08-08-2023, 10:18 PM | #2 |
Rep 3,681
Oil temp range is large. Consider warm enough to pushing the car, I would say 200F. Under heavy driving, 250+F ks entirely possible. Typical would be somewhere between 220F-230F of you drive normally on street and highway
08-10-2023, 03:46 PM | #4 | |
Rep 7,488
I would think the unwritten message is...don't drive hard until the engine has come up to normal operating temps. And the manual says where the pointer is when that temp is achieved.
08-10-2023, 03:47 PM | #5 | |
Rep 3,681
Think this, the turbo will spin at 100K RPM when you push it. The bearing is hydraulic, meaning thin layer of oil. You oil to have the correct viscosity, so it get there and provide lubrication. Same for other bearing, such as rod bearing, crank main bearing, cam bearing ... It is exposure related as well. If you push it cold once or twice, it is not the end of the world, if you do it often and long, say cold car and starting doing track lap, sure shorten life
2022 G05 B58/PHEV
+ a few very old BMWs |
08-10-2023, 03:49 PM | #6 | |
Rep 3,681
2022 G05 B58/PHEV
08-10-2023, 04:20 PM | #7 | |
Rep 4,337
. Last edited by Marty in NY; 08-10-2023 at 04:36 PM.. |
08-10-2023, 04:27 PM | #8 |
Rep 6,806
I know in sport mode, the temperature gauge is oil temperature per the user's manual, but I was under the impression that it always shows oil temperature as that reacts faster than the coolant temperature in an engine. The manual just says engine temperature, except in sport mode where it specifically says it's oil temperature, not coolant.
08-10-2023, 05:48 PM | #9 |
Rep 3,681
In 45e, the temp gauge in instrument cluster is 100% coolant even in sport mode. Please compare instrument gauge vs sport gate temp. When temp gauge on instrument cluster reach middle, oil temp in sport screen is no where near 200F.
Coolant take 5 minute for less to read "mid" point even in cold winter days. This is because thermostat is working, by passing coolant loop to radiator. The amount of coolant inside engine block is small, gets warmup quickly. Oil is entire different story, you cannot by pass oil loop. The entire 7 quad needs to get to operation temp, circulating engine block and head. This also mean the engine block is up to operation temp. We are talking about 500lb of stuffs (engine + oil) here. It will take sometime.
2022 G05 B58/PHEV
08-10-2023, 05:56 PM | #10 |
Rep 3,681
Not quite the same. Qsilver7's said "engine temperature". Your's has "Engine Oil Temperature". Now the icon on both are the same, it looks like coolant icon tho. The oil temp icon should look like the attache picture. BTW, this part of gauge does NOT exist in PHEV. this corner is the HVB level even in sport mode. the only temp reading in instrument cluster is the bar at the mid part, slightly off to the right side (attached picture)
It is very easy to tell if it is oil or coolant. If it take 2-5min to get to middle, it is definitely coolant. Oil cannot get there that fast. If take 15-20min, and gauge slowly ramp up. It is oil. I know X5M has oil temp there, but the icon is different. I don't have 40i, probably I can check coworker's car if I get a chance to drive it for 10 minutes. OK, I also found picture of my 45e, sport mode, instrument cluster and sport display in the same picture, clearly show instrument at mid level, oil at ~165F. Typical oil temp should at the middle of the sport display, which is 220F
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 08-10-2023 at 06:09 PM.. |
08-10-2023, 06:19 PM | #11 |
Rep 6,806
The attachment is from the 50e user's manual...the 45e's manual says the same thing. Note that there's a thermostat on the oil cooler, so the volume of oil is limited until it warms up, letting the oil warm up fairly fast, maybe close to in lock step with the coolant or close.
08-10-2023, 08:17 PM | #12 | |
Rep 565
Oil temp changes significantly slower than coolant.
08-10-2023, 09:46 PM | #13 | |
Rep 7,488
Having the oil temp gauge in the sport display is a nice feature, though. I give that two thumbs up…at least you all aren’t stuck with one or the other. If you want to know your oil temp….just pull up the sport display…sweet. Oil Temp Gauge (on my f15 X5) Coolant Temp Gauge (on my e53 X5)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-10-2023 at 09:57 PM.. |
eelnoraa2032.50 |
08-10-2023, 11:45 PM | #14 | |
Rep 3,681
I just checked my cars E39 coolant E46 coolant E82 oil E61 535xi (not mine, just doing maintenance with a friend), none, no temp gauge at all, it is MPG gauge there, WTF It seem all E series non turbo has coolant. Some early E series with N54 has none. The later E series has oil. I don't have any F series car nor much experience with them
2022 G05 B58/PHEV
08-11-2023, 05:26 AM | #15 |
Rep 804
08-11-2023, 08:14 AM | #16 | |
Rep 7,488
The e61 was produced during the era where BMW changed the instrument cluster design from having the four gauge rings down to only two gauge rings...so the oil/coolant temp gauge had to go away...and the moved the fuel gauge into the speedometer gauge as a meter within the speedometer ring. I'm glad they brought back the four rings prior to moving on to the all digital displays that have everything but the kitchen sink.
08-11-2023, 11:50 AM | #17 | |
Rep 3,681
Honestly, if I have to choose between coolant or oil, I think for general public, coolant is a lot more meaningful. Coolant temp will be the first indication of overheating and cause catastrophic issue, long before oil temp can cause issue. And BMW cooling system will fail at various level at 60-80k miles. Oil temp is more for auto sport, where the car get stress at redline for long duration. I would say even drag racing or autox, the stress is too short to create oil temp issue, it needs to be track events. For people who stress car this way, they all know better how long to warm up before going at it. People who warm up car for 5 min, see coolant gauge reaches middle, and start pushing the car, maybe they need a bit more experience in car and performance driving before doing so.
2022 G05 B58/PHEV
08-11-2023, 01:02 PM | #18 |
Rep 204
Drives: 2022 BMW X5 xDrive 40i
I went to death valley and ambient was around 130F. Oil reached 280+ while climbing a mild hill and I felt the engine misfiring. No warnings or light but it was enough to have me check the oil temp. Quickly pulled to the side and idled for 10 minutes, it was back to 230-ish. So in my experience, 280 is a no go.
PS. X5's ambient temp sensor tops out at 122F. That's 50.0 in Celsius. |
08-11-2023, 02:18 PM | #19 | |
Rep 3,681
2022 G05 B58/PHEV
08-12-2023, 02:02 AM | #20 |
Rep 825
Assuming that one is using BMW recommended engine oil, oil sump temps of 300º F transiently is not a problem. The flash point of the LL-01 5/30 oil is ~450º F. Change the oil every 5K miles.
Two is One and One is None
