09-15-2023, 03:25 PM | #26 | |
185
Rep 355
I use this regularly, especially since the actual turn signal deactivation is so bad (it requires the wheel to return nearly all the way to straight, and often I find that if I use the actual clicked signal, the signal will stay on far longer than I would want it to). If the normal turn signal deactivation was better (eg: switched off when the turning radius relaxed, instead of staying on long beyond when the turn is done), I'd probably use the real signal more, but the bad deactivation tuning discourages me from using it.
09-15-2023, 04:27 PM | #27 |
Rep 208
I use flash-to-pass all the time. Is that what you're talking about? Ideally it would flash 4-5 times, but whatever, people see it anyhow and know I'm moving lanes.
09-15-2023, 04:34 PM | #28 |
Rep 118
09-15-2023, 06:50 PM | #29 |
Rep 6,805
Different markets, different defaults. But, I agree, 5-blinks is much more useful than 1 or 3. Why the USA chose to not offer that option when it's already in the code, I don't know.
09-15-2023, 08:35 PM | #30 | |
BMW fan
Rep 13
Drives: 2021 X5 xDrive 45e
Don’t you think BMW will take every opportunity to say that whatever is wrong with the vehicle was possibly caused by coding, such that they won’t cover it under warranty? Thanks! |
09-15-2023, 11:24 PM | #31 |
Rep 68
I use touch for passing and set it for 3 times, not sure why the option of 1 time is for (it’s not like the 1 time swipe with the wipers that is useful also at times)?
09-15-2023, 11:55 PM | #32 |
Rep 83
It’s an indicator of personality.
0 time: childish and immature 1 time: a frugal person; selfish and calculating 3 times: sharp; mildly self-entitled, mildly aggressive 5 times: a kind person, but a bit boring 20 times or more: retarded
TEST
09-16-2023, 02:10 AM | #33 | |
Rep 6,805
You should note that if BMW ends up having to recode a module during service, every once in a while, it fails, and they have to replace the module. I've had that happen to me. But, that was a warranty issue because it happened during a service session. If something goes south and you did it, you may not be as lucky. In the USA, to deny warranty, they'd have to prove you created the problem. While it can happen, a typical coding session rarely causes something like that to happen. |
09-16-2023, 04:04 AM | #34 |
Rep 1,155
No, my UK X5 has maximum of 3 blinks, my wifes UK mini has maximum of 5 blinks which has you say is much more useful, both 2023 cars.
2024 M60i Frozen pure grey/Black Merino
2023 M50i Tanzanite / Ivory/Night Blue Merino gone 2022 40i G05 Arctic grey/Ivory Merino gone |
09-16-2023, 04:06 AM | #35 |
Rep 1,155
What about people who just leave them on for a mile?.
09-16-2023, 08:28 AM | #36 |
Rep 539
09-16-2023, 08:47 AM | #37 |
Rep 8,700
Drives: eVeRyOnE mAD!
09-16-2023, 06:31 PM | #38 |
Rep 6,805
Different markets, even within the same country. Mini drivers don't look at branded BMWs as often if they're interested in a Mini...still, why not give the user the option? And yes, I know BMW owns Mini...but there are different managers apparently with different viewpoints.
09-17-2023, 07:59 AM | #39 | ||
Rep 7,487
The easy coding parameters in apps like Bimmercode are not much different than swapping on aftermarket wheels that have the same size tires. The change is not anything different than what was previously installed…so if you needed new brake pads…the dealerhsip is not going to refuse the job because you have aftermarket wheels…using the same size tires as oe. The easy coding side of Bimmercode is only giving you access for selections that are already there…but not turned on…or you may be making another selection that is already there. Again, if you go into the expert side and screw something up then go to them to put things back…then obviously this is not going to be covered under warranty. The failure was caused by you…thus the cost should be covered by you.
09-17-2023, 08:37 AM | #40 |
Rep 72
Worth noting for those new, Bimmercode will not work with 2024 LCI with the new head unit at this time due to the new secure coding done by BMW.
2024 BMW X5 xDrive50e
09-19-2023, 01:12 PM | #42 |
Rep 118
09-19-2023, 01:14 PM | #43 | |
Rep 118
Loose long term support? |
09-19-2023, 04:47 PM | #44 |
Rep 72
Hopefully not for you. The new encryption likely requires hardware support from the new control head and ECM and cannot be back-ported to your vehicle. So you may be safe.
