10-26-2020, 08:20 PM | #89 | |
23
Rep 48
Drives: BMW X5(G05) 2019
In 03/2019, aSLA and eTJA are in operation as standard in the Japanese specification and are not coded. I have FDL'd the aSLA and previously published TLA coding in the cheat code to make TLA work, but TLA does not work. The TLA is just displayed, it doesn't work and doesn't cause an error. I thought that what is missing is aSLA coding, so I changed the default code to the aSLA code, even though aSLA was working in Japan. So I compared the cheat codes with my car and decided to change all the aSLA coding from nicht_aktiv to aktiv, 000000 to FFFFFFF or Gen1. The only change to the aSLA coding is that the TLA's "Not supported in your country" has been added to the aSLA coding. My consideration is that the aSLA and eTJA could be activated only by some other code besides the cheat code? I assumed that. In a nutshell I meant to say that aSLA works by default in Japan without having to enter the aSLA code published on Bimmerpost. By coding aSLA, I was able to get the "TLA does not work in this country" indication for TLA. Translated with www.DeepL.com/Translator (free version) Last edited by Hideada; 10-26-2020 at 08:37 PM.. |
10-27-2020, 01:48 AM | #90 | |
1198
Rep 1,587
I didn't publish the TLA coding and if that is what you are working from then you will be part of the way there, but it won't work. I'll PM you. |
10-27-2020, 04:50 PM | #91 | ||
Rep 66
It ended with no error, was enabled in idrive, it identifies traffic lights, shows it on dashboard, but asks for manual activation all the time. So I guess something is missing. |
11-20-2020, 10:03 PM | #92 |
Rep 4,689
Anyone have issue coding 3D14? Playing with aSLA, but any changes I make based upon the G05 cheat sheet ends in error. On 7/2020.54. I've got some of the features working, but wanted to see what else could potentially become active. The VIP ecu is the only one I can't seem to code. Feel free to pm me.
My daughter has appreciated the interior lighting color changes so I appreciate the contributions to this. |
11-21-2020, 03:39 AM | #93 | |
1198
Rep 1,587
11-21-2020, 07:27 AM | #94 | |
Rep 4,689
I also coded the extra codes for vld post 3/2020. I didn't notice much, if any difference, from what I experience with what was coded via FA. |
11-21-2020, 07:48 AM | #95 | |
1198
Rep 1,587
I only put the aSLA coding together for cars with 5AU/Drive Assist Pro, in regions where its not supported i.e. Speed Limit Assistant works, but requires manual acceptance for each change in speed limit. The coding provides the automatic acceptance option. It also includes some coding for adapt to route - slowing for roundabouts, junctions etc |
11-21-2020, 08:17 AM | #96 | |
Rep 4,689
11-21-2020, 08:20 AM | #97 |
1198
Rep 1,587
11-21-2020, 08:25 AM | #98 |
Rep 4,689
11-21-2020, 08:29 AM | #99 |
1198
Rep 1,587
Ha ha. not at all. I'd definitely do it, and come up with some elaborate but unrealistic justification as to why it makes financial sense
12-21-2020, 06:56 AM | #100 |
9
Rep 42
12-21-2020, 07:10 AM | #101 |
1198
Rep 1,587
12-21-2020, 07:39 AM | #102 | |
9
Rep 42
Thanks!! I Love you |
12-21-2020, 09:37 AM | #104 | |
1198
Rep 1,587
homerrr133.50 |
01-11-2021, 04:58 AM | #106 |
105
Rep 335
I've read all the messages and I would like to ask a few things:
Is iD7 required for these? And do I need to have 5AT? I've started this project about a year ago for my 2017 G30 with 5AS (with a retrofitted SLI): https://g30.bimmerpost.com/forums/sh....php?t=1702052 I've achieved to enable EDP (Limit Assist that works to restrict top speed limit), but I couldn't activate SLA, VZA or ISA(not for G series as I understand). How can I activate SLA and VZA for G30 with iD6 with 5AS instead of 5AT? Your support will really be appreciated
2017 G30 520 (1.6lt)
2016 S1000RR 2014 W205 |
01-11-2021, 06:14 AM | #107 | |
1198
Rep 1,587
01-12-2021, 02:07 AM | #108 |
105
Rep 335
Thanks for the reply. I've realized some parameters are id7 specific. I've found the similar ones for id6 and prepared some CAFD files. I'll give it a try again. Activating SLA is enough for me anyway. Thanks again
01-12-2021, 02:12 AM | #109 |
1198
Rep 1,587
If auto-accept Speed Limit Assistant is available on pre LCI G30, and you already have the manual version, then it should be possible. Not something I've looked into.
01-14-2021, 06:27 AM | #110 | |
105
Rep 335
Actually, all the codes related with this system is as follows: KAFAS VFW_AVAILABLE aktiv [01] VFW_COUNTRY_VARIANT_MODE all FF DSC_EBC460 C_EDP_Land_Aktiv all FF C_VZA_Funktion_Land_aktiv all FF C_vSLI_Land_aktiv all FF C_SLA_Variante dcc [01] C_VZA_Funktion aktiv [01] C_EDP_vorhanden vorhanden [01] BDC_BODY2 STRECKEN_VERLAUF aktiv [01] PIA_DEFAULT_UEBERNAHME_GESCHWINDIGKEIT aktiv [01] UEBERNAHME_GESCHWINDIGKEIT aktiv [01] HU_NBT2 GESCHWINDIGKEITSASSISTENT nicht_aktiv [00] STRECKENVERLAUF aktiv [01] VORAUSSCHAU aktiv [01] SLAMANUELL aktiv [01] HUD_VZA aktiv [01] KI_DISP_CB_STRECKENUEBERSICHT aktiv [01] VOFFSET aktiv [01] AUTOTEMPOMAT aktiv [01] SAS C_EDP_Land_Aktiv all FF C_EDP_SLI_Aktiv all FF C_VZA_Funktion_Land_aktiv all FF C_EDP_Vorausschau_aktiv all FF C_SWA_Land_aktiv all FF C_vSLI_Land_aktiv all FF C_SLA_Variante keine [00] (there is no other option) C_Umschaltung_ACC_DCC zugelassen [01] C_EDP_Laendersteuerung_Konfiguration Vorausschau immer aktiv, SLI immer aktiv C_VZA_Funktion true [01] C_EDP_Anzeige_Zusatztexte true [01] C_EDP_vorhanden true [01] C_ISA_vorhanden true [01] DKOMBI SICHT_ABSICHT_ENABLE aktiv [01] LDM_VORAUSSCHAU_ENABLE aktiv [01] HMI_ECO_TIPP_GESCHWINDIGKEIT_KI_ENABLE aktiv [01] LDM_ISA_ENABLE aktiv [01] LDM_TIP_ENABLE aktiv [01]
2016 S1000RR 2014 W205 Last edited by ejlover06; 01-14-2021 at 10:43 AM.. |
