      11-23-2019, 11:21 AM   #67
AndroidRobot
AndroidRobot's Avatar
  [0.00]
is there any increase in wind/road noise by running spacers? I would assume the tires would be creating more drag if they start to stick out or are nearly flush based on how air flows around them
      11-23-2019, 12:41 PM   #68
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
That is a question where a lot of variable will need to be accounted for.
For the drag:
1. Speed
2. hp rating
3. Weight of the car
For wind/tire noise:
1. Type of tire and brand
2. Tire pressure
3. Car insulation
But, in general, you will not notice any difference.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
March SALES!! Evolution Racewerks - Until 04/01 | PM for DEALS
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      11-23-2019, 03:02 PM   #69
AndroidRobot
  [0.00]
For the drag:
1. Speed
2. hp rating
2. Tire pressure
3. Car insulation
having more surface area exposed to the open will create more drag when it's a wheel since they're not exactly aerodynamic I'm curious if you hear any more noise because with most people I see running spacers where they're flush by me I can hear noise pretty easily. I love the look but would need to see for myself I suppose
I don't disagree with you for what it's worth. My X5 has acoustic glass to further reduce the noise
Thumbs27.50
      11-23-2019, 04:09 PM   #70
r33_RGSport
For the drag:
1. Speed
2. hp rating
2. Tire pressure
3. Car insulation
My personal experience, as far as flush look, I do not notice any difference.
The amount of road noise and mpg are the same.
      11-23-2019, 05:05 PM   #71
AndroidRobot
  [0.00]
For the drag:
1. Speed
2. hp rating
2. Tire pressure
3. Car insulation
mpg doesn't matter it's noise that I care about personally. I'll add it to my list of things I need to do for my car. They're not a priority currently because of how busy I am with work. thank you!
r33_RGSport12803.00
      11-23-2019, 06:22 PM   #72
r33_RGSport
Seems like all the Gremlins are gone with the car?
      11-23-2019, 08:07 PM   #73
AndroidRobot
  [0.00]
thankfully so far, yes, but who knows what will happen when I get it serviced in a week. I'm nearly 18k miles since I drive A LOT
r33_RGSport12803.00
      12-01-2019, 11:59 AM   #74
KrisV
KrisV's Avatar
Drives: 2023 BMW X5 M Competition
since the factory lugs don't fit with spacers what is everyone doing for the lug lock? do they make an extended lug lock set?
      12-01-2019, 12:03 PM   #75
LexxM3
LexxM3's Avatar
1698
Drives: E46M3, G05X5
2019 X5  [0.00]
I had a massive amount of "fun" with aftermarket rims, spacers, and bolts. The rims weren't stock thickness (thicker) that I didn't realize, that drove most of the fun. The very last step required grinding down 10 very nice forged bolts by 2mm each. Much more to the project ...
If you go with RG and stock rims, they will supply correct length bolts with your spacers. Much less "fun" ...
... unless one of your stock bolts turns out to be stuck inside the stock rim ... like I said, much more to the story.
r33_RGSport12803.00
      12-01-2019, 12:08 PM   #76
KrisV
KrisV's Avatar
but what about the one lug on each wheel that's a lock?
      12-01-2019, 12:22 PM   #77
LexxM3
LexxM3's Avatar
1698
2019 X5  [0.00]
You don't install it (you're supplied with 5 extended length bolts/rim). The locking bolt is stupid and a scam anyways, there are only 8 variants and key kits for all 8 are trivially available.
r33_RGSport12803.00
      12-02-2019, 12:21 PM   #78
nytrydr
Drives: 2006 BMW X5 4.8is
Are the front and rear OEM lug nut length both 27mm? Trying to determine that length of lug nut required if i did a +15mm front spacer and +20mm rear.
      12-02-2019, 02:42 PM   #79
KrisV
KrisV's Avatar
torn right now on decisions...you can get reps for the 742M wheels in black and regular finish and they are actually 10" front, 11" rear instead of the oem 9.5" and 10.5". That means you could throw a 295 tire on front and 325 on rear essentially. Question is will .5" wider rim all around look that much different than just doing spacers on my current configuration?
      12-02-2019, 07:49 PM   #80
LexxM3
LexxM3's Avatar
1698
2019 X5  [0.00]
Yes, stock BMW bolts and rims are all designed for M14x1.25 27mm shank bolt. In fact, my dealer parts department simply doesn't carry any other size in the M14x1.25 spec.
Adding bolt-through spacers in that case just adds that thickness to required bolt length. It doesn't have to be quite exact, a couple of mm either way will normally be close enough, but I would start to pay careful attention around and above say +/- 2mm for sure.
Note also that thicker spacers are not necessarily bolt-through and rather do a two stage mount: spacer to hub, then rim to spacer. 20mm is probably at the edge of where that becomes a necessity. My rear winter non-stock rim spacer at 22.5mm is like that. This requires further bolt attention. Normally a spacer supplier will give you the right spacer to hub bolts, but they need to know your exact car model to do that. Rim to spacer bolts will be stock 27mm for stock rims, and something else for non-stock rims.
      12-04-2019, 06:10 AM   #81
Ninefourteener
Ninefourteener's Avatar
1273
Drives: 2020 X5 M50i
I purchased the 15mm front and 20mm rear spacers.
The thread pitch size is 14x1.25
RG sport told me I needed 43mm and 50mm locks respectively.
I didn't want 2 sets of locks with 2 different keys, so I decided to "split" the difference, and order a set of 47mm locks. I really don't think 3mm in either direction is going to render the car "unsafe" by any means. I don't have the car yet, but I don't expect any issues.
EDIT: This post was updated, as I received incorrect info from RGsport.
12+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019
690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813
6-Piston X5M Big Brake Kit:https://g05.bimmerpost.com/forums/sh....php?t=1779038
      12-04-2019, 06:33 AM   #82
KrisV
KrisV's Avatar
The thread pitch size is 14x1.5
Specifically, these: https://www.ebay.com/itm/4Pc-Black-1...72.m2749.l2649
Yea... not super "high-end".... but if someone wants your shit bad enough.... they are going to get it. These will serve as a "detractor" to the common petty thieves. Otherwise, that's what insurance is for.
ok thanks for the info. i wonder what size for 12mm, 15mm ?
      12-04-2019, 06:40 AM   #83
Ninefourteener
1273
Presumably 40mm and 45mm.
I imagine you could get a 42 or 43mm set of 4 and be just fine
      12-04-2019, 07:22 AM   #84
LexxM3
LexxM3's Avatar
1698
2019 X5  [0.00]
[COLOR="DarkRed"]
M14x1.5 is NOT THE CORRECT BOLT!!!
G05 is definitely M14x1.25 !!!
[/COLOR]
And 3mm off in either direction may or may not be usable or safe and requires test fitment before finalizing the mount. If too long, a) may bottom out in the hub and not tighten to spec, or b) in the case of bolt-on spacers, may "protrude" and apply counter pressure to the hub (harder to explain without a diagram). If too short, may not retain torqued force and loosen. Regarding too short, I believe the rule of thumb is minimum of 10 turns depth (for M14x1.25, will be different for different bolt specs), but that needs to be verified.
https://blog.moddedeuros.com/how-to-...-or-volkswagen
https://www.drivenproducts.com/blogs...ead-engagement
Finally, I would NEVER use a lug bolt of unknown construction and origin i.e. "random shit off eBay". That's fine for pretty stickers and trunk nets, not a critical safety component like a lug bolt. The issue isn't whether someone steals your wheels, the issue is that an unknown bolt can sheer off under driving stress and kill you, your family, and others. To be sure, there are very fine Chinese bolts, but I won't be mentioning them in RG Sport's thread.
If these issues are too complicated (and they can be, no shame), you should not be dealing with rims and custom wheel mounting setups yourself.
Thumbs27.50
      12-07-2019, 04:17 PM   #85
Ninefourteener
1273
Thanks for your .....umm.... "advice". I think the locking lugbolts will suffice, being US made hardened steel. I think I'll be ok.
More importantly, M14x1.5 is what RGSport told me, and presumable matches the bolts they sent me with the H&R spacers. I haven't visually checked to see if the threads match yet though. I'll check this evening. If not, I still have 20 H&R bolts to do the install until I buy another set of locks. If you are correct, then hopefully they sent me the correct thread pitch, and just typed it incorrectly in their email.
      12-07-2019, 04:29 PM   #86
LexxM3
LexxM3's Avatar
1698
2019 X5  [0.00]
It is definitely M14x1.25. The "advice" is not just for you — we don't want people reading this taking wheel lug bolts lightly.
      12-07-2019, 04:43 PM   #87
r33_RGSport
It was my typo. It is 14x1.25.
I am so ashamed.
      12-07-2019, 04:47 PM   #88
Ninefourteener
1273
Ok... you were right about the size. It is M14x1.25.
I also just visually checked it. Turns out, they SENT me the correct lug size.... but then told me a different size in an email.
Thanks RG Sport.
I just ordered a 47mm set from ECS Tuning in the correct size.
https://www.turnermotorsport.com/p-3...pacers/?pdk=BQ
Going to update the post above.
r33_RGSport12803.00
