      01-05-2021, 02:15 PM   #1
mousefarmer
130
Drives: 2007 328i, 2006 330i
Does BMW use recycled plastic?
I've read that automakers use recycled plastic in cars. Does BMW? If so, where is the plastic sourced from, and does it affect quality?
      01-06-2021, 09:19 AM   #2
kyriian
kyriian's Avatar
872
Drives: 06 Black Sapphire Z4MR
2014 BMW X5  [0.00]
2011 Scion tC  [0.00]
Can't say specifically for BMW, but majority of plastic parts you see today will have SOME recycled plastic content.
I can't imagine anyone doing mass production today spending the coin on virgin grade anymore unless its application specific.
Revolution of our Times
I will return to the track, one day.
David701567.00
dradernh4179.00
      01-06-2021, 10:13 AM   #3
The Libertine
The Libertine's Avatar
Drives: 2021 Porsche Macan
Yeah... the proliferation of recycled plastics is pretty much unavoidable....
      01-06-2021, 10:29 AM   #4
David70
Drives: 06 Z4M Coupe - 13 Cadillac ATS
Yes they use recycled plastics, as a manufacturer with plants all over the world with thousands of total suppliers I doubt even BMW knows the source of all of the plastic. They require suppliers to meet design and manufacturing criteria to continue to buy parts from them. Everything BMW and their suppliers to do affects quality, the amount of recycled plastic is one input but if it, like everything else, is checked and controlled it is a good thing overall to use it. Same with the recycled metal in the car, it also has to be checked and controlled. With much of the plastic in the car the finish of the material doesn't matter much. Look at your plastic fender liners or the plastic panels under the car and you will see the finish is far from perfect as it isn't critical for the part to function as designed.
From your question I think you are trying to oversimplify it.
2006 Z4M Coupe - Stromung exhaust, ZHP knob, stubby antenna, clutch delay delete
chris7197273.00
      01-06-2021, 11:38 AM   #5
mousefarmer
130
Well I had an eccentric shaft sensor fail recently. Its a $200 plastic, German made part and the oil gets inside the sensor and messes it up. I've also had the upper plastic neck of radiator fail and basically fall apart before 100,000 miles.
The plastic was not able to handle the heat or age well.
      01-06-2021, 11:51 AM   #6
M5Rick
M5Rick's Avatar
58908
Drives: M5 F10 DCT Gunmetal
Recycled plastic used in high stressed engine/gearbox parts subject to high heat and oil/fluids are a passport to fail soon. Recycled and new plastic mixed together will always be brittle and every manufacturer uses the process.
      01-09-2021, 09:41 AM   #7
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
Most people do not understand plastic.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
F32Fleet3539.50
      01-09-2021, 09:48 AM   #8
Piper1
Piper1's Avatar
Drives: E85
George Carlin did
Efthreeoh16950.50
      01-09-2021, 09:52 AM   #9
Efthreeoh
Most people don't understand "engineered plastics" either.
      01-09-2021, 10:03 AM   #10
SteveinArizona
Drives: BMW 530e
Originally Posted by Piper1 View Post
George Carlin did
      01-09-2021, 10:51 AM   #11
mousefarmer
130
I use only organic non GMO plastic in my BMW, lol. However, I do think the radiator plastic used in the n51 is biodegradable because it disintegrates in hands after about ten years in the car.
E92William1998.00
      01-09-2021, 06:16 PM   #12
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
The EU has addressed this in part via lifecycle regulations. IIRC there was a program in Germany which pre-dated the EU. IMO it's a big reason why Euro cars always did poorly with regards to reliability.
BMW used to have a program in Germany where they recycled as much what was feasible. For example they would convert seat foam into wheel well liners. BMW also invested heavily in environmental friendly interior materials which contained some recycled content. They were heavily advertised with the i3.
Edit: YouTube is full of BMW recycling videos.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      01-10-2021, 01:21 AM   #13
E92William
1998
Drives: 2008 E92 328xi
2008 BMW 328xi  [0.00]
I was under the impression that there were some EU regulations requiring car manufacturers to use X amount of recycled plastic. Of course this could just be gibberish that's being thrown around but if they can give you a ticket for leaving your car idling because you're "polluting" while half a dozen oil tankers do more than all cars in the world, I wouldn't be surprised if there was some sort of law regarding which plastic they have to use.
      01-10-2021, 12:06 PM   #14
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
It's real.
https://en.m.wikipedia.org/wiki/End_...cles_Directive
https://eur-lex.europa.eu/legal-cont...X%3A32000L0053
      01-10-2021, 12:06 PM   #15
whyzee125
Drives: Dinan stage 2 335i
BMW plastic is some of the worst in the industry so I would say it probably is recycled. It's supposedly due to some sort of German government regulations but from what I've seen Mercedes-Benz does not have the same degree of issues with their plastics that BMW does so I'm not really sure what the answer is.
