      01-05-2019, 11:59 AM   #1
magna6882
162
Drives: 2017 audi q7
curb lights
the manual indicates there are curb lights that respond to steering angle. On our q7 when turning into the driveway clearly a light comes on illuminating the side. i dont see any change on the x5. have any of you guys noticed the light?
      01-05-2019, 02:11 PM   #2
ScottMZ3
Drives: 2018 Camaro ZL1, 2019 X5 40i
I was thinking this too. The cornering lights don’t seem to come on. They were obvious on our 2016 528i.
- Scott
Current Cars: 2019 X5 xDrive40i M-Sport, 2018 Camaro ZL1
Past BMWs: '16 528i, '00 M-Coupe, '14 X1 sDrive28i, '00 740iL, '02 325i, '99 M-Coupe, '00 323Ci, '79 323i, '83 320i
      01-05-2019, 02:18 PM   #3
puraj83
Drives: 2022 x5 m50i
I haven't noticed them either... Hmm.
      01-05-2019, 04:58 PM   #4
Aliendrive
Aliendrive's Avatar
Drives: 23 X3 M40i 24 X3 M40i
2023 X3 M40i  [0.00]
Mine comes on and is noticeable when turn signal is on
      01-05-2019, 06:27 PM   #5
BMPHIL
BMPHIL's Avatar
623
Drives: 2024 M60i
Would have thought turning the steering wheel should operate them not the turn signal.
      01-05-2019, 07:15 PM   #6
magna6882
162
I used the turn signal and dont see anything change on the lighting
      01-05-2019, 11:43 PM   #7
ScottMZ3
Can someone take a picture of them on?
FYI, we have the Laser Lights.
- Scott
      01-06-2019, 02:47 AM   #8
MysticBlue
369
Drives: '20 M5C, '09 M3 DCT Coupe
Are you turning them on to the "auto" position or just turning them on to the "on" position? In the past, turn lights or curb lights only work in "auto", not "on". They should also come on when putting car in reverse (assuming selector switch is in "auto").
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra.
      01-06-2019, 03:04 AM   #9
BMPHIL
BMPHIL's Avatar
623
Drives: 2024 M60i
Must work differently than on my Merc where they only come on when you turn the steering wheel!.
      01-06-2019, 03:23 AM   #10
MysticBlue
369
I should add, since they are in "auto", they will only come on if it's dark enough for the lights to come on.
This is all based on previous models I've owned. I don't know if the G05 is the same.
      01-06-2019, 09:09 AM   #11
cygnusecks
cygnusecks's Avatar
Drives: X5 (G05)
My custom online manual says I have them too (referred to as a "Cornering Light"). I don't have laser lights. But I too have not seen them in action yet ...
      01-06-2019, 11:09 AM   #12
ScottMZ3
Yes. Headlights have been in "Auto" mode since we picked the car up. In our 528i we traded in they were very obvious when in reverse, with the blinkers on, or when turning the wheel. In the 528i's case the inner of the 2 "headlights" acted as the cornering light and would come on (not LED or HID, so was easy to see the additional yellowish light).
- Scott
      01-07-2019, 06:39 PM   #13
magna6882
162
Can you tell if the light comes form a second light or do the headlights move? Is there another small led i cant find?
      01-07-2019, 07:51 PM   #14
Aliendrive
Aliendrive's Avatar
2023 X3 M40i  [0.00]
I checked my laser lights tonight and mine are not working either. I thought they were working last week with blinker on and when the wheel was turned half way thru turn. I remembered thought it was weird that they were delayed coming on compared to my past cars or my 2018 X3. I tried with light on , auto, and auto high beams. No difference. Also checked to see if corespondent fog light would come but it didn't. If they start working I'll repost.
      01-07-2019, 07:57 PM   #15
screamace
screamace's Avatar
304
Drives: 2020 BMW X5M Competition
I have that on my G30 and it's very noticeable. It will delay for a couple seconds after flickering turn signal, but the side or curb is illuminated very well.
2019 Porsche Panamera 4 E-Hybrid
Past BMW: 2018 M550i, 2016 X5 40e, 2014 335xi, 2011 X5 50i, 2010 550i
      01-07-2019, 08:06 PM   #16
JayPichardo
BMW Client Advisor
JayPichardo's Avatar
3452
Drives: 2020 M340i
2020 BMW M340i  [0.00]
I need to test this on one of the cars.
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com
Top M Client Advisor in New England.
      01-07-2019, 09:57 PM   #17
tqbmw
Drives: 2013 F10 550
Pretty sure it's the fog lights that come on for this. On the G05 fogs don't make as much a difference due to better lighting by the headlamps (led or laser lights). So it's not as noticeable but it does happen.
      01-07-2019, 10:29 PM   #18
Auricom
Auricom's Avatar
Drives: 2020 X5 xDrive40i M Sport
Cornering lights are integrated into the headlights. See item 5 for adaptive LED and 8 for laser.
Not sure if the L/R fog light also illuminate with corresponding turn signal on G05.
On the F15, cornering lights were integrated in the fogs and would activate:
- only under 25MPH
- when turn signal is used
- when reverse is activated
- by large steering angle
      01-07-2019, 10:39 PM   #19
MatchboxM1
MatchboxM1's Avatar
59
Drives: 2022 X5 M50i
Coming from a 2017 Rover, I have been really impressed with the fog lights. Make a noticeable difference on mine. Standard adaptive LEDs. But I guess I do also drive on very dark narrow town streets and tight mountain canyon roads.
      01-07-2019, 10:55 PM   #20
magna6882
162
I find it odd that the feature is listed everywhere but there are no pictures or confirmation it even exist. We have a fairly large group here so my guess is it doesn't exist. I looked really close at my front end and i cant find anything.
      01-07-2019, 11:14 PM   #21
Auricom
Auricom's Avatar
See my post above. They exist. It's the inner most lighting element next to the slant closest to the grill in the headlight unit.
Manual states the conditions on how it's activated:
Adaptive light functions are active when set to AUTO
In tight curves, for instance on mountainous roads or when turning, an additional, cornering light is switched on that lights up the inside of the curve when the vehicle is moving below a certain speed.
In the F15 that certain speed was less than 25MPH
The cornering light is automatically switched on depending on the steering angle.
Usually it's more than 15 degrees.
When driving in reverse, the cornering lights may be automatically switched on regardless of the steering angle.
Both cornering lights come on in reverse.
Xeno313.00
      01-08-2019, 10:28 AM   #22
ScottMZ3
I'll have to ask the service department about ours then. They don't illuminate on ours...ever.
- Scott
