
wolfverine
Drives: iX 40 MSprt; X6 40i; 640iGC
I had the OTA upgrade back in Nov to 07/2020.54 and all the Bimmercoding work well after that. Unfortunately, after sending my car in for maintenance today, seems like the software got "upgraded" to 11/2020.45 and as a result, all the previous codings have been reset to default. I tried to code back the previous settings (e.g. video in motion, Alpina startup/iDrive etc) but the buttons (e.g. Headunit, Instrument Cluster, etc) are all greyed out and not enabling me to code these functions. Anyone encounter similar situation?
      02-13-2021, 02:16 PM   #114
roadkillrob
Drives: 08 335i,22 X3M, 2012 C63 Black
Hey just an FYI if anyone else finds this helpful, since you can't seem to code the tailgate functions with a bluetooth adapter, at least I can't with the obdlink LX using android, I had been using esysx but that is a bit more work. Decided to try my OBD ethernet cable and it worked like a top. I used the OBD Ethernet cable I had with a usb ethernet adapter (both the surface one and amazon basics one I have worked) and then used the micro USB to usb adapter to plug that into my Samsung Tab A followed the instructions from bimmercode to set the IP and activate ethernet on android.
2022 X3M Brooklyn Grey
2008 E93 335i FBO
2012 Mercedes C63 Black Series Alanite Grey
      03-05-2021, 03:21 AM   #115
Dr. Jekyll
Dr. Jekyll's Avatar
I'm able to use the OBDLink MX+ OBD2 and code tailgate functions with an iPhone
      03-05-2021, 04:47 AM   #116
Kas63
Kas63's Avatar
United Kingdom
80
Drives: 2020 X5 M50d
Been able to do the same with my Galaxy S10+ for the tail gate functions with an MX+ adapter.
2020 M50d - Arctic Gray with Ivory White/Black Vernasca
      04-13-2021, 09:21 PM   #117
sripathinishanth
Drives: BMW 2020 X5 xDrive40i
Traffic Loght Assitant
Any idea on TLA coding?
      04-14-2021, 02:30 PM   #118
edtreo
Drives: 2019 X5 40i MSport
I'm using ENET cable + adpater, after upgrading to 11.2020 I couldn't connect. I tried with either diagnostic mode and with the engine on to no avail. Any ideas? Thanks.
      03-28-2022, 01:44 PM   #119
emuu101
Drives: 22 X5
Comfort Individual
Hi,
I was wondering if anyone was able to set the default driving mode to Comfort Individual. When I use Bimmercode to change the default driving mode to Comfort Individual, the option does not appear in the Infotainment options. All I get is Eco Pro Individual and Sport Individual. Has anyone been able to get Comfort Individual working?
All I want to do is set the steering to Sport, and everything else as Comfort. Alternatively, I was thinking I could set the default mode to Sport Individual, and change everything except Steering to Comfort, but I would like to have the Auto Start-Stop function enabled. Is there a way to be in Sport Individual and still have Auto Start-Stop enabled?
Thanks!
