      08-16-2020, 06:20 PM   #23
Trojanlaw
Trojanlaw's Avatar
Drives: 2019 X5 40i M
2019 BMW X5  [0.00]
You must have a mapping error because the only 2 options you should have are US[05] or Rest of World[03]
Do you have the most up to date psdz files?
2019 X5 X40iM
      08-16-2020, 08:08 PM   #24
Bigtop
Drives: 2020 G05 M50i
Originally Posted by Bigtop View Post
Nearly there.
I have done everything "After you hit "Code" on the Kafas file, you will have to revise the three specific files mentioned previously."
Except the last sentence. I checked the values after coding and the only one that is different and needs revising to [03] is
C_FLA_BS_EXIT_THRESH: Rest of world (mine shows Werte =02
How do I revise. When I right click the Edit , it is greyed out so I cannot change it to 03
Hi Trojanlaw
PSdZData_Lite_v4.21.32
shag36.50
      08-16-2020, 09:06 PM   #25
VTENGR
1053
Drives: 2020 X5 M50i
Nearly there.
Hi Trojanlaw
There's a more recent version that you should download.
      08-17-2020, 06:32 PM   #26
NYC_340i
Drives: '20 M340i xDrive, '11 X3 28i
Thanks for the info. I coded anti-dazzle on my M340i back when it was on version 7/2019.55 but lost it when the dealer updated me to 3/2020.69. I remember last time just removing 5AP and coding those ECUs but this time I made those extra 3 changes in KAFAS. Didn't get a chance to test yet but hopefully it's back to the way I had before or even better!
Current: 2020 M340xi
Previous: 2016 340xi
      08-25-2020, 11:42 AM   #27
Bigtop
So I have looked at the usual places to download the latest Lite version (Almarreto) and the one I have is the latest Lite version
Is the full version more up to date? Any suggestions on getting a later version?
      08-25-2020, 12:48 PM   #28
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
LOL v4.24.12 was latest in June (last time I downloaded), so no, v4.21.32 is far far from latest. You're looking at something like v4.24.31 right now. See the CarTechnology UK forum as one of the sources for more recent versions.
P.S. There is some indication that v4.25.12 is out a couple of days ago as well.
      08-25-2020, 10:28 PM   #29
Bigtop
Thank you
      09-09-2020, 11:10 PM   #30
nosnoop
838
Drives: 5 Series
Has anyone gotten this to work with 7/2020.30?
I asked Steve to do the coding for me, and he followed the instructions on first post, but anti-dazzle does not work; it still only works as auto high beam. I have a G01 with anti-dazzle coded, so I know how it is supposed to work.
      09-10-2020, 07:57 AM   #31
Trojanlaw
Trojanlaw's Avatar
2019 BMW X5  [0.00]
Just coded on 7/2020.35 last night and it works fine.
2019 X5 X40iM
      09-11-2020, 08:00 PM   #32
Trojanlaw
Trojanlaw's Avatar
2019 BMW X5  [0.00]
Codes still work. Also code the following in 40F9 if you have issues:
C_FLA_CC_MESSAGE_3:
CC_message_active to no_CC_message [00]
C_FLA_US_SENSITIVITY_MODE:
US to Normal [00]
2019 X5 X40iM
nosnoop837.50
LexxM31698.50
      09-12-2020, 11:50 PM   #33
nosnoop
838
Drives: 5 Series
C_FLA_CC_MESSAGE_3:
US to Normal [00]
Thanks to Trojanlaw, anti-dazzle now works with these additional codes!
Just an observation: I do notice quite a big difference between G01 and G05. Actually, I noticed the difference with their Auto High Beam, even before the coding. G01's Auto High Beam is much more active, it would turn on much more frequently than G05. Any speed above 40+ km/h, the auto high beam would be ON if there is no car in front.
The same pattern follows after the anti-dazzle coding. G01's anti-dazzle high beam would turn on much more frequently and at lower speed than G05.
      09-13-2020, 02:17 AM   #34
ifr
ifr's Avatar
United Kingdom
1198
Drives: Tesla MY LR AWD
Probably coding. My UK G05 High beam activates most of the time even at low speeds and in built up areas, etc.
These are the HBA settings including some of mine for a reference.
No idea which ones will help with activation frequency, and after working with Trojanlaw on his HBA I'll be quite happy not to see another HBA setting again, but fill your boots.
https://drive.google.com/file/d/1vcn...ew?usp=sharing
LexxM31698.50
nosnoop837.50
      09-13-2020, 04:26 AM   #35
GrussGott
GrussGott's Avatar
Drives: 2018 M4 Comp Indv
Given the NHTSA's October regulation change, I'm wondering if dealerships will recode anti-dazzle, especially for vehicles that leave the factory before, and aren't delivered before the regulation change.
I noticed the anti-dazzle decoding option on a build vehicle order ... be great if dealers enabled it for free after the change.
Originally Posted by TurtleBoy View Post
He tries to draw people into inane arguments, some weird pastime of his.
      09-13-2020, 07:31 AM   #36
nosnoop
838
Drives: 5 Series
The chance of that is almost close to zero.
Given the fact that most of them would not even do a requested iDrive software update unless you have a problem, and there is no sign that they would add functions like Assisted Driving View for older cars, I am very much doubtful that they would accommodate any request to re-enable anti-dazzle. I hope I am wrong though.
If other manufacturers like Audi upgrade theirs, it may put pressure on BMW to the same.
      09-13-2020, 09:16 AM   #37
Trojanlaw
Trojanlaw's Avatar
2019 BMW X5  [0.00]
Without ifr, no one in the US would have GFHB after the software updates. To save everyone time, here are the settings that differ from ECE re VLD. This includes settings not included in ifr's list.
7083 AL_MODE_ECO: LOW_LEVEL_3_DIPB[03]
7083 LIN_VARIANTE_SZL: szl_r_HW_aic_4Band_fla [30]
1DF8 C_AFS_ECO_LEVEL_3_ENA:enable
1DF8 C_AFS_ENA: enable
1DF8 C_BLC_PRE_ENA:enable
1DF8 C_CLC_BLINK_ENA: enable
1DF8 C_CLC_CURV_V2: ECE
1DF8 C_CLC_CURV_V3: ECE
1DF8 C_CLC_EXT_ENA: enable_roundabout
1DF8 C_CLC_REV_ENA: enable
1DF8 C_HBA_GFHBA_ENA_V_HI: standard
1DF8 LUT_AFS_CODRV_HOR: G05_Laser_ECE
1DF8 LUT_AFS_DRV_HOR: G05_Laser_ECE
1DF8 LUT_FLC_FORWARDLIGHTING_Y: AFS[00, 00, 00]
Just a heads up that many of these files were trimmed in 7/2020. You will need the Esysx update coming out soon to properly map.
Let me know if this works better for you all.
2019 X5 X40iM
Appreciate 5
LexxM31698.50
nosnoop837.50
ifr1198.00
      09-14-2020, 02:30 AM   #38
ifr
ifr's Avatar
United Kingdom
1198
Thanks but you're too modest mate. The GFHB codes are definitely all yours.
      09-22-2020, 08:38 AM   #39
Saunders17283
Saunders17283's Avatar
Drives: 2020 M850xi Gran Coupe
I coded anti-dazzle a few weeks back but am only now getting the chance to drive at night and use it. It definitely works but I seem to remember some discussion surrounding sensitivity coding. Have we isolated what those codes are? For example, I seem to remember somebody posting about 1) sensitivity to oncoming street signs, 2) sensitivity to ambient light and overhead street lights.
Reason I ask is mine rarely comes on when traveling on the interstate since most of the freeways in my area have updated to LED street lights over the freeway. However, when I travel highways without these new overhead street lights, it works great.
Also, too large or too many street signs will typically turn it off.
Lastly, are there other tweaks that can be made to VLD?
Thanks in advance & sorry if this is covered elsewhere...I search for quite a while and couldn't find definitive answers.
Current Ride
Previous Rides
2019 X7 / 2018 X5 / 2012 X5 / 2014 750xi / 2011 750Lxi / 2008 335xi
      09-22-2020, 09:18 AM   #40
Trojanlaw
Trojanlaw's Avatar
2019 BMW X5  [0.00]
If you check the cheat sheet I posted, this is the code that references signs, although I have not seen a big difference using it.
KAFAS4 40F9 C_FLA_Country_With_Multiple_Reflectors Inactive aktiv
Mine works as well but does not turn on nearly as often as it does for our friends in Europe. I have spent a lot of time evaluating ECE settings vs. ours and other than Laendervarient issues, I cannot tell why ours are less sensitive. I have also found changing certain settings to ECE messes with US sign recognition and other related issues.
The codes that deal with HBA and GFHBA sensitivity are the following contained in BDC_BODY3 1DF8:
C_HBA_DIM_DELAY: default [0A]
C_HBA_DIM_ENA: enable [01]
C_HBA_DIM_MAX_DIFF: default [02]
C_HBA_DYN_RESERVE_LOWER_MAX: default [FB]
C_HBA_DYN_RESERVE_UPPER_MAX: default [0A]
C_HBA_ENA_V_HI: standard [28]
C_HBA_ENA_V_HYST: default [0A]
C_HBA_FILT_BND_BOT_DEC: default [05]
C_HBA_FILT_BND_BOT_INC: default [19]
C_HBA_FILT_BND_HOR_DEC: default [05]
C_HBA_FILT_BND_HOR_INC: default [19]
C_HBA_FOG_ENA: default [01]
C_HBA_GFHBA_ENA_V_HI: standard [3C]
C_HBA_GFHBA_ENA_V_HYST: standard_10_km/h [0A]
C_HBA_GFHB_HGWY_ENA: default [01]
C_HBA_HOR_BND_F_INC: default [07]
C_HBA_HOR_BND_OFF: standard_04_deg/s [28]
C_HBA_HOR_OFF_VEL_HI: standard_11_deg/s [71]
C_HBA_HOR_OFF_VEL_LO: vel_6_9_deg/s [47]
C_HBA_HOR_OLAP_CODRV: 2Grad [15]
C_HBA_HOR_OLAP_DRV: 2_grad [EB]
C_HBA_PREV_REA_ONC: default [00]
C_HBA_SWITCH_DEL_T: default [05]
C_HBA_TAU_EX_HGWY_ENA: default [01]
C_HBA_TAU_EX_HGWY_L: default [F6]
C_HBA_TAU_EX_HGWY_R: default [0A]
C_HBA_TAU_EX_L: default [D7]
C_HBA_TAU_EX_R: default [29]
C_HBA_THRES_CODRV_DEACT: standard [99]
C_HBA_THRES_CODRV_INIT: default [00]
C_HBA_THRES_CODRV_REACT: standard [E1]
C_HBA_THRES_COR_TYP: default [00]
C_HBA_THRES_DRV_DEACT: standard [28]
C_HBA_THRES_DRV_INIT: default [00]
C_HBA_THRES_DRV_REACT: standard [05]
C_HBA_THRES_HGWY_CODRV_DEACT: default [B8]
C_HBA_THRES_HGWY_CODRV_INIT: default [00]
C_HBA_THRES_HGWY_CODRV_REACT: default [F6]
C_HBA_THRES_HGWY_DRV_DEACT: default [28]
C_HBA_THRES_HGWY_DRV_INIT: default [00]
C_HBA_THRES_HGWY_DRV_REACT: default [0F]
C_HBA_UC1_THRES_RES_CURV_HI: default [0A]
C_HBA_UC1_THRES_RES_CURV_LO: default [04]
C_HBA_VERT_OFF_VEL_HI: default [06]
C_HBA_VERT_OFF_VEL_LO: default [00]
I do not mean to discourage you from testing. Please do. Of course it is difficult because you can only test late at night in proper lighting circumstances. Also, there aren't a lot of options for the these settings. It will likely require you to discover alternative werte values that increase or decrease sensitivity.
I hope this helps. Please keep us posted if you learn anything.
2019 X5 X40iM
      09-22-2020, 11:27 AM   #41
Jrunr
Germany
188
Drives: 2019 BMW X5 M40i - G05
Do any of these coding modifications increase the output of the laser lights?
      09-22-2020, 11:56 AM   #42
Trojanlaw
Trojanlaw's Avatar
2019 BMW X5  [0.00]
If you are adventurous, the attached spreadsheet highlights all ECE potentially relevant codes that differ from the US.
https://drive.google.com/file/d/1kd0...ew?usp=sharing
You may be able to convert your lasers by changing all codes listed in 40F9. There may be other issues associated with that, however, so try at your own risk. I changed all codes previously by changing my country code and then VO coding all modules. That resulted in several errors, but the lights did function. Whether they were stronger or not I have no idea.
2019 X5 X40iM
      09-27-2020, 10:20 PM   #43
screamace
screamace's Avatar
304
Drives: 2020 BMW X5M Competition
When I purchased my 2019 Porsche Panamera with PDLS+, I specifically asked if the dealer will help enable full functionality after the regulation passes and was told a firm yes.
2019 Porsche Panamera 4 E-Hybrid
Past BMW: 2018 M550i, 2016 X5 40e, 2014 335xi, 2011 X5 50i, 2010 550i
GrussGott18183.50
      11-07-2020, 04:00 PM   #44
nosnoop
838
Drives: 5 Series
Does anyone know if remote software update would reset the Anti-Dazzle coding?
I got notification for 07/2020.54 remote software update.
