      10-30-2023, 02:04 AM   #111
lpawelek
Drives: G07 30d
Originally Posted by mlurker View Post
Can you share the file please
PM me your email address pls
aleksy7.00
      11-11-2023, 04:27 AM   #112
aleksy
Drives: BMW X5 50i 2019 g05
lpawelek
Siemasz,
Mam x5 50 2019
Mam pare pytan odnodnie
Bu- aSLA, TLA, itp
Nie do konca potrafie to uzywac
z cheat sheet
Jak bys mial chwilke, I chicialoby ci sie
To napisz mi w Pm twoj number Whatsappa
Ja nie moge jeszcze pisac Pm
Nie Mam wystarczajaca postow…
Dzieki!!
Sorry y’all I have few questions about bu
I feel like my fellow polak might be down to answer me few questions
      12-23-2023, 12:43 AM   #113
aMIC
Drives: BMW 325 XIT , X5 45e
Is possible to set a parameter that would stop the car ahead of location of the stop light?
That would help/ solve the issue that in US the traffic lights are after the intersection vs just before the intersection in Europe or other places.
      02-08-2024, 12:17 AM   #114
thepianist1
37
Drives: BMW X3 G01
Can BimmerUtility modify any parameters in ICM, SAS or DSC modules? For me it’s view only and I paid for the $109 access full.
      02-08-2024, 12:41 AM   #115
lpawelek
Drives: G07 30d
I don't know if any parameters BU is able to change, but as far as I used this utlility every module was successfully coded.
      02-15-2024, 07:57 AM   #116
007bandido
Switzerland
Drives: 2019 G05 30D M
Hello,
Just updated OTA from 03.2023 to 11.2023. Impossible to put back TLA when it worked perfect before update. The option is available in the idrive put I can't select. I use BU and cheat codes does'nt work anymore for TLA. Thanks.
sac0249.50
      02-23-2024, 10:31 AM   #117
lactlac
Drives: BMW G20 320Xd
Could you please send me the link or file? lactlac@gmail.com
Thanks in advance.
Bambazonke
      02-24-2024, 05:03 PM   #118
Bambazonke
Bambazonke's Avatar
Australia
210
Drives: 2017 X5 & 2020 X5
  [0.00]
Thanks in advance.
Bambazonke
File sent
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive
      02-24-2024, 05:14 PM   #119
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
Originally Posted by 007bandido View Post
Hello,
The cheat codes supplied by BU for TLA aSLA are not complete. They are missing the coding for one of the ECU's that is required for it to work.
Secondly when using the cheat codes to change, do one or two lines at the most Especially "Land masks" to "FF FF FF FF" execute one command at a time and save and check to confirm the file has been changed to the new value. I have found when trying to execute multiple lines in one step they are not always saved to the "new" values
      02-24-2024, 05:18 PM   #120
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
Yes BU can do all but you must put the vehicle in diagnostic mode (press start button quickly three times without foot on the brake) A message will come up on the instrument panel telling you your vehicle is now in diagnostic mode and will give you access to all ECU's
      02-25-2024, 12:34 AM   #121
Emengy
Drives: G06 MY23
Originally Posted by Bambazonke View Post
File sent
May I ask you to email me too? emengy.ae@gmail.com
Going to try this in UAE.
Many thanks in advance
      03-08-2024, 03:42 PM   #122
lactlac
File sent
Thank you very much! My list had all the codes except IntRxSWINVarianten
      03-08-2024, 03:49 PM   #123
lactlac
Bambazonke
There is a question about DEFAULT_EINSTELLUNG_STL_BEI_TFL. Are you sure this option applies to TLA? Esys contains such a comment:
(ger) MenüDefaulteinstellung für Standlicht bei Tagfahrlicht
(eng) Menu Default setting for parking light for daytime running lights
      03-09-2024, 02:26 PM   #124
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
Bambazonke
Probably not, what I do is run a SVT coding verification exercise on my X5 by changing the production year in the FA list ie 7/19 to 7/20 and or market version eg 801 (Germany) vs 812 (UK) and list the changes. Pending your iLevel status and hardware fitted these "new" features may or may not work hence my indemnity clause at the top of the sheet
      03-09-2024, 06:00 PM   #125
Yoram57
Drives: BMW g20 330e (2020)
Hello!
What does the IntRxSWINVarianten parameters change/ impact?
And to what value should these be set for a Feb 2020 G20 (software 03-2023)?
I have coded aSLA, TLA and UCC to my 2020 G20 today. Most of the features are working. Although braking for traffic lights is very late (maybe because TLA is officially not supported in the Netherlands). And the green light alert is not working. So I am going over the coding again to check whether I missed something.
Bambazonke Would be great to receive your cheat sheet. I have sent you a PM.
      03-17-2024, 05:08 PM   #126
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
Originally Posted by Yoram57;3Int0972506
Hello!
What does the RxSWINVarianten parameters change/ impact?
Cheat sheet sent G20 Values for RxSWINVarianten will be in the drop down menu in BU which you will have to manually overide
      03-20-2024, 05:51 AM   #127
Emengy
Drives: G06 MY23
RxSWINVarianten looks like something related to physical windows. Are you sure this is required for TLA?
      03-20-2024, 12:24 PM   #128
jonesy16
Drives: 2018 530E xDrive, 2021 45e xD
I've tried doing a quick search but couldn't find anything definitive ... which of these two options works on US cars? (I have DAP, '21 45e)
      03-20-2024, 03:52 PM   #129
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
They may do, however in my X5 assembled in Aug 2019 i had a generic setting value which after coding verification and changing the build date to 07/20 (when TLA was first introduced to the GO5 in certain markets) the value changed to a model specific value. Normally code settings for window functions are to be found in the BDC modules not in the SAS3 & DSC_VIP ECU's. These values may be already set to model specific values in vehicles assembled after July 2020 if they are indeed related to non TLA features.
      03-27-2024, 04:15 AM   #130
vcastceo
11
Drives: Mercedez E250
Hi, I am new Bimmer Utility user and I tried activate urban cruise control with some codes, BDC_BODY3, HU_MGU, SAS3, DSC_VIP_IB4 module. But I couldn't find any relevant codes in KAFAS4.
However, after coding, my steering wheel does not detect my hand. always blink after 5 second, and steering wheel icon change to grey color.
I would like to share which codes I change all, but afraid that it should be violate forum's rule.... Any idea?
      04-05-2024, 06:49 AM   #131
Egorka1983
Drives: Bmw x5 g05
Pm me your email address as I have a cheat sheet specifically for G05 that includes coding for the fourth ECU & more
You can send a shporgalka on TLA, TRL to BMW x5 g05 by mail egornazarov1983@gmail.com
      04-05-2024, 07:25 AM   #132
Egorka1983
Drives: Bmw x5 g05
Originally Posted by postbox1918 View Post
I've used your cheat sheet and coded my G05 and UCC , Highway exit both works perfectly fine just the TLA is little hit and miss i think it has to do with red lights in USA are not exactly marked on idrive maps properly sometimes i can feel that car hesitate or gets confused where to exactly stop at red light ,but thanks a lot for your cheat sheet and helping me out with the coding.
Good afternoon, please tell me If you can send a shporgalka to TLA, TRL to send to BMW x5 g05 to send by mail egornazarov1983@gmail.com
