08-16-2020, 11:46 AM | #1475 | ||
Rep 235
2M Ethernet to OBD Interface Cable E-SYS ICOM Coding F-Series for BMW ENET https://www.amazon.com/dp/B07Y5FJ695..._ykwoFbH94JYVS And Lighting Ethernet Adapter Phone Ethernet Adapter Network Pad Ethernet RJ45 100Mbps by Enbia Grey https://www.amazon.com/dp/B07VK8Q36S..._xlwoFb25B7WFK |
edtreo88.50 |
08-16-2020, 01:34 PM | #1476 |
805
Rep 1,790
I'm having a hard time understanding why all of you are using cables. That's the whole purpose of getting one of these. https://burgertuning.com/products/mh...-flash-adapter.
This is basically giving you the functionality of a wired Ethernet connection without the wires. The above adapter is compatible with iOS and Android. |
08-16-2020, 02:09 PM | #1477 | ||
The Dark Knight
421
Rep 1,262
08-16-2020, 04:16 PM | #1478 | |
The Centurion
137
Rep 451
I was told it's no longer supported for certain modules. Then I wanted to code anti dazzling 5AP Which isn't possible via BimmerCode. So I went the wire route to be able to do that via Esys while having the capabilities to do any other app in the future without the compatibility concerns.
From the East to the West through the rest of the World
09-07-2020, 10:52 PM | #1479 |
Rep 11
(Apologies if bumping this thread is not the best place for this Q). I've attempted to code ADV on my G05 via Bimmercode expert mode using the instructions provided by LexxM3 earlier in the thread. All 4 of the codes required were available in Bimmercode.
When I coded the options, a "Driving Assistant Permanently Disabled. You may continue driving..." etc message appeared. I reverted to a backup (the message appeared again but went away) and Driving Assistant is still working fine. I fired up ISTA+ and there was a fault for 'incorrect option' or similar (I thought I had a screenshot of this but apparently not!), which I cleared. Vehicle is Oct 2018 build and has the S5AU option. Bimmercode reports that the i-Level is currently S18A-20-3-558 (18-7-540 at delivery). Silly me didn't actually check ADV/drive assist functions when I first got the error -- so I can't confirm if ADV activated or not before reverting to backup. Before another attempt, is this message expected as part of the ADV coding process? If not, ideas as to what triggered the error? Thanks for any info! PS: I'd love to code Automatic Speed Limit Assistant but if I've read the thread correctly this still can't be done even in Bimmercode expert mode? PPS: has anyone here ever had a wheel swap and updated their VO to see if the on-screen image of their vehicle shows the correct wheels? I had mine swapped by the dealer at purchase and was just curious if the display is based on VO coding or hard-coded at build. |
09-08-2020, 01:06 AM | #1480 | |
Rep 2,609
BimmerCode App just updated..
5AU should be the right option, but your car is one of the very first G05 builds, so almost anything was possible at that point. Since you know you can "fix it" by a backup restore, it's probably worth a shot to try again with care and power cycle the car a couple of times to see if the displayed error is persistent.
09-08-2020, 02:04 AM | #1481 | |
1197
Rep 1,587
As lex said, lots of error messages occur during the coding process. ISTA records hundreds of non-persistent messages just in normal usage, even when coding is not used. Personally I would clear all Errors in ISTA. Re-run the identification and test report and see which persistent errors remain if any. That's your baseline. If you have an option error at this point its not ADV coding related- maybe your steering wheel? Next code ADV, shut the car down, restart and confirm the idrive error has gone. Confirm ADV is working then rerun ISTA. Clear the error codes and re-run the ID and test process again. Compare with your baseline. I'd wager the coding is doing nothing more than activating ADV, but there's always a first time. aSLA cant be coded with BC |
09-09-2020, 05:38 PM | #1482 |
Rep 11
This is the correct answer.
In case anyone else encounters the message and this thread via search: I ensured that all faults were cleared in ISTA. I then drove for a while to ensure no new faults. I coded ADV using BC expert mode and the "drive assistance permanently restricted" message appeared again, but this time I checked and ADV was now an option in Displays settings. I went for another drive and DA also worked fine. There was a new fault on HU-H in ISTA related to the alertness monitor, but after clearing that and a few drives nothing else has appeared. I haven't done any 'proper' coding since 2015 when upgrading a combox in an E70 and that experience is no longer of much value. I've got e-sys 3.33 but only the old version of launcher pro so I'll probably get esysx and endeavour to code aSLA, which seems far more useful than ADV. A few (dozen) hours of study are probably warranted before going down that path. :-) |
09-10-2020, 12:58 AM | #1483 | |
1197
Rep 1,587
09-10-2020, 09:52 AM | #1484 |
1053
Rep 1,952
exactly - never understood the hype around getting ADV or having it on all the time. When I have adaptive cruise on, my ADV turns on but I honestly never even pay attention to it. It's just a "oh that's kinda cool" type deal.
09-10-2020, 11:18 AM | #1485 |
13223
Rep 19,708
I feel the same. I coded mine to have it but after testing it out I didn't see any value in it so turned it off.
09-10-2020, 12:59 PM | #1486 | |
Rep 2,609
But yeah, as it stands it's just cute. I keep it on mostly to just fill the space in the dash. I won't hold my breath, but I really do hope that this is just the first try — as a first try, it's impressive, but if it doesn't evolve, it will just be another pathetic lost opportunity to make something actually great.
09-11-2020, 04:13 AM | #1487 |
Rep 480
Yesterday I was upgraded by the garage to 07/2020.45 and can confirm that after the upgrade I can no longer code the BDC module with Bimmercode. All others work fine. I use an Enet cable with lightning<>ethernet converter on my iPhone Xs. Previously that worked fine on 03/2020.xx
09-12-2020, 12:59 PM | #1488 |
Rep 1
Hi I was playing with the BimmerCode and was trying to change the dashboard layout to M mode and decided to change it back to normal bmw mode. I found an issue with the Hybrid value in my journey data and it seems to reset by itself and it is starting from zero even though I choose the ex factory mode in the journey data. Please shed some light with this matter and I would like to get back my hybrid mileage in my journey data. Thanks
09-12-2020, 02:26 PM | #1489 | |
Rep 5
09-13-2020, 05:19 PM | #1490 |
Member
898
Rep 2,031
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [10.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
Does anyone know if the Fog Lights can be programmed to come on automatically when the lights come on?
2019 X5 Alpine White M-Sport
Software Version 11/2022.31 2023 M2 (HEA) Brooklyn Gray 2021 330i XDrive Alpine White M-Sport |
09-30-2020, 09:14 AM | #1492 |
Starfleet Command
315
Rep 785
Any thought on when new version to control BDC will be avail ... last I heard the beta ver supported. but seems like new release is overdue. How can I obtain beta for bimmercode?
2020 X5 M50i Phytonic Blue w/ Black Merino
22" 747M wheels, |
09-30-2020, 11:07 AM | #1493 | |
13223
Rep 19,708
Put a support request in through the app and request to be a beta tester. |
10-18-2020, 02:15 AM | #1494 | |
Rep 242
Hi Alexdragu, can you tell me which program you used to activate lane change assist on your g20? I have a g21 and I would active the same (I have drive assistance plus but in Italy the lane change assist is disabled) Is it possibile with BimmerCode app on iOS? (Maybe with expert mode) Thanks a lot Francesco |
11-16-2020, 01:55 AM | #1495 |
Rep 2,609
Bimmercode for iOS was just updated a few hours ago to 4.0 (11767) on the App Store. Everyone who's had trouble with 07/2020.xx and Bimmercode functionality (eg BDC not supported) should give it a shot.
11-16-2020, 05:29 PM | #1496 |
Rep 7,468
Has anyone checked to see if the IOS version moved the multiple ambient light color selection to the EASY side?
