09-16-2023, 04:26 PM | #89 |
14
Rep 37
Has anyone experienced a problem coding the VIP ECU? I'm on 03/2023.67. I know I'm using ProTool (latest version), but I thought perhaps you guys may experienced something similar. Basically all the TLA & SLA parameters in VIP are being written EXCEPT these two:
C_SLA_aSLA_Land_Aktiv C_SLA_Streckenregelung_Land_Aktiv I get an error upon writing too. Any ideas? Update: Putting the vehicle in maintenance mode solved it. TLA works now. Last edited by Tylast; 10-29-2023 at 07:41 AM.. Reason: Fixed. |
aMIC31.00 |
09-16-2023, 06:09 PM | #90 | |
Rep 451
Drives: 2017 X5 & 2020 X5
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive |
aleksy7.00 |
09-29-2023, 01:03 PM | #91 |
Rep 6
TLA can't enable after OTA update
Last year I used this sheet for my UK G05 and can confirm emergency lane ant traffic assist worked. I remember not everything i was able to code, but it worked. After latest OTA tried to code again, and now getting country not available error, altough can see traffic light phases on the dash. using 22 esys with launcher pro 5 and latest pszdata lite
BDC 3420 9 9 11000000b SITUATIVER_ABSTAND (only nicht active available to chose) HU_MGU 3006 5 5 00000100AbDAS_2DH_HORIZON_EXTENSION (missing) SAS3/42C1 3000 192 192 11111111b C_RGA_Funktion (missing) SAS3/42C1 3002 137 137 11111111b EM_ElectronicHorizon_MostProbablePathBending (missing) SAS3/42C1 3000 179 182 11111111b C_SLA_UCC_Land_aktiv (wrote FF,FF,FF,FF in the edit menu, but above in drop menu it turns to unknown) SAS3/42C1 3000 184 187 11111111b C_SLA_QmaN_Land_aktiv (wrote FF,FF,FF,FF in the edit menu, but above in drop menu it turns to unknown) SAS3/42C1 3000 188 191 11111111b C_SLA_aUCC_Land_aktiv (missing) SAS3/42C1 3000 193 196 11111111b C_RGA_Land_aktiv (missing) SAS3/42C1 3000 197 200 11111111b C_RGA_Seitenwahl_links_Land_aktiv (missing) VIP/3D14 3020 111 114 11111111b C_SLA_aSLA_Land_Aktiv (missing) 3D14 3020 215 215 11111111b C_SLA_Streckenregelung_vorhanden NR001_vorhanden NR_002_vorhanderne_qSuiLreAs_e>n=t1k9o0p7pelt (missing) 3D14 3020 216 219 11111111b C_SLA_Streckenregelung_Land_Aktiv (missing) 3D14 3020 114 114 11111111b C_SLA_Anzeige_Zusatztexte (missing) 3D14 3020 117 117 11111111b C_SLA_aSLA_vorhanden (missing) 3D14 3025 5 5 11111111b EM_ElectronicHorizon_MostProbablePathBending (missing) 3D14 3025 6 6 11111111b EM_AdasIntegration_AdasExtendedPdu enabled 2007, 6U3 (missing) 3D14 3020 210 213 11111111b C_SLA_Vorausschau_Land_aktiv (missing) 3D14 3020 179 182 11111111b C_SLA_UCC_Land_aktiv (missing) 40F9 3103 37 37 11111111b LDW_C_ELKA_DEB_DSI_DEACT_LMRE TRUE >=2007 (missing) 40F9 3103 38 38 11111111b LDW_C_ELKA_DEB_DSI_ACTIV_LMRE TRUE >=2007, (missing) 40F9 3103 41 42 11111111b LDW_C_RB_TYPE_NODSI_BITMASK initwert - 15,00 >=2007 (missing) 3103 37 37 11111111b LDW_C_ELKA_DEB_DSI_DEACT_LMRE TRUE >=2007, (missing) 3103 38 38 11111111b LDW_C_ELKA_DEB_DSI_ACTIV_LMRE TRUE >=2007, (missing) 3103 41 42 11111111b LDW_C_RB_TYPE_NODSI_BITMASK initwert - 15,00 >=2007 (missing) |
aleksy7.00 |
10-05-2023, 05:02 AM | #92 |
Rep 16
I can confirm that almost all ECU's can be coded by the BimmerUtility. I cannot find in KAFAS sections of LDW_C_ELKA... and others connected with the Lane Departure Warning as well as mentioned by Bambazonka in previous post EM_AdasIntegration_AdasExtendedPdu. I'm after the OTA update and the TLA as well as aSLA working good, even better than before. I don't know how the lack of coding the EM_AdasIntegration_AdasExtendedPdu impact on the system working...
Additionally, I've coded the STOPPCHIELDER in MGU and in BDC BODY so I have active checkbox and the sign in aSLA menu but camera doesn't recognize the STOP sing . Last edited by lpawelek; 10-05-2023 at 05:18 AM.. |
aleksy7.00 |
10-05-2023, 06:21 AM | #93 | |
Rep 226
Drives: 2022 BMW X5 M50i
10-05-2023, 06:33 AM | #94 |
Rep 16
I used in BU option find STOPSCHILDER in those 2 ECU's:
[BDC_BODY3 7083] STOPSCHILDER Yes=01|No=00 [HU_MGU 3E52] STOPSCHILDER No=00|Gen1=01 Hope for your experience with this function I found on internet the file G07 Keylist with much more options of coding. It seems that this file is form Asian coder Last edited by lpawelek; 10-05-2023 at 07:09 AM.. |
postbox1918154.50 |
10-05-2023, 07:09 AM | #95 | |
Rep 226
aMIC31.00 |
10-05-2023, 07:13 AM | #96 |
Rep 16
postbox1918154.50 |
10-05-2023, 07:19 AM | #97 |
Rep 226
10-05-2023, 07:26 AM | #99 |
Rep 226
10-09-2023, 07:28 AM | #101 | |
182
Rep 332
My car is g20 not sure if i can do this Bambazonke |
10-26-2023, 02:12 PM | #102 | |
Rep 17
Is there anyone know if I need to code VFW_country or country_WWA for enable the TLA? Thank you |
10-27-2023, 04:08 AM | #103 |
Rep 451
No these are not required for TLA to work. The above coding is for Priority Warning ie Stop or Give Way Signs and for models built after 07/2020 traffic lights and WWA (Wrong Way Warning) There is no evidence that the enablement of the above 2 features is a prerequisite for TLA to work. Unfortunately I am not in a position to validate this as TLA does not work in Australia due to the map database missing Traffic Light Location data. WWA & VFW does not work here either and I cannot code it as it requires an FSC code which the dealer cannot supply
MY 17 X5 2.5d sDrive Last edited by Bambazonke; 10-27-2023 at 04:40 AM.. |
SBimmy1.50 |
10-27-2023, 06:03 PM | #104 | |
146
Rep 345
10-27-2023, 06:08 PM | #105 | |
146
Rep 345
10-28-2023, 08:39 AM | #107 | |
Rep 17
I have updated my BU to 1.0.64. Have you notice any missing codes for TLA for this version? Because i still cant get it work. ( it use to be work before i updated my car to 07.2023) |
10-28-2023, 09:30 AM | #108 |
Rep 226
The more newer software update you do on your car the less you can code , i disabled auto update in idrive and on the phone app since 03.2023 update because I lost the ability to code disable auto start/stop feature with that update.
SBimmy1.50 |
10-29-2023, 04:02 AM | #109 |
Rep 451
SBimmy
Did you copy my cheat sheet into the BU cheat sheet directory and enter the coding changes in comfort mode? or manually in expert mode. From previous experience with BU, i would save the NCD file after every change and then recheck it at the end. I have an old copy of Launcher Pro that reads cheat sheets and I usually open the modified file in LP just to double check the coding changes are correct before I upload to the car. There are no missing or incorrect labelling for my current cheat sheet in the latest version of BU v1.0.64
MY 17 X5 2.5d sDrive Last edited by Bambazonke; 10-29-2023 at 04:08 AM.. |
10-29-2023, 07:01 AM | #110 | |
Rep 17
Your current cheat sheet is the same as last year? Thank you |
