01-04-2024, 02:09 PM | #23 |
284
Rep 369
Drives: '24 X5 M60i
Makes me wonder how BMW in different markets approaches the tire size matter. First thing that’d happen if I showed up at a dealer for service with non-OEM tire size: voided warranty. They’d immediately hop on me saying the tires will create too much tension, or whatever forces which will lead to increased wear and tear on the x-drive components, and so on
I heard this warning so many times with my prior 3 BMWs that I’d never consider putting on any tires in sizes varying from the OEM specifications Some dealers would go as far as saying that you lose warranty when you put on tires without the BMW star marking, even if the said tires meet OEM size requirements My head swells in amazement every time I see a thread discussing how well your cars perform on whatever tires you dream up
Have: '24 G05 M60i
Had: '15 F10 535d; '21 G11 740d |
01-04-2024, 06:19 PM | #24 |
Rep 408
Well, if you look at the specs of the OEM 22” tires, they have the same 0.7% (3 revs/mile) difference in diameter between the front and rear tires as the 21” Michelin tires being discussed here. Although, in the 22” OEM setup the front tire is larger whereas in Michelin 21” the rear is larger. But that shouldn’t make a difference to the xDrive system or the drivetrain. So technically even if BMW denies warranty on drivetrain because of this, you could always argue that 22” OEM setup has same size difference.
01-07-2024, 12:07 AM | #25 |
Rep 208
The screen shot above misses an important point that star tires are not going to be the same diameter as non star tires of the same size. They could be either larger or smaller to provide a perfect match front to back. Designed as a matching set. This is why BMW wants you to use star tires. You are not going to have a 0.7% missmatch with them.
01-07-2024, 12:18 AM | #26 | |
Rep 408
01-07-2024, 10:24 AM | #27 |
284
Rep 369
Drives: '24 X5 M60i
Well, what I see in this picture is that the taller 21” wheels are over 1 inch bigger in diameter than the OEM specified 22” wheels
In my post above this was the factor I was referring to — the wheels don’t meet the diameter limit set by OEM. Consequently, showing up to a BMW dealer/authorized service shop with such wheels would void my warranty on the spot. Greater wheel size translates to greater weight, and that adds whatever forces which may impact whatever components of x-drive or other parts of the drivetrain. At least that’s the spiel I heard so many times On the star marked tires: they are manufactured in such a way that the difference between rear and front are (close to) eliminated, as stated in another post above
Have: '24 G05 M60i
01-08-2024, 11:29 PM | #28 | |
Rep 208
This is just the kind of bs we have to deal with with an xdrive staggered setup. If I knew it when buying our X5, would have excluded with the 21" staggered tires or the xdrive 40i and bought the sdrive 40i. Its a fn nightmare. Last edited by slicky; 01-08-2024 at 11:38 PM.. |
mojoJJ265.00 |
01-09-2024, 01:19 AM | #29 | |
Rep 408
05-01-2024, 04:13 AM | #31 |
Rep 13
Taller tires are good. But what about the space saver tire. I don't think a taller space saver would fit in the wheel well in boot. How to go about it during a puncture.
05-01-2024, 09:25 AM | #32 | |
Rep 408
I guess spre tire vs run flats is a whole another debate, you can find that searching the forum. It has been discussed at length. |
