09-15-2023, 07:03 AM | #67 |
Rep 1,082
10-06-2023, 08:21 PM | #68 |
Rep 57
Just picked up a MY24 X7 M60 today and have the same problem. The highway assistant simply won’t pop up as an option. Everything else works great.
I went through all the steps to make sure data privacy and LED was enabled, along with being logged into BMW ID. Any ideas on resolution? My CA is not particularly aware. |
10-06-2023, 10:04 PM | #69 | |
Rep 2,106
Driver assist + won’t work if the trailer mode is enabled as well. Finally and this is obvious, but driver assist + won’t be offered to the driver unless driver assist is already enabled and road conditions permit. There are a long list of requirements documented in the owners manual. |
10-07-2023, 02:26 AM | #70 | |
Rep 57
The only other thing that comes to mind is the vehicle is still in run-in mode with power restricted. I’m wondering if max power must be available to have DA+ be active? |
10-07-2023, 09:15 AM | #71 | |
Rep 2,106
There were a small number of X5s delivered in July I think that didn't have the feature enabled from the factory. Not sure if it effected X7s. If you search the forum you can find some info. Going from memory i think there might have being some error messages on the screen about it though, but not the messages you describe which are typical when the system is restricted for various reasons relating to the driver. |
10-08-2023, 11:31 PM | #72 |
Rep 10
I tried high way assist on my new 2024 X5 50e for the first time. Turns out there are only 2 options, distance control and drive assist. When conditions are met there is a note on the dash saying driver assist plus ready. The when i let my hands go away from the steering wheel it automatically became assist plus, and steering wheel light indicators turn on.
Just post here in case someone is also trying to figure out how to turn that on as i was. |
10-09-2023, 04:53 PM | #73 | |
Rep 99
10-09-2023, 05:10 PM | #74 |
Rep 1,195
“Assist plus” shows up in my HUD and on the instrument panel only on limited access highways (freeways).
2024 X5M60i-- Skyscraper/Ivory
2020 Cayenne replaced by ^^ 2017 X5 35d--still in my diesel phase 2015 GL 350--diesel burner/highway queen 2013 Audi S6--a beast in it's day |
