      01-20-2023, 06:55 PM   #1
Bking60
Drives: BMW X5 2019
Tools for rear brake replacement
I went ahead and got these tools since new rear pads will eventually be needed. The 3-prong adapter does not seem to be included in any non-BMW kits. Both are 3/8 drive.
The 3 prong was on sale on amazon for $12.
The wind back tool was $15 on amazon. It's more heavy duty than most others online.
I have not used these but certain they will work.
Also need bimmerlink or a better one like Burger Motorsports.
      01-23-2023, 05:39 PM   #2
RumblePhytonic
Drives: 2023 45e Msport
Electric parking brake- It does not work that way anymore. Remove the electric motor off the caliper and spin it back manually with a bit or 'service mode' it.
      01-29-2023, 11:07 AM   #3
Bking60
Drives: BMW X5 2019
Thats the other way that results in a brake code for many that tried it.
I have $25 in tools plus bimmerlink or better to do it right.
      02-06-2023, 06:05 PM   #4
ladra
Drives: X5 (G05) 2021
Bking60,
Please keep us posted on how your rear pad change goes. Steps would be appreciated, if possible. So many different stories out there, I wish someone would come up with a 'correct' procedure for the rear.
In case you are not tracking, from what I have read you must DISENGAGE (turn off) the e-brake before starting the job. Good luck!
      02-08-2023, 09:05 AM   #5
Bking60
Drives: BMW X5 2019
Originally Posted by ladra View Post
Bking60,
Correct, retract the "e-piston". I won't be doing this for a year or more, we mostly use the car for trips. I have a case of preplanning, always buying parts and tools in advance. I've seen too many things discontinued where I'm forced to pay more later. I always spray the back of the pads with CRC anti squeal in the red can, it says to let it dry for something like 30 minutes, but I spray them the night before and never have any squeal. I think new spring clips come with bmw and oem pads which is necessary and lots of cleaning plus grease the caliper pins. Also read where you need a very stubby 1/4 drive 7mm hex tool.
      06-02-2023, 08:54 AM   #6
Marty in NY
Marty in NY's Avatar
Drives: 21 X5 40i, 18 GTi, Snowblower
Here is a thread on this topic that explains how to retract the rear e-brake piston without throwing codes, you can read the entire thread but post 92 is the procedure this person used.
      06-02-2023, 07:25 PM   #7
gfeiner97
Drives: X540i
forgot the thread link
      06-02-2023, 07:51 PM   #8
Marty in NY
Well, that surely sucks! Maybe this will work.. .. -->https://g05.bimmerpost.com/forums/sh...ke+pads&page=3
      09-09-2023, 06:20 PM   #9
kgelfen360
kgelfen360's Avatar
Drives: BMW
I tried using BimmerLink. I am getting an error inside BimmerLink app HOWEVER I do hear the noise of EPB retracting. Has anyone experience this?
      09-22-2023, 03:25 PM   #10
Big_CG
Big_CG's Avatar
185
Drives: 2020 X5
Has anyone actually done the rear m sport brake pads and can advise what tool is needed to wind back the caliper? Besides bimmerlink, obviously we have to enter parking brake service mode. But the caliper piston also has to be retracted to make room for the new pads.
      10-01-2023, 10:10 PM   #11
Bking60
Drives: BMW X5 2019
Same tool as in the OP I would think.
