05-15-2023, 07:19 AM | #23 |
Generalissimo
641
Rep 1,392
05-15-2023, 07:39 AM | #24 |
Rep 8,696
Drives: eVeRyOnE mAD!
I’m pretty certain we access Expert Mode in the tailgate module
05-15-2023, 07:54 AM | #25 |
Rep 228
I followed the instructions that TheNine90 posted in this thread, the last two sets of parameters are his settings which works perfectly! You will find the parameter settings in expert mode, i think there are only 6 sets of hex numbers that you need to change. You change the hex on 3011 (top tailgate) and 3072 (botton tailgate). Ill take some screenshots for you later if needed. |
05-15-2023, 10:11 AM | #26 | |
578
Rep 2,047
Bimmercode HKFM tailgate module, go to expert mode look for the code and apply them
05-15-2023, 10:33 AM | #27 |
Generalissimo
641
Rep 1,392
05-15-2023, 10:34 AM | #28 | |
Generalissimo
641
Rep 1,392
alabesky92.50 |
05-15-2023, 05:45 PM | #29 |
Rep 1,292
I am going to take a look at this for X6M and see if the codes are similar since I do not have the split tailgate.
05-16-2023, 06:40 AM | #30 |
578
Rep 2,047
The X6 only has 3011 APPL_PLG_SPEED_PROFILE, 64(Top tailgate) and only uses Node1 and Node2.
So it should be same method. However the values are diffrent. You can multiply the pwm parameters by a constant like 0.25 or 0.5 then modify the posplg values. |
05-26-2023, 04:05 PM | #31 |
237
Rep 372
Thank you TheNine90 for the soft-close code! It works great (but I had to make 1 minor adjustment for the upper liftgate).
For those of us that had adjusted the threshold knobs on the sides of the hatch to eliminate the hatch rattles, you might have to make a single adjustment to account for the extra force required to close the hatch properly: ProfileCloseStartNode1PwmPlg = wert00,XX where XX = 40 to 45 (as in wert00,41) I had originally used wert00,3E (as per TheNine90's code) but the hatch did not lock fully and left a gap, then it opened right back up. I changed to wert00,41 and it closes and locks perfectly. If you want to make it a bit softer, change ProfileCloseStopNode1PwmPlg = wert00,YY where YY = 8C to 96
2021 G05 X5 s40i Phytonic Blue | Ivory White Vernasca | Anthracite-Brown Poplar Matte Trim
2015 F10 535i M-Sport Space Gray | Black Nappa (Gone) |
05-26-2023, 04:25 PM | #32 | |
Generalissimo
641
Rep 1,392
05-26-2023, 07:12 PM | #33 | |
237
Rep 372
12-15-2023, 05:49 PM | #34 |
Rep 4
Hey, I'm the newbie here. Could someone share the detailed instruction how to programming in expert mode? I saw some videos but in this case I'm stucked a bit.
For example code ProfileCloseStartNode1PwmPlg Werte=00, 3E But I can't find that "Werte" string. Here is what I see: View post on imgur.com |
12-15-2023, 10:07 PM | #35 |
Rep 6,805
I think you'd have to click on 'custom value' then enter it there...the menu is just giving you some default values they feel work. The check mark indicates the current value.
01-09-2024, 04:21 PM | #39 |
Rep 4
Thanks a lot! Your kindness is appreciated, and it would be wonderful, but I'd prefer to learn how to control it independently. I don't want to rely on others all the time. While adjusting trunk speed seems straightforward with everyone in this thread succeeding, I'm having trouble editing those variables.
02-23-2024, 07:48 AM | #40 |
Rep 1,292
Has anyone done this with the X6M? if so, what values are you using?
03-04-2024, 11:09 PM | #41 | |
33
Rep 40
G05 Soft Close Tailgate with Bimmer Code
3011 APPL_PLG_SPEED_PROFILE, 64(Top tailgate) Code: ProfileCloseStartNode1PwmPlg Werte=00, 3E ProfileCloseStopNode1PwmPlg Werte=00, 98 ProfileCloseStartNode2PosPlg Werte=00, 32 ProfileCloseStopNode1PosPlg Werte=00, 32 3072 APPL_LTG_SPEED_PROFILE, 69(Lower tailgate) Code: ProfileCloseStartNode1Pwm Werte=00, 25 ProfileCloseStopNode1Pwm Werte=00, BB ProfileCloseStopNode1Pos Werte=00, 96 ProfileCloseStartNode2Pos Werte=00, 96 Having some problems how to use the custom values in Bimmer Code. ProfileCloseStartNode1PwmPlg Werte=00, 3E So in custom value the first line is Byte 0 0x00 The second line is Byte1 is that the box to be changed to 3E? |
03-05-2024, 08:44 PM | #44 | |
33
Rep 40
Thank you TheNine90 very much for showing the code for us G05 drivers. I think you are the only one that posted this information for the G05. However, looks you are banned member. Wish you the best! |
