07-12-2023, 01:12 PM | #24 |
Rep 9
I also contacted BimmerCode yesterday regarding the update for the non-beta version. They have informed me that the update, which will support software version 7/2023, is expected to be available this Friday.
07-12-2023, 03:15 PM | #25 |
Rep 215
Awesome! You probably contacted them later in the day (US).
07-13-2023, 06:06 PM | #26 |
Unapologetic Tool Hoarder
736
Rep 966
Bit of advice for those that use BimmerCode. When you first connect to your vehicle at the start of each session, it makes a backup. Rename them with something meaningful like “Before Dazzle fix”. BimmerCode seems to like making unexpected changes and if you don’t know what you’re doing, it could be hard to roll back after you’ve gone too far. Example: Went to enable M layout on my daughter’s M340i. It changed the layout as expect but lost the M340i logo so I decided to switch it back immediately to the previous layout setting. It did BUT the M340i logo was still missing. Fortunately I had not made any other changes so I restored the backup and fixed it. Clearly it makes other changes and doesn’t drop bread crumbs so to speak for changing back.
07-17-2023, 09:05 AM | #28 |
Rep 215
I checked on Saturday and haven't seen any updates yet Using an Andriod device.
07-17-2023, 09:57 AM | #29 | |
Rep 9
SG Software GmbH & Co. KG 2:45 AM (8 hours ago) to me Hi, the update will be available within the next few days. -- Kind regards / Schöne Grüße Stephan Gauch -- SG Software GmbH & Co. KG Linsenäcker 18/1, 72379 Hechingen __________________ 2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 07/2023.23 |
07-17-2023, 10:30 AM | #30 |
Rep 1,021
07-18-2023, 03:22 PM | #32 |
13582
Rep 20,217
I didn't think they found a solution for the ASS issue yet so let us know if you are successful.
07-18-2023, 04:14 PM | #33 | ||
Rep 9
slilley51.50 |
07-18-2023, 08:47 PM | #34 | |
Rep 215
07-18-2023, 09:53 PM | #35 |
736
Rep 966
I haven't used it extensively for a while and I remembered it being easier to rename, etc. Not sure if it's changed or I misremembered. You can go into the BimmerCode settings menu and then manage files. That just takes you to the BimmerCode backups folder which can also be accessed from your iPhone files menu. You can see all backups for all modules in there. Best to add a meaningful name/moniker there with the rename function. Changing that doesn't seem to update the naming in the main app though so you'll have to compare the renamed file timestamp with the backup timestamp in the app for restoring. The moniker will also help in deleting unneeded backup revisions.
07-31-2023, 07:32 PM | #37 | |
Rep 172
Coding ASS off
07-31-2023, 07:55 PM | #38 |
257
Rep 332
Some people consider ASS an annoyance at best, while others will debate as to whether it contributes to more wear + tear on the starter + engine. A few people have also commented on the inconvenience of ASS in stop+go traffic since it will also turn off the A/C when the engine stops. I've experienced this myself but still have the ASS button by the shifter so I can disable it at will. Finally, BMW will tell you that ASS is intended to provide better fuel economy, so there is much debate there as well - no comment from me
2020 BMW X5 M50i . Tanzanite Blue II . Black Merino . Extended Shadowline . 742M Black / ART Replica 181
07/2019.55 (since birth Oct.1,2019)-> 11/2019.70 (OTA Aug.11,2020)-> 11/2020.36 (Dealer Nov.25,2020)-> 03/2021.50 (OTA Jun.15,2021)-> 07/2021.85 (OTA Mar.1,2022)-> 07/2022.58 (OTA Dec.9,2022)-> 11/2022.60 (OTA Mar.2,2023)-> 03/2023.50 (OTA May.31,2023)-> 07/2023.35 (Dealer Aug.21,2023)-> 11/2023.50 (OTA Feb.9,2024) |
07-31-2023, 08:47 PM | #39 |
13582
Rep 20,217
The benefit would be the ASS is off, how important that is would be up to the individual. I keep mine on but it bugs me almost every time I park my X5 in the garage. I would code it off, like I did on the M340i, but it doesn’t bother me at other times.
07-31-2023, 08:56 PM | #40 |
Rep 8,803
Drives: eVeRyOnE mAD!
on my wife’s previous G30, whenever the engine stopped at a light due to ASS, I would quickly release the brake pedal then press it again (as I’m at a stop). doing so fired up the ICE; no start-up lag upon acceleration. I also didn’t have to worry about the AC shutting down. does this work on the X5?
08-01-2023, 12:21 AM | #41 | |
Rep 412
08-01-2023, 12:19 PM | #42 |
10
Rep 42
08-01-2023, 01:02 PM | #43 |
13582
Rep 20,217
They usually keep the major version in the field for a few months prior to releasing it as an OTA. The iD8.5 update is scheduled for OTA in September so they likely will send the 07:2023.xx as and OTA to everyone.
08-02-2023, 04:19 AM | #44 |
10
Rep 42
thank you .mine is ID 7 so most probably i will receive anything much later ?
