      04-19-2021, 02:45 AM   #133
sahajesh
sahajesh's Avatar
United Kingdom
2294
Drives: 2021 G05 X5 40i Tanzanite Blue
Originally Posted by ifr View Post
Originally Posted by sahajesh View Post
Never knew that's what the SET icon meant! Will try that next time I'm out on a motorway
As a UK owner, you have the option of using 'auto' for Speed Limit Assistant. Just change it in idrive from Manual to Auto, adjust the +- speed up to 40mph, and above 40 mph (i use +2mph and +5mph respectively) and you don't have to worry about changing the cruise or getting a speeding ticket.
Edit: if you ever get TLA working natively in a future update, you will need aSLA enabling to allow the car to stop at the lights.
I've now set mine to this but will check the manual (shock horror!) as well.
      04-19-2021, 03:48 AM   #134
ifr
ifr's Avatar
United Kingdom
1198
Drives: Tesla MY LR AWD
That should work. I like 2mph as it in theory shouldn't go above 32mph. 5mph means you don't go above 55mph, so no tickets.
Some might want faster than 75mph, but I'm slowing down in my old age
      04-19-2021, 04:06 AM   #135
JJ 911SC
Crusty Old Navy Chief
JJ 911SC's Avatar
22438
Drives: 2022 X3 M40i, 1983 911SC
I wish the Speed Warning would work on a percentage like 10% over the posted speed.
      04-19-2021, 04:34 AM   #136
ifr
ifr's Avatar
United Kingdom
1198
Originally Posted by JJ 911SC View Post
I wish the Speed Warning would work on a percentage like 10% of the posted speed.
that would be better
      04-19-2021, 06:47 AM   #137
roadkillrob
Drives: 08 335i,22 X3M, 2012 C63 Black
Had an interesting bug last week, I updated to 11/2020.50 about a week or a little more and recoded stuff like ADV etc. Went on a long drive 5-6 hours last thursday using active cruise with driving assist for most of it as it was late and not a lot of traffic, so most of the time the car is showing the Advanced Driving View on the cluster, about 4 hours in the ADV on the cluster just went black, so nothing in the center of the cluster at all, all while just cruising with ACC on didn't touch anything. After about 30 seconds, ADV came back on for a few seconds, then back to black, did that about 5 times then went black again and after a bit just changed to the map in the center like it has when not cruise control. Stayed like that for the rest of the drive for another hour no matter if I turned on acc or off. Shutoff car when I arrived and turned it back on and went back to working.
2022 X3M Brooklyn Grey
2008 E93 335i FBO
2012 Mercedes C63 Black Series Alanite Grey
      04-21-2021, 03:39 PM   #138
mnavis29
Drives: BMW 435xD
Hi all,
I am kind of stuck at the preparation phase of the OTA update. The software was properly uploaded via myBMW to the car, but since one week it's basically preparing the update and not giving me the option to start the upgrade progress.
Anybody had a similar problem? Any suggestion? I have read somewhere that the battery needs to be properly loaded?
      04-22-2021, 04:33 AM   #139
BrummyGit
United Kingdom
75
Drives: BMW X5 xDrive45e M Sport
Slightly off topic but I continue to be confused by my UK 2021 (built 9th Nov 2020) 45e which arrived with 07/2020 software. It seems to be different to others.
Not only do I not have any Traffic Light Assistant references in any of my iDrive menus (which I hope will appear with a future software update), but I notice that your A/C display below is showing red fan speed bars - I only see white on my display. Any idea why the difference (I don't have 4 zone A/C)
      04-22-2021, 04:51 AM   #140
sahajesh
sahajesh's Avatar
United Kingdom
2294
At the time, AC wasn’t on or Auto weren’t on, I just tried now and I can’t get white fan speed bars on mine.
      04-22-2021, 06:07 AM   #141
BrummyGit
United Kingdom
75
Strange, I wonder if it's due to the blue "eco friendly" dash colours on the 45e which I assume you don't get on the 40i. It's in at BMW today for charging issues, but I'll switch to sport mode (dash goes back to BMW red/amber) when I get it back later and see if its the same then.
      04-22-2021, 07:16 AM   #142
sahajesh
sahajesh's Avatar
United Kingdom
2294
At the time, AC wasn't on or Auto weren't on, I just tried now and I can't get white fan speed bars on mine.
I'll try on Eco Pro to see if it changes - that's the closest we have on the 40i!
      04-22-2021, 01:03 PM   #143
BrummyGit
United Kingdom
75
Well my car is back from BMW with new software - there was a high voltage charge controller error and part of the fix was to install 03/2021.40 - I can't get my heater display to go red, although I do now see references to Traffic Light Assist.
      04-22-2021, 01:39 PM   #144
sahajesh
sahajesh's Avatar
United Kingdom
2294
The TLA you're looking for is here - do you get the same as me?
      04-22-2021, 05:06 PM   #145
BrummyGit
United Kingdom
75
Yes, exactly the same
      04-22-2021, 05:40 PM   #146
JJ 911SC
JJ 911SC's Avatar
22438
Look like its not available in UK, pity...
      04-22-2021, 05:51 PM   #147
sahajesh
sahajesh's Avatar
United Kingdom
2294
It is via coding, but not something I’d want to do.
In addition, I would likely only use Assisted Driving/ACC on motorways/major dual-carriageways and you don’t get traffic lights on the former and hardly on the latter (at least the roads I use).
      04-22-2021, 06:43 PM   #148
JJ 911SC
JJ 911SC's Avatar
22438
... motorways/major dual-carriageways and you don’t get traffic lights on the former and hardly on the latter...
You know that most people here have no idea what you are talking about...
      04-22-2021, 11:23 PM   #149
sahajesh
sahajesh's Avatar
United Kingdom
2294
Oops!
I'd use on the U.K. equivalent of highways/freeways but not on the smaller roads, as they have curves in them and aren't long, boring straight roads
JJ 911SC22438.00
      04-23-2021, 02:37 AM   #150
ifr
ifr's Avatar
United Kingdom
1198
It's almost perfect in the UK now (with coding) but limited use if you don't engage cruise in urban areas.
it's a shame the green light warning isn't supported yet. That could be useful even if you don't use the Assisted Driving.
      04-23-2021, 07:04 AM   #151
Consuldean
Drives: BMW 21'' X6MC (F96)
I don't see this menu although I did the coding. Here's what I see in the drivers assistance menu.
Did I miss something in the coding ?
with that said, my car does pick up the traffic lights on the road but isn't able to translate their color into any action/recommendation. I get a Red Cross next to the light when it comes up.
      05-02-2021, 11:37 AM   #152
NoPII
Drives: 2024 XM Label
Am I doing something wrong? My 2021 X6M still has 07/2020 on it, and OTA update still tells me there's nothing available.
While I did remove 5AP from my FA and VO code to activate adaptive lighting, I didn't write the FA back to the car?
      02-22-2022, 07:34 PM   #153
mitch57
805
Drives: 2020 BMW X7 xDrive40i
Welcome to BMW.
It's a known issue and BMW has issued a Service Information Bulletin (SIB) on this issue. You'll need to take it in to get it resolved. https://static.nhtsa.gov/odi/tsbs/20...04533-9999.pdf
