11-10-2020, 01:48 PM | #111 |
Rep 1,298
was it difficult to feed through the harness? Any advice?
11-10-2020, 01:50 PM | #112 |
171
Rep 301
I haven't fed it through the frame, just connected the control module with the harness.
Shawzy44
2024 BMW X1 28i 2023 BMW X3 M40i 2019 BMW 440iX M Performance Cabriolet |
11-10-2020, 02:34 PM | #113 | |
10
Rep 37
I got the same message when I first connected my harness to test it. I didn’t drive with it so no idea if it’ll disappear. I might try again today to test it with my boat trailer. |
11-10-2020, 06:25 PM | #114 |
Rep 6,883
If the hole has a grommet in it, is it large enough if you were to remove the grommet? Once removed, you could stretch the grommet onto the cable, and reinstall it, if so.
The other thing might be to buy a pin extractor, and take the pins out of the connector, slide the wire through, then reinstall the pins into the connector. |
11-10-2020, 07:33 PM | #115 |
Rep 1,298
This may help. This is the X3 hitch retrofit. However, the concept should be the same for running the harness.
11-10-2020, 07:43 PM | #116 |
Rep 1,298
here is another wiring kit instructions
11-10-2020, 07:55 PM | #117 | ||
171
Rep 301
Shawzy44
11-10-2020, 08:26 PM | #118 |
10
Rep 37
11-10-2020, 08:33 PM | #119 |
Rep 1,298
Well that’s a relief!
11-17-2020, 11:43 PM | #120 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
Re-posting here. Step-by-step Stealth hitch installation video - 2020 BMW X5. Enjoy
2021 X5, Excellence, M Sport, DHP, DAP, RSE, MW, Merino.
12-05-2020, 02:25 AM | #121 |
Rep 18
Installed stealth hitch with OEM wiring harness and control module today.
Harness can be fed through grommet just fine. You drill a hole with 5/16 drill bit. Cut from the hole to outside edge. Then push the grommet into the car frame. Opening where grommet used to fit is big enough to pull harness through. Then just push the wiring into the drilled hole in the grommet trough radial cut. Then pull/push grommet back out. I'll post few pictures later. The car threw "chassis stabilization error" and "do not drive with trailer connected" warnings. Drove a few miles - message persist. Asked BMW to activate trailer mode and it said that this car is not equipped with such function. I suspect some coding required after all? Maybe plugging a trailer would make it think it's all good? Hard to believe, but I'm hopeful Hardest part was removing fascia. Overall took me all day (9 hours) with all manual tools and figuring out how to unlatch side panels on 3rows car. |
12-05-2020, 06:52 PM | #123 | |
Rep 1,298
For my X6MC ships this week I hope. Do you have option 8SL trailer tow prewire? Awaiting pics.
12-05-2020, 07:02 PM | #124 | ||
Rep 18
I think trailer mode needs to be coded after all. |
12-05-2020, 07:55 PM | #125 |
Rep 6,883
On older models, yes, you did need to modify the coding for the computer to recognize the module. My guess is that this is still true.
BMW tends to use programmable modules that work in various models, so to ensure they work, you need to program them and the rest of the vehicle to recognize them and work right. Way back when, it only was about 3 items. |
01-08-2021, 11:43 AM | #126 | |||
171
Rep 301
When I plug my trailer into the coupling the trailer lights do work as expected. However, I get the following screens. Note in 1st pic, clicking on settings does nothing. I'll have it coded on Tuesday and see.
Shawzy44
01-11-2021, 03:58 PM | #127 |
171
Rep 301
Coded successfully!
Great coding write up to follow over on the X3 forum: https://x3.xbimmers.com/forums/showthread.php?t=1582562 Now I just need to fish the harness through and mount the coupler.
Shawzy44
01-12-2021, 11:11 AM | #128 | |
Rep 1,298
Congrats, good news. Thanks,
02-24-2021, 01:08 PM | #129 |
Rep 217
Hey all, reading this through thread and others and still a little confused on the appropriate Part #'s to order.
61129834453 is the wiring harness? What is the control module part #? 63116894066 appears to be correct, but wanted to see what others have ordered. I'm looking to use the BMW wiring with a stealthhitch. |
02-24-2021, 01:55 PM | #130 | |
Rep 1,298
I will post this again... 63-11-5-A05-6D0 AAA CONTROL MODULE 51-12-7-425-457 3C20G02 GASKET (optional x2) can re-use factory 61-13-6-840-334 3C20E14 POLLAK 61-12-9-834-453 AAA WIRING (Harness) If you are gong with Stealth Hitch LLC with the BMW Harness you don't need the POLLAK from BMW instead get: Pollak 11-893P 7-Way Sealed RV OEM Socket and Pollak 12-711U Right Angle Mounting Bracket for 7-Way Trailer Connector both can be found on Amazon. Also, optional, you may want to get some new stainless hardware for the Pollak connector, bracket and the bolts that attach the Pollak to the Stealth Hitch electrical bracket. The hardware that comes with this will rust in no time.
02-24-2021, 01:59 PM | #132 | |
Rep 1,298
Don't know, however there are a few threads on this and it may have been in the other ones. Hard to keep straight what is where....
