05-08-2023, 02:42 PM | #1 |
Rep 1,022
Keyfob Close Windows - Distance/Proximity
Noticed the front windows were open so from inside the house, keyfob lock to close them (coded as such). Wasn't happening so I unlocked the car and locked it just to confirm the fob was talking. Which it did, but still no window closing...
Walked outside to the car, and same *keyfob press* closed the windows. Is there some sort of definitive note that states you must within a certain proximity distance re: keyfob/window close . I should test the window open later just to duplicate the issue |
05-08-2023, 03:12 PM | #2 |
Rep 1,209
I have also found that to be true on multiple cars incl BMW, Audi, MB. Seems 15--18 ft. is the sweet spot
2024 X5M60i-- Skyscraper/Ivory
2020 Cayenne replaced by ^^ 2017 X5 35d--still in my diesel phase 2015 GL 350--diesel burner/highway queen 2013 Audi S6--a beast in it's day |
05-08-2023, 03:12 PM | #3 |
Rep 8,848
Drives: eVeRyOnE mAD!
no official distance per se, but you must be pretty close… essentially able to view all windows from your vantage point so that you can safely close all windows without bodily dismemberment
05-08-2023, 03:34 PM | #4 |
Rep 1,022
I've definitely been able to close the windows via keyfob in same/similar location - so the question is more specific to the G05.
I'll retest it again thinking it was the keyfob initially - but a quick unloc/lock of the keyfob in the same proximity confirmed it was talking....it just wasn't closing the window Aka, if the distance of keyfob was too far to unlock/lock the car, then I knew it was a distance issue. But it did that just fine - but did not close the windows. Last edited by chefwong; 05-08-2023 at 04:08 PM.. |
05-08-2023, 03:58 PM | #5 |
Rep 140
Trust me, this works...
Face the car, hold the key fob against your cheek (facing your cheek), open your mouth and then press the open/close button as required. I've used this for years when some distance from the car and want to confirm the lock status. |
05-08-2023, 04:44 PM | #6 | |
Rep 8,848
05-08-2023, 04:54 PM | #7 |
Rep 1,203
When I had a GLE I could open/close windows and sunroof on phone app, surprised X5 hasn't got this.
2024 M60i Frozen pure grey/Black Merino
2023 M50i Tanzanite / Ivory/Night Blue Merino gone 2022 40i G05 Arctic grey/Ivory Merino gone |
05-08-2023, 05:23 PM | #8 |
Rep 1,022
It's the window closest to the garage aft the roundabout. And have closed/opened windows with keyfob in this same location.
Pulled the car out of garage and parked it the same spot. Went back inside. This time windows was closed. Keyfob unlock and window rolled down. Lock - window no close.... Start walking towards the car with keyfob pressing lock. No dice. As I got close/much closer did the windows roll up So I guess it is a proximity thing when it comes to rolling up.... Rolling down , no issues. Last edited by chefwong; 05-08-2023 at 05:37 PM.. |
05-08-2023, 07:30 PM | #9 | |
Rep 8,848
05-08-2023, 08:31 PM | #10 |
Rep 1,022
I'm thinking before the 11/22 OTA update, I -think- I might have closed the window once from this same window spot....which is greater than 5 feet ! Has anyone ever closed their window with the keyfob further than 4-5 feet ? Without doing back to back testing, the window did not start closing while I was walking towards the car testing until I literally was 5 feet in it's proximity... |
05-08-2023, 11:04 PM | #11 | |
24
Rep 49
I've used it as a party trick, but don't love the idea of using my head as an antennae regularly. |
05-09-2023, 10:45 AM | #12 |
Rep 7,567
Ditto this is true. And you don't have to put the remote under your chin...you can place it anywhere on your head (temple, forehead, etc). Anytime that your car's remote fob doesn't appear to be working from the distance you're attempting to unlock or lock the vehicle...hold the remote next to your head and try again.
It's the water in your head that boosts the signal. The human brain is made up of approx 70% water. You can test this for yourself by using your head or with a bucket (or bottle) of water and your remote fob. If you walk far enough away from the vehicle to where your remote fob DOES NOT work...then hold the remote next to the bucket or bottle of water...the remote will then work. Here's an old video that explains/demonstrates how this works:
Gilles7988.50 |
