      07-02-2019, 09:03 AM   #89
stevoplaystation
Drives: X5 G05
G05 dashcam start/stop not working
Hi, got the blackvue CH900 F&R with the power magic pro installed professionally
the start/stop has stopped working now just has a line through. is there some reason for this? is it the wrong fuse being used ? anyone can shed some light?
      07-02-2019, 09:19 AM   #90
Xeno
Xeno's Avatar
315
Drives: 2019 X5 M Sport 5.0i
Search this thread:
https://g05.bimmerpost.com/forums/sh....php?t=1586693
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired
R360c + EL, V1G2 + V1Driver, Uniden R8
      07-27-2019, 08:17 AM   #91
eagle_bmw
Drives: 2019 BMW X5 40i
Has anybody tried installing a battery pack (BlackVue B-124 or Cellink Neo)? Where's the best position to completely hide the wires? Seems like no hole in the glove to fuse box to fish the wires.
2019 X5 40i M-Sport
07/2020.54 -> 11/2020.50 -> 03/2021.50 -> 07/2021.85 [All OTAs]
      07-27-2019, 08:26 AM   #92
Tim2189
Russian in a Bimmer
Tim2189's Avatar
Drives: X5 M50i
I put the battery pack under the passenger seat, in front of the footwell of rear passenger
2013 X6 - retired
2015 X6 - retired
2015 435GC - retired
2018 X5 40e - retired
2020 X5 M50i - Current
eagle_bmw182.50
      07-27-2019, 08:49 AM   #93
doctorttt
Drives: 2020 G06
Hi, I'm also in NYC. Just curious - do you have any safety concerns of leaving the battery pack inside your car (i.e. leaks, explosion, etc.), especially when NYC experienced extreme high temperature over the last two weeks?
      07-27-2019, 10:38 AM   #94
eagle_bmw
Thanks! What's your recommended path to route the main camera and fuse wires to the battery?
2019 X5 40i M-Sport
radmjk240.50
samvora422.00
      07-27-2019, 11:44 AM   #95
Tim2189
Russian in a Bimmer
Tim2189's Avatar
Drives: X5 M50i
Nope never had a thought, if that battery pack fries then im sure it wont be the only thing to go.
In my other car (x5) I took it to a shop (oneeighty) and they hardwired it to the car and it'll stay on for about 2-3 hours and then turn off when parked.
2013 X6 - retired
2015 X6 - retired
      07-28-2019, 11:41 PM   #96
eagle_bmw
I haven't opened the front passenger fuse box but the one in the cargo doesn't come with the fusecard. I downloaded mine from:
https://www.bmw.ie/en/topics/owners/...xsYmFjay5odG1s
The fuse box in the cargo area has plenty of space to place the battery pack (blackvue or cellink). My problem is all fuses, while mostly switched (except for F217 which is always on), have ~10 min delays before powering off. Some actions like opening door(s) result to power switching on. I think this is bad for the car battery with at least 9A draw from the battery pack. Could have been good setup.
Looks like I have to go to the front fuse box. My battery pack hasn't arrived yet but it looks like it would fit the glove compartment. I really want all wires hidden including the battery pack.
Any inputs from others who have set up blackvue with a battery pack?
      07-29-2019, 11:31 PM   #97
eagle_bmw
I had a chance to open the front passenger fuse box by the kick panel. It looks like, though, that all switched fuses do not turn off immediately after the ignition is turned off. Similarly, fuses have 12V when doors are opened (e.g., F53).
nyc328ci , would you mind sharing if your battery pack is still powered after you turn the car off, or after any door is opened? Thanks!
2019 X5 40i M-Sport
      07-30-2019, 06:23 AM   #98
Simon.iv
Drives: Bmw x5 30d
Originally Posted by AndroidRobot View Post
Has anyone hard wired a dash cam or dash + rear camera yet? I'm likely getting the Blackvue DR900S-2Channel and wanted to see if anyone had trouble getting it installed? I'm not doing it myself because the X5 had a lot of electronics I'd rather not mess up
I have a pro mechanist to install blackvue on my G05. Basically, he said blackvue with magic pro will not work for this bmw (work well for my previous RX350) so he suggest to buy a blackvue external battery for this dashcam.
Then I had it and used for almost 3 months without any issue. Only thing we need to do is drive the car at least 1 hour a day so the battery will be charged for parking mode.
That's pretty simple. Except the blackvue battery will cost us a few hundred bucks.
The video attached is the auto braking activated for no reason in the middle of traffic.
https://streamable.com/s/x549i/jkxgfi
      07-30-2019, 07:43 AM   #99
Xeno
Xeno's Avatar
315
My dealer's electronics shop did the install of my BV900S-2 Channel. They insisted on including the magic pro.
I have not had serious problems and am not certain what role the BV plays in occasional battery issues reported in this thread:
https://g05.bimmerpost.com/forums/sh...hlight=battery
      07-30-2019, 09:05 AM   #100
Simon.iv
Drives: Bmw x5 30d
Obviously, the magic pro did not work properly as it supposed to prevent the BV suck all the vehicle's battery.
That's why the mechanist suggest me to have the blackvue external battery. And as they mentioned blackvue has recommend this for most of new german cars like mercedes & audi.
I guess having an external battery is a safe option while they figuring how to make it work with magic pro.
      07-30-2019, 10:47 AM   #101
Xeno
Xeno's Avatar
315
Neither me nor my dealer have been able to determine with certainty that the BV triggered the battery warnings I reported in a separate thread.
I do not routinely use the parking mode and the first time I saw the battery warning was during a month of driving on the open road.
Other considerations relate to how frequently the G05 turns on and turns off. When I walk around my car in the garage, it will turn on and off multiple times. If I leave my key on an adjacent vehicle in my garage and walk down the driveway to get mail, again the car will turn on and turn off multiple times. Then of course every time I go to the car in the garage to follow up on a post from this forum we have the power staying on another 15 minutes.
I have a V1 that is hardwired and goes off with the ignition. I also have an R7, but I unplug it on days when I am not driving the G05.
      07-30-2019, 11:19 AM   #102
Simon.iv
Drives: Bmw x5 30d
Im not so familiar with mechanical stuffs, however I guess going with external battery will be a safer option for your car rather than magic pro as I can see many people having issue with magic pro as well as my mechanist said.
You can read this thread as well : https://x3.xbimmers.com/forums/showthread.php?t=1454576
Hope you find a good solution for your dash cam.
Cheers
      07-31-2019, 01:59 PM   #103
Ken6096
Ken6096's Avatar
108
Drives: BMW X5M F95 2022
Just got The blackvue dr900s 2 channel set up professionally at Abt. They did pretty good job.
Did not have extra battery and parking mode because worried about car battery problem . The price with all setup with tax is around $722
BMW X1 F48 2017 sold
BMW X5 G05 50i 2019 sold
BMW X5M comp F95 2022
Mini clubman JCW F54 2019
      07-31-2019, 02:09 PM   #104
Tenac
Tenac's Avatar
4539
Drives: All
Curious why is the camera looking at you?
2022 M8 Comp Convertible
2023 718 Cayman GTS 4.0
2019 718 Cayman Base
2015 M235 Manual
On the list for the M2 CS
      07-31-2019, 02:48 PM   #105
Ken6096
Ken6096's Avatar
108
I dont want them to install it at the rear . The one you see that turn to me is the rear camera which i ask them to install it at front to see passenger room.
      07-31-2019, 05:15 PM   #106
Simon.iv
Drives: Bmw x5 30d
Im curious about the video quality compared to 750 version. If you could post a video that would be much appreciated.
Parking mode is a must at where I live as there are so many lousy driver here lol....
      07-31-2019, 05:27 PM   #107
Ken6096
Ken6096's Avatar
108
I dont know how to post the video here and not sure the file will have original quality as 4K. The front camera has 4 k resolution which is stunning while the rear camera has the same camera as in 750 which give you Full hd 1080 P quality which you will see the different.
I mostly park in garage and get o work and also park in private garage so dont really worried much snd no need for parking mode. We usually travel as family so reccording in passenger room could be fun. Also if some one stealing my car so i can see who are they lol or may be doing a fake taxi XD
I tried to post the video but it said “invalid”
      10-01-2019, 09:08 PM   #108
elbandito
Drives: 2019 BMW x5 40i
Any consensus on where to tap a fuse for the hardwire? Exposed wires are a pet peeve of mine and I’d ideally like to tap it to a fuse box in the back
      10-02-2019, 02:13 AM   #109
OzJedi
Australia
107
Drives: X5 2019 40i MSport Carb Black
Originally Posted by Hchhuor View Post
Blackvue power magic ez installation
I read in some other thread that there still issues with Magic Pro and there is a considerable battery drain. I even contacted BlackVue support but didn't get a proper response, just a standard response.
      10-02-2019, 11:14 PM   #110
Ken6096
Ken6096's Avatar
108
iOS 13.1 cant connect blackvue with direct WiFi from phone. Cant download the file via WiFi. This is suck. Most of blackvue user in forum complaint about this, just to let u guys know if you have the same problem
OzJedi107.00
