      04-13-2019, 09:57 PM   #67
skalberti
skalberti's Avatar
Drives: 2017 Mineral White M3
Originally Posted by speuk View Post
Originally Posted by Hchhuor View Post
I was able to run the cable for rear cam. All you need to do is pop open the speaker penal and rear hatch.
Just installed my rear camera, tricky to get through the rubber grommet for the lower cable s and then out through the double skin. I really needed longer fingers to grab the nylon guide/ cable puller I was using. After that it was easy to feed through the rubber tube to the tailgate. Took a bit longer than the F15! Trim is pretty much the same as F15.
Make sure you get that rubber boot put back correctly. There's a groove in the boot that the metal seats into. It's very hard to push that boot back in and have it seat correctly. If it's not seated correctly you'll have a wet cargo area.
It's good to be bad
      04-13-2019, 10:14 PM   #68
Hchhuor
Drives: 2016 LX570
The fuse paper manual that I found from 2019 x3 forum really help a lot. Without that I would not know where f27 is at. Other post F20 and f53 without picture I would not know which is f20.
Best way to find the correct wires is to use a low voltage test light and test the fuses for switched and constant. Fuse powering varies from vehicle to vehicle. Posting a picture of the fuse box and fuse numbers still may not give you the correct fuses for your X5.
I did use fuse test light.
      04-14-2019, 01:40 AM   #69
speuk
Registered user
United Kingdom
78
Drives: G05 3.0d MSport / F23
2010 f07 SE GT  [0.00]
Indeed much harder than the F15 boot which just snapped back in but it is seated correctly
      04-15-2019, 08:55 AM   #70
edikam
edikam's Avatar
Drives: 2024 X5 M60I Carbon Black
2024 X5 m60i  [10.00]
How do you connect to f27 or F76 is they both +, how do you connect -?
I was wondering how do you connect two wires to fuses. One should be negative and positive. How do you connect it to camera since it is always on.
I reconnect my blackvue magic pro wire today with f27 battery which is empty slot(mini fuse tap) and f76 for acc aslo Emory slot (standard fuse tap). If you plan to used f27 and f76 you need to have extra fuse. There no need to take off the right panel. Super fast and simple way.
      04-15-2019, 09:05 AM   #71
Hchhuor
Drives: 2016 LX570
For blackvue magic pro parking mode there 3 wire battery, acc and ground. F27 for battery alway power and F76 for ACC only come on when car turn on
      04-15-2019, 11:39 AM   #72
edikam
edikam's Avatar
Thank you. So fuse F76 is on only when car ignition turned on?
      04-15-2019, 11:44 AM   #73
Hchhuor
Drives: 2016 LX570
Yes
      04-19-2019, 05:11 PM   #74
Xeno
Xeno's Avatar
315
Drives: 2019 X5 M Sport 5.0i
I have a BM mount for my V1, but would there be enough room to use another BM mount for the BV 900S-2C?
My installer says the BV comes with an adhesive for the windshield which reduces glare so does that look okay in a G05?
(Apologies for cross post, but no one is using the subforums.)
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired
R360c + EL, V1G2 + V1Driver, Uniden R8
      04-20-2019, 11:43 AM   #75
Hchhuor
Drives: 2016 LX570
I used blendmount BBv-2030 for dashcam. The way I use dashcam Mount is not correctly installed cause I want dashcam closer to windshield and I plan to add escort radar mount to bbv-2030. As you can see there are 2 empty screw slot to mount radar to. I'm just waiting to get cheap escort radar mount on eBay. I want to use this spare part radar clip part number BBE-UC4
Xeno315.00
      04-20-2019, 01:23 PM   #76
Xeno
Xeno's Avatar
315
Thank you. Looking at the BM web, I could not tell if 2030 or 3032 was the best for us.
I do not see a way for two separate BM mounts to fit that tight space and a BM dealer confirmed this as well.
In the meantime, the dealer electronics tech claims that using the BV windshield adhesive places it in a good position to reduce glare. I will start with that install and see if I need to work toward another solution.
BTW, if you have not already purchased your Escort you might want to look at the lively discussion on RDF about the new Uniden R7 which has the longest range (WS detector) with arrows. However, if BWM is a priority due to a congested daily commute then Escort has made some progress has seen in the new EL app.
      04-20-2019, 01:38 PM   #77
Hchhuor
Drives: 2016 LX570
I almost bought the r3 last for $288 but have I had 2 9500 and max 360. I want to stay within escort mount. The only different between 2032 and 2030 is body link part number bm-sp-0001
      04-21-2019, 07:26 AM   #78
Xeno
Xeno's Avatar
315
Where did you order your BM? How long did it take for delivery?
      04-21-2019, 09:03 AM   #79
Hchhuor
Drives: 2016 LX570
From blendmount please my referral link to save 12% off. They ship out using post priority mail 2-3 days working day. They ship 1 or 2 days after order is place. I received less then 5 working days.
http://blendmount.refr.cc/hengchhuor
      04-21-2019, 09:35 AM   #80
Xeno
Xeno's Avatar
315
Much appreciated! Thank you.
Unfortunately, I need the BM for my 1 pm install in Monday which means pay $100 for early overnight delivery. If I put up that kind of money, I want to make certain that my BM clip for my V1 will attached to the BBV 2030.
Have you encountered problems like the BM moving too much because you needed to tighten some of the screws?
      04-22-2019, 11:33 AM   #81
Xeno
Xeno's Avatar
315
I just heard from BM moments ago and they said based on your photo, that I should use BBV-2018. They do not official support the notion of added a RD clip to this but are aware 'it has been done'.
When you finish, please post a photo of your work.
      04-22-2019, 11:39 AM   #82
Hchhuor
Drives: 2016 LX570
I have been searching for a photo of adding a RD clip to the BV version of the BM but have not located such at this point.
I try 3 different model.
Xeno315.00
Cooltones241.00
      04-22-2019, 11:49 AM   #83
Xeno
Xeno's Avatar
315
Thank you.
There are photos of an actual install that includes a RD in post #1 of this thread:
https://g05.bimmerpost.com/forums/sh....php?t=1586693
      04-22-2019, 12:04 PM   #84
Hchhuor
Drives: 2016 LX570
Thank you.
I finished my blendmount dash installed before February 05 and took about over 10 days to get blendmount to ship me the right mount I want.
      04-23-2019, 08:48 AM   #85
Xeno
Xeno's Avatar
315
I am still thinking about the BM, but here is my current install:
      04-23-2019, 01:15 PM   #86
Hchhuor
Drives: 2016 LX570
You can add this for your blackvue BBV-UP2 and BM-SP-0001
to mount your radar in the enphold in the middle of this part number.
Xeno315.00
      04-23-2019, 01:47 PM   #87
Xeno
Xeno's Avatar
315
So you paid $230 for BM parts? 140 + 70 + 20?
      04-23-2019, 01:54 PM   #88
Hchhuor
Drives: 2016 LX570
No, I have not buy the extra part the radar yet. I have 2030 only for dashcam.
