04-17-2024, 12:38 PM | #1 |
Rep 451
Drives: 2023 BMW M4 Comp xDrive ; 2021
Spacer suggestions
I have a 2021 X5 40i with 22” stock wheels. I need suggestions regarding spacer size for rear and fronts at a stock height. I will appreciate if someone can share pictures as well. I really want to flush these rear wheels in that wide fender.
Thanks
23' M4 Competition X-Drive
21' X5 40i M-Sport 21' Toyota Tacoma TRD OR Insta: masmdm4 |
04-17-2024, 12:44 PM | #2 | |
Rep 1,080
https://g05.bimmerpost.com/forums/sh....php?t=1603269 Hit up Ben r33_RGSport and he can help you out with getting something for your X5 as well as provide recommendations. Post pics when you've installed your spacers! |
r33_RGSport12996.00 |
04-17-2024, 01:53 PM | #3 |
Rep 58
15/20mm spacers on 742M, 22” staggered. I would have gone 20/25mm. But good enough. Took over 500 miles. No shakes, vibrations.
r33_RGSport12996.00 LuckyBrand1360.50 |
04-17-2024, 01:56 PM | #4 | |
Rep 8,739
Drives: eVeRyOnE mAD!
04-17-2024, 03:18 PM | #5 |
Rep 626
I’m at stock height with the 22” 747M wheels, which have the same specs as the other 22” options. I have 12mm F and 15mm FC spacers.
Note: I have the 20” 748M wheels for winter, for those I would choose 12F/25R. Front is flush: Rear is almost flush (18mm would work): A shot that catches both rear and front: |
04-20-2024, 06:44 AM | #6 | |
Rep 451
Do you mind sharing zoomed out pictures of your car for me to get an idea of the look? Thanks
r33_RGSport12996.00 5ive7even141.00 |
04-21-2024, 06:24 PM | #7 | |
Rep 626
https://postimg.cc/gallery/jy7swJd Last edited by mmm50i; 04-22-2024 at 02:42 PM.. |
masab321347.00 |
04-21-2024, 06:36 PM | #8 |
Rep 89
Drives: 2024 X5 40i, E63s AMG
I have Future Classic (from IND) 12mm Front and 15mm Rear spacers on mine with the 742m rims and really like it. It is lowered on H&R springs.
04-22-2024, 12:08 AM | #9 |
Rep 1,145
Drives: 2022 x5 40!
04-22-2024, 09:52 AM | #10 |
Rep 89
Well, I also went from 20"s to 22"s at the same time so it is difficult to say. The ride is a bit stiffer than before, but I know the 22"s are probably having the greatest impact on the ride. I actually like the ride much better with the 22"s and lowering springs as there seems to be less body roll in the turns and and the X5 feels more responsive and planted without sacrificing a nice ride. Hope that helps.
04-22-2024, 02:39 PM | #11 | |
Rep 1,145
Drives: 2022 x5 40!
5ive7even141.00 |
