07-01-2022, 12:05 AM | #1 |
Rep 10
Stuck Headlight Dust Cover
Hello everyone, I'm new here and have learned a lot from you all, so thank you!
I'm currently in the middle of swapping out my halogen H7 low beams for LEDs and as "painful" as this process is, I've successfully swapped out the driver side bulb with no problems. The passenger side is where I'm having issues - the dang dust cover will NOT come off! After close inspection, I noticed the tabs that lock into place are broken (see pic), but that doesn't explain why the cover is stuck. I feel like maybe the previous owner broke it and screwed it on wrong. I have tried prying it off with a flathead with no luck, I'm pretty sure I'm going to break it further. Should I just chalk it as a loss and try to break it and just replace it? If so, where do I find this part? I doubt a place like AutoZone or Advanced Auto would carry this, I'm thinking I may need to contact the dealer for this part. Any help/advice is greatly appreciated!! Thx |
07-01-2022, 10:07 AM | #2 |
Rep 4,552
Drives: 2015 328d xDrive
Just twist left as hard as you can. Unless the previous owner glued it on, it should come off with enough force. If not then just break out the flat head again and cross your fingers. If it breaks there's a 0% chance you'll get the part at a place like AutoZone lol. The part # is 63117311241 and you can easily google it and order it online yourself and save a trip to the dealer. You can find part information like this using realoem.com
NYC Bimmer259.50 angelforce7.50 |
07-01-2022, 10:46 AM | #3 |
Rep 10
Thank you kind sir, actually headed to the dealer now since they have it in stock. With July 4th weekend and shipping, I needed something immediately so I can drive because I can't be out there with one LED and one hallogen, and I'm definitely not taking that LED back out! Lol
07-01-2022, 12:09 PM | #4 |
8289
Rep 16,159
That cover is over the high beams. There's no cover over the low beams. I got around that by creating my own 'cover'. You can see it in this post: https://f30.bimmerpost.com/forums/sh....php?t=1377259
07-01-2022, 07:39 PM | #5 |
Rep 10
In my 2016 328i GT, the dust cover is definitely over the low beams. I was able to miraculously remove the cover after wedging a flathead screwdriver under it again..so thanks for that tip! Swapped out the passenger side low beam, DRL and fogs up next!
What is everyone's thoughts on the switchback LED fogs that cycle between white and yellow? I'm hearing some people having issues with the lights randomly getting out of sync... |
07-02-2022, 07:58 AM | #6 | |
Rep 4,552
Not sure what you mean when you say switch back fog lights. When and how would they cycle between white and yellow? Do you mean the indicator bulbs?
NYC Bimmer259.50 |
07-02-2022, 08:28 AM | #7 | |
8289
Rep 16,159
I made the decision to go with LED within weeks after taking delivery, because I couldn't see a damn thing at night, especially with just the low beams. You will change the high beams as well, because once you see how much better the lows are with LED you won't be able to live with halogens in the high beams. |
07-02-2022, 08:35 AM | #8 | |
Rep 10
Here's a vid of them in action: |
AndrewC198910942.50 |
07-02-2022, 08:43 AM | #9 | |
Rep 10
I just did the DRLs and they were very easy compared to the low beams, hopefully the high beams are as easy.. |
07-02-2022, 08:47 AM | #10 | |
Rep 4,552
This is what I have for the high beams, I'd suggest finding something similar: https://www.amazon.com/dp/B077D8KZLV...p_mob_ap_share
NYC Bimmer259.50 |
07-02-2022, 08:51 AM | #11 |
Rep 10
Has anyone had inspection issues with LED bulbs in the hallogen housing? A repair shop that specializes in BMWs told me - back when I was inquiring about changing out the bulbs - that they would 100% fail me on inspection if they saw that. (I'm in VA and I assume the laws may vary by state)
So I figured I'd get my future inspections done at very basic mom and pop garages that probably wouldn't know the difference, but was curious of you guy's experiences... |
07-02-2022, 08:53 AM | #12 | |
Rep 4,552
NYC Bimmer259.50 |
07-02-2022, 08:54 AM | #13 | |
Rep 10
07-02-2022, 09:34 AM | #14 | ||
8289
Rep 16,159
07-02-2022, 11:32 AM | #15 | |
Rep 4,552
https://www.amazon.com/dp/B081BDCJH2...roduct_details I'm happy with them so far. One partially died about a year in and the company replaced it for free so I can't be mad. Super bright and I don't hear the fans at all. If they die in the near future I'll replace them with the ones you linked.
NYC Bimmer259.50 |
07-02-2022, 12:01 PM | #16 |
8289
Rep 16,159
If they still exist. Those that I installed don't, and with H7 rapidly going away LED replacements for them will as well. I picked up a couple of spares just in case, which of course means that they'll last forever.
07-03-2022, 01:30 PM | #17 |
Rep 10
What are some of the best LEDs you all recommend for the high beams that are available on Amazon?
https://a.co/d/eVs6wpu These Beamtechs were mentioned, but can anyone confirm they fit in the high beam housing? |
07-07-2022, 04:15 PM | #19 |
Rep 10
So I got the above Beamtechs the other day and just tried to install them. I cannot get them to clip in, tried for over an hour, evident by all the scrape marks. Even though the shape looks completely identical, the bottom base is thicker, which is what I believe is stopping them from seating properly. And yes, I pulled the metal tabs back quite a bit to help accommodate, but no luck. I have since put the hallogen bulb back into the high beam...any advice or should I try another brand?
KCee41.00 |
07-13-2022, 10:24 AM | #20 |
Rep 10
I sent those Beamtechs back and purchased these and they were a much better fit, still tricky, but easier. Hopefully they last...
https://a.co/d/c1NHWcK My LED conversion is now complete: lows, highs, DRL, and fogs. For my fogs I did go with the switchbacks and they're pretty dope. |
07-13-2022, 12:32 PM | #21 |
8289
Rep 16,159
The stop, reverse and signal bulbs are also critical. There's a significant lag with incandescent bulbs between when voltage is applied and when they illuminate. There's none with LED. That can make the difference between someone seeing you stopping or turning in time or not. The lower current draw of LED also eliminates the dreaded and all too common frying of the undersized rear lamp connectors. Brighter back ups make it easier to see with the rear view camera at night.
11-09-2023, 08:21 PM | #22 | |
Rep 11
My LEDs. |
